PCI sound cards and Chipsets from various manufacturers...
Discussion about old sound cards, MIDI devices and sound related accessories.
Re: PCI sound cards and Chipsets from various manufacturers...
Postby Kamerat » 2018-8-09 @ 13:07
ruthan wrote:I tested Yamaha 744 on GA-Z97P-D3 with loaded DSDMA driver, driver can be loaded, but when i try to test FX i get freeze, also YMHIRQ has some problem - message found and error on next line.. Its no go, or we need some programming..
Tried running Duke Nukem 3D setup? It's usually detects the source of the problem, if it's problems with I/O, IRQ or DMA.
User avatar
Kamerat
Postby ruthan » 2018-8-09 @ 13:32
Kamerat wrote:Tried running Duke Nukem 3D setup? It's usually detects the source of the problem, if it's problems with I/O, IRQ or DMA.
I tried Blood one, should i try Duke3D too?
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough HW.
User avatar
ruthan
Location: Schwarz Wald-from France to Ukraine, from Denmark to Austria. Celts+German+Slavs melting pot.
Postby dr.zeissler » 2018-8-09 @ 15:25
The chipset-dependencies is the strange thing here.
i815e with SOLO1(ES1938)
Dosdrivers -> Doom2/Hexen/Heretic/Duke3d/Swarrior/Blood -> DMA-Playback issue => no SFX (FM/MIDI does work)
Win98VXDdrivers => Doom2/Hexen/Heretic/Duke3d/Swarrior/Blood -> DMA-Playback issue => no SFX (FM/MIDI does work)
Win98WDMdrivers => Doom2/Hexen/Heretic/Duke3d/Swarrior/Blood -> working
i815e with YMH74x
Win98VXDdrivers => Doom2/Hexen/Heretic/Duke3d/Swarrior/Blood -> not tested
Win98WDMdrivers => Doom2/Hexen/Heretic/Duke3d/Swarrior/Blood -> not tested
CPU: PII 133-333 MOBO: SNI-D981 RAM: 512- FDD: Dualfloppy 3,5"HD/5,25"HD - 3,5"HD - 5,25"DD ISA-Catweasel HDD: 2x40GB - DVD
ISA(3): Audician32-S2Dreamblaster - GusACE PCI(3): Monster3D- Intel NW AGP(1): 3dfx V3-3000
dr.zeissler
Postby ruthan » 2018-8-09 @ 15:46
dr.zeissler wrote:The chipset-dependencies is the strange thing here.
There is lots of variables, even board vendor could matter in theory, same as used PCI slot and of course IRQs.Bios settings and drivers.
That Yamaha pure dos FX problem, i still believe that is not working because DSDMA.exe is not loaded, after sound driver.
I have ESS-Solo 1 on the way, multiple ones so probably at least one will work.
User avatar
ruthan
Postby dr.zeissler » 2018-8-09 @ 17:18
Today I got my Solo-1E (ES1946) that should have ESFM,SBpro and WSS. We will see...
dr.zeissler
Postby Kamerat » 2018-8-09 @ 17:54
ruthan wrote:I tried Blood one, should i try Duke3D too?
Did it just crash when trying to play samples in Blood setup?
User avatar
Kamerat
Postby ruthan » 2018-8-09 @ 18:15
Yeah, no error message, plain freeze before 1st-center sample..
User avatar
ruthan
Postby dr.zeissler » 2018-8-10 @ 06:51
The ES1946 is compatibilty-wise the same as the ES1938. I did not get WSS working yet, but I can tell you that
the dos-soundmixer does not work anymore and that the card produces massive slowdowns and stuttering
within win9x/2k while gaming. the ES1938 is fine. So I am pretty sure that the ES1938 is in fact the best
retro pci-soundcard for dos/win3/9/2k gaming. I will perhaps go the WDM-Drivers within Win9x so that
the problematic-games work too.
dr.zeissler
Postby dr.zeissler » 2018-8-10 @ 09:57
btw. the intel q33 chipset including gam 3100, what are the oldest possible drivers?
I think win9x does not work, therefore i915 should be the latest.
For win2k there is a driver for the GMA3100, but not for the hole chipset, or I am
wrong here and it starts with winXP?
c5720.pdf
This is my new retro-thin-client test sample
(107.42 KiB) Downloaded 5 times
dr.zeissler
Postby ruthan » 2018-8-10 @ 11:11
In first post i have found this: It (means ESS 1938) works almost flawless on VIA K8T890/VT8237x based motherboards, even on Socket AM2 boards that used the chipset. K8T890 means that VT8251 soughtbridge worked.. and AM2 quite new so i theory it could be better that some Core 2 duo machines.. I did small reasearch and VIa8237 southbridge was used from Socket A years, that is good sign.
Any experience with such boards?
User avatar
ruthan
Postby Srandista » 2018-8-10 @ 11:50
Yeah, I have VT8237S. It's not AM2 platform, but still same southbridge.
ESS Solo-1 is working flawlessly in DOS (7.1), sometime in the future I want to test it with some wavetable board too.
