Reply 40 of 57, by arncht
Is there any difference? 😀 i will try out the wax, looks more promising for the longterm usage. I would use the 303, if i have chance to reapply. Maybe easier to remove the wax, if it is necessary.
I retrobringted this case 8 months ago, it was very yellow… now it is yellow again (stored in a box in the dark).
174.94 KiB
112.12 KiB
Overdoze of the demoscene
Reply 41 of 57, by Shponglefan
This does seem to be an issue with retrobrighting. People reporting that the yellow discoloration will return over time.
I've decided to accept the yellow patina on older cases. It's just part of what makes retro systems retro.
Alternatively, I've pondered trying out airbrushing instead of retrobrighting. I've wondered if lightly airbrushing a case with the original color, plus a thin topcoat might result in a longer lasting finish. Though it would also be more prone to damage of the paint / topcoat.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 42 of 57, by Killian
arncht wrote on 2023-02-25, 20:01:
No difference yet. It's placed right behind the window and it gets enough sunlight every day. So I am hoping to see a difference in few months. I also think that the wax is potentially better because it's a thicker barrier.
Reply 43 of 57, by waterbeesje
Shponglefan wrote on 2023-02-25, 20:09:
You mean, like the IBM ps/2 line? Those are coated and I yet have to come across one that is yellow.
Stuck at 10MHz...
Reply 44 of 57, by Killian
Well if you find a paint that has similar colour like the plastic and similar matte shine, then that would definitely fix the yellowing 😀. The yellow stuff would not be visible under the coat of modern UV resistant paint. That's definitely not something you want to do to rare pieces, but for a random old PC case - why not? I think finding a spray paint that would look authentic isn't going to be easy, but maybe has already done this and it can be found on google.
Reply 45 of 57, by Shponglefan
Killian wrote on 2023-02-26, 17:50:
This is why I suggest airbrushing, not spray painting. With airbrushing you can mix any color you want to match the case color exactly.
I did this recently when repairing a case using epoxy. I was able to match the existing case color perfectly creating a near-seamless looking repair.
Plus airbrushing can go on much thinner than spray paint helping preserve the original texture of the plastic.
Reply 46 of 57, by arncht
I do not think it will be so nice if it will be scratched. The dye would be perfect, but no chance to find the right color, and application process. Once i contacted with a company.
A computer beige could be popular for retro fans.
Reply 48 of 57, by Killian
I don't have a large test sample, but a case and speakers treated with 303 (applied multiple layers) yellowed again after 2.5 years at room temperature (it was also covered with a black plastic - didn't help).
Reply 49 of 57, by arncht
informatyk wrote on 2023-05-21, 20:42:
Did anybody can share results about that "303 Aerospace Protectant" after time? Did yellowing back?
You should reapply monthly, so if it even helps, not the best treatment.
Reply 52 of 57, by badmojo
I recently pulled a case out of storage that I'd retrobrited back to a nice bright beige, then given a few coats of 303, then wrapped in heavy plastic and stored in my garage. That was about 2 years ago and it's yellowed again, so I don't think I'll bother with retrobriting again in future - it can't be good for the plastic and doesn't last anyway.
Reply 53 of 57, by arncht
badmojo wrote on 2023-07-01, 12:31:
HOW OFTEN SHOULD I USE 303® AUTOMOTIVE PROTECTANT? It is recommend to re-apply product every 30-45 days for best results, and maximum protection against the sun's harmful UV rays.
I guess it uses similar stabilizer, what they put to the plastic, and it will degradate.
Reply 54 of 57, by arncht
informatyk wrote on 2023-07-01, 07:52:
arncht: please upload photos for people like me who don't use Instagram.
Retrobrighted parts, let’s wait another year in the dark, what happens.
    331.73 KiB
Reply 56 of 57, by Warlord
In the past I've removed the front cover and just layed in the sun on my driveway for 14 hours of sun to 28 hours and that alone will turn the yellowed plastic atleast 3-4 shades whiter. The heat also seems to rearrange the molecules a little making them slightly less brittle.
Reply 57 of 57, by arncht
Warlord wrote on 2023-07-01, 15:34:
It will be just degradated even more, if you put it to the sun, even if the “color” is faded out by the sun. You should store them in a cold, dark place, if it is possible w/o oxygen.
https://en.m.wikipedia.org/wiki/Photo-oxidation_of_polymers
https://popart-highlights.mnhn.fr/
Maybe with some coating we can slow down the process. It would be also a result, if it is yellowing again, but slower - that what i want to check. If there is no difference between the second traited parts, does not make sense to do do anything, and be honest the whole retrobringing is useless. If we can homogenize the sides, worth to invest, anyway just collect the most beige stuff, and try to store in the proper way.
