MT-100 Roland switch to MIDI play mode - how to
General information and assistance with Munt.
Postby Amdahl » 2010-3-10 @ 01:55
If at first you don't succeed, push every button combination until you do. At this time, the manual can be found at ftp://ftp.roland.co.uk/productsupport/M ... 100_OM.pdf
Roland MT-100 button combos that are somewhat useful:
Stop + BEAT/MEAS = Set THRU On/Off w/turn dial, then Execute. (Play MIDI IN, hooray!) You can use FWD/BWD to select other options as well. You can record this change to the saved settings(used during power-on) by holding the REC button while you press Execute.
Stop + Delete, then Execute = All Clear
Sound Control + Delete, then Execute = All Reset
Sound Control + Sound, then BWD or FWD, then Dial, then Execute = select patches for each instrument.
Sound Control + Volume, then BWD or FWD, then Dial, then Execute = select volume for each instrument.
Sound Control + Play, (Use the wheel to select a specific song) then Play = Plays a demo. (Stop or Play then work to stop or continue.)
I got the All Clear and All Reset from elsewhere on the web.
On USB MIDI adapters: I tried EMU Xmidi 1x1 USB MIDI interface w/MT-100 in WinXP with latest EMU drivers, and with only the Microsoft default drivers and SysEx did not seem to work. All music played with incorrect sounds.
I tried M-Audio USB Midisport Uno MIDI interface w/MT-32+MT-100 in WinXP and OS X. It worked fine with the default Microsoft drivers and in OSX. With the latest M-Audio Windows drivers installed, I got blue screens. If you know you don't need the M-Audio drivers, this seems to be a suitable device, although Amazon reviewers have noted a number of compatibility issues with other MIDI hardware.
Amdahl
Re: MT-100 Roland switch to MIDI play mode - how to
Postby HunterZ » 2010-3-18 @ 18:21
A word of warning on the Uno: There are actually two versions of it - one that is plug-n-play and one that is not.
Unfortunately I ended up with the older, non-pnp version. It works fine on my Windows XP machines, but not with my Win7 x64 machine because M-audio has not released a driver for that OS.
I recently picked up an E-mu Xmidi Tab from Creative/Amazon and my MT-32 and SC-88 are working fine with Win7 x64 (tested some .MID files in Windows Media Player and some old Cakewalk projects with Music Creator).
I won't be buying M-Audio products ever again, as they've been dragging their feet on Vista/Win7 x64 drivers for their MIDI interfaces since before Vista was released!
You're perfect, yes it's true...but without me, you're only you.
User avatar
HunterZ
Postby Amdahl » 2010-3-20 @ 19:23
That is odd.. I think I have the same Emu device(Xmidi 1x1 Tab), and SysEx seemed not to work in either Mac or WinXP. Do you know if you played anything that had MT-32 SysEx messages in it?
Amdahl
Postby HunterZ » 2010-3-22 @ 19:36
No, I haven't tried doing that yet - I only tried some MIDI files that were made for the default instrument set. I hope I don't have problems!
User avatar
HunterZ
Postby skate323k137 » 2018-8-01 @ 15:22
"Stop + BEAT/MEAS = Set THRU On/Off w/turn dial, then Execute. (Play MIDI IN, hooray!) "
This worked great for me. All I had to do was set THRU ON from OFF, and now my mt-100 works great. Got it for 50 bucks "broken" because it "would not respond to midi"
Celebration time!
Also, does the mt-100 have a battery like the sc-55 that I should change out? I opened it and look a quick look, didn't see one. Perhaps they expect you to use the QD (quick disk).
skate323k137
Return to MT-32 General
Who is online
Users browsing this forum: No registered users and 0 guests