My overkill "retro" PC - Pentium E6500K, 512MB/2GB RAM, Radeon 9500@9700 (Softmod), 80GB HDD, Win 98/XP
User avatar
Srandista
Postby Kamerat » 2018-8-10 @ 12:16
ruthan wrote:In first post i have found this: It (means ESS 1938) works almost flawless on VIA K8T890/VT8237x based motherboards, even on Socket AM2 boards that used the chipset. K8T890 means that VT8251 soughtbridge worked..
No, that board (GA-K8VT890) is using the VT8237R southbridge, but I'll guess the VT8251 would also work fine with the Solo-1.
ruthan wrote:and AM2 quite new so i theory it could be better that some Core 2 duo machines.. I did small reasearch and VIa8237 southbridge was used from Socket A years, that is good sign.
The same southbridges were also used in socket 775 motherboards, some also supporting Core 2 CPUs like the Asus P5VD2-VM SE I got.
User avatar
Kamerat
Postby ruthan » 2018-8-10 @ 13:09
Kamerat wrote:No, that board (GA-K8VT890) is using the VT8237R southbridge, but I'll guess the VT8251 would also work fine with the Solo-1.
Regarding of this:
https://en.wikipedia.org/wiki/List_of_VIA_chipsets
K8T890 - has VT8251, original author probably wanted to say that K8T890 + others MBs with that VT8237R southbridges are supported.
User avatar
ruthan
Postby Kamerat » 2018-8-10 @ 14:14
ruthan wrote:Regarding of this:
I'll guess the southbridges are interchangeable, but VIA list the VT8237(R) for the K8T890 on their page.
User avatar
Kamerat
Postby LSS10999 » 2018-8-11 @ 01:38
K8T890 is usually paired with VT8237 series (R/A/S). There's a K8T900 that's to be paired with VT8251.
K8T900 and VT8251 are said to be pin-compatible with K8T890 and VT8237x respectively, so they should be compatible with ES1938.
Sadly, I personally haven't really seen any motherboards actually featuring K8T900/VT8251 pair. However, it seems VT8251 exists in some mATX motherboards like this one.
LSS10999
Postby RayeR » 2018-8-11 @ 01:53
Hm, in the dump I can see that brirges cascade have enabled the subtractive decode (PCI0->PCI5, PCI5->PCI6, PCI6->Aureal) so I don't know what else could make problem, esp. when it's random - it's bad.
You can try to make PCI dumps before loading the vortex driver for multiple times and compare logs for case when it feeeze and when it didn't freeze to see it there would be any difference. Also, did you try to swap the soundcard to second PCI slot?
Gigabyte GA-P67-DS3-B3, Core i7-2600K @4,5GHz, 4GB DDR3, 128GB SSD, GF7900GT, SB Audigy + YMF724F + DreamBlaster combo
User avatar
RayeR
Postby ruthan » 2018-8-11 @ 07:05
RayeR wrote: Hm, in the dump I can see that brirges cascade have enabled the subtractive decode (PCI0->PCI5, PCI5->PCI6, PCI6->Aureal) so I don't know what else could make problem, esp. when it's random - it's bad.
I tried both slots its the same. I wonder how SMB working, is list affected by virtual drivers devices etc.. or its only HW level, because from you post it seems to that it is affected by SW too??
Because its freezing in most of the cases 80% and even when it is working it failing very quickly.. it would be hard to make those logs, it would take lots of time..
I also tried to Aureal V1 with PCI-E to PCI bridge on X58, im not 100% sure that all was connected how it should be (these adapters are clunky), but there is big change that it was.. and when i tried create log with SMB.. i got pc speaker beeping and some strange binary characters on screen freeze.. i now that it is beta, but in all other cases it worked well.
User avatar
ruthan
Postby gdjacobs » 2018-8-12 @ 14:59
Some board manufacturers included the vt8251 with later IGP models. I believe it was an inexpensive way of bumping up the feature count.
User avatar
gdjacobs
Postby RayeR » 2018-8-12 @ 19:34
smb /pci use direct IO access to address all devices on PCI bus(es), it doesn't rely on PCI BIOS services. But some drivers may affect PCI devices configuration or enable/disable PCI devices. Hm, beeping speaker and screen garbage - I never seen this. PCI scan should not harm PC at all. But some HW/BIOS/SW combinations just may be unstable.
User avatar
RayeR
Postby ruthan » 2018-8-13 @ 17:42
ESS-Solo1 at home.
Can someone pleas share proven ESS-SOLO1 (1938) pure Dos driver package? I tried 2 packages from Forum, but there is strange message during autoexec part loading:
Code: Select all
PLease use Windows software applet to enable
Sound Blaster, MPU4041 for real / Windows DOS
So far no success with X58 or i865 but it could be driver problem above.
I865ESS.TXT
(8.13 KiB) Downloaded 5 times
X58ESS.TXT
(34.57 KiB) Downloaded 6 times
User avatar
ruthan
PreviousNext
Return to Sound
Who is online
Users browsing this forum: Marmes and 3 guests
