First post, by nikiniki
Hi
Shadow Warrior freezed after I defeated the first boss.
I selected 800x600.
The game runs fine if 320x200 is selected but I'd like to use higher resolution.
    14.17 KiB
Reply 2 of 12, by DosFreak
Which version of DOSBox?
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 4 of 12, by robertmo
where have you got your dosbox from?
what is your Operating System?
what are your PC specifications?
post your exact mountings
post what is written after you mounted
post content of "DOSBox Status Window" before running the game
enclose your dosbox's config file
Reply 5 of 12, by nikiniki
The dosbox webpage
windows vista
Vaio 4gigs, laptop
c:\dosbox\dosbox C:\ShadowW -conf dosbox.conf
see the picture
    5.74 KiB
Reply 6 of 12, by nikiniki
Here the picture
    8.16 KiB
Reply 9 of 12, by nikiniki
Hi
I created go.bat file to run Shadow Warrior.
In GO.BAT
When I erased dosbox.conf from SW directory, a new one was created at c:\users directory not from the game. I'd like the config was created in the game directory like Dosbox did with screenshots.
Also I changed svga_s3 to vesa_nolfb
Now, the graphic look better
But the game still crashes in the boss battle.
Here the dosbox.conf
    dosbox.conf
    9.92 KiB
    238 downloads
    Here dosbox.conf v0.73
