Thexder EGA vs TANDY/PCjr mode
Reply 23 of 63, by Mau1wurf1977
🤣 too hard to unpack a file 😀
Looks good. The pixels are roundish rather than square. And it has that typical CRT look! I like it...
Have you tried these output filters that DOSBox offers? It might simulate a similar image:
scaler: Scaler used to enlarge/enhance low resolution modes.
# If 'forced' is appended, then the scaler will be used even if the result might not be desired.
# Possible values: none, normal2x, normal3x, advmame2x, advmame3x, advinterp2x, advinterp3x, hq2x, hq3x, 2xsai, super2xsai, supereagle, tv2x, tv3x, rgb2x, rgb3x, scan2x, scan3x.
Reply 24 of 63, by Mr_Blastman
Yeah I've tried RGB2x and RGB3x and neither look the same (though, I can't try 3x because I don't have an older, smaller monitor hooked up that can do at least 1024x768 yet--the 15 inch that is hooked up only really does up to 640x480--it is _really_ old). You really need RGB3x to get close I theorize but I'll have to try it with one of my older monitors.
Here are some screenshots (the side by side didn't turn out well) comparing the Tandy RGB monitor vs. the VGA in Dosbox RGB2x mode.
http://rapidshare.com/files/437133570/thexder … bysidergb2x.zip
Reply 26 of 63, by HunterZ
Multiupload.com is good because they spread your file around to multiple sharing sites (including rapidshare) so that people have a choice of which to use.
Reply 27 of 63, by Mr_Blastman
Per your requests 😀
http://www.multiupload.com/MEKNVWZLBH for the RGB/RGB2x comparison
and
http://www.multiupload.com/CENZJ5G02H for the raw RGB footage on a real RGB monitor (and a real Tandy too).
Reply 28 of 63, by digitaldoofus
I LOVE Tandys. I can't believe that I waited over 20 years after they first came out, before I discovered how much "FUN" they are!
Once you try retrogaming, you'll never go back...
Reply 29 of 63, by MusicallyInspired
Tandy mode. Same with Firehawk. Also, for Thexder 1, Tandy is the only way to best experience the soundtrack.
Yamaha FB-01/IMFC SCI tools thread
My Github
Roland SC-55 Music Packs - Duke Nukem 3D, Doom, and more.
Reply 31 of 63, by MusicallyInspired
Right. I guess I meant the EGA as opposed to MCGA.
My Github
Reply 32 of 63, by Gemini000
Fire Hawk's "256 colour" MCGA mode is just its 16-colour Tandy mode rehashed to work on IBM computers with MCGA chipsets since they were NOT backwards compatable with EGA standards. :P
--- Kris Asick (Gemini)
--- Pixelmusement Website: www.pixelships.com
--- Ancient DOS Games Webshow: www.pixelships.com/adg
Reply 33 of 63, by MusicallyInspired
Yeah, I know that. But it's lo-res 320x200 compared to EGA's 640x200 dithered resolution.
My Github
Reply 34 of 63, by nikiniki
Fire Hawk's "256 colour" MCGA mode is just its 16-colour Tandy mode rehashed to work on IBM computers with MCGA chipsets since they were NOT backwards compatable with EGA standards. 😜
I don't think MCGA mode is backwards compatible with Tandy mode either. MCGA use mode 13 but only 16 colours are used.
Reply 35 of 63, by Gemini000
MCGA is one of the least compatible standards ever made. It's no wonder that there were never any MCGA graphics cards you could install (it was a chipset built into certain IBM systems) nor did it take long for VGA to push it out of existence.
Tandy's a special standard. Most old Tandy systems not only lacked EGA support, but installing an EGA card into a Tandy system was an interesting (and sometimes impossible) ordeal itself.
Fire Hawk supports Tandy, MCGA, and EGA modes specifically because those were the three predominant standards at the time and not a single one of them were compatible with each other. :P
Reply 36 of 63, by HunterZ
MCGA did at least make enough of an impact that VGA seems to be backwards compatible with it. Having had an ISA Paradise SVGA card when I bought Fire Hawk, I was disappointed that the MCGA mode was worse than the EGA mode.
As far as I know, Zeliard is the only Japanese game port that Sierra produced which uses more than 16 colors.
Reply 37 of 63, by Cloudschatze
Bah, this poll is flawed. Where's the MCGA option?
    5.81 KiB
    6.39 KiB
    27.94 KiB
Reply 39 of 63, by Gemini000
I think Cloudschatze is confused because this poll's about the first Thexder game while I started going off about Fire Hawk's graphics modes and their incompatibilities with each other. :P
Thexder came out the same year as the MCGA standard came to exist, I don't know which came first. There is no MCGA mode in the original Thexder, and in Fire Hawk it looks IDENTICAL to the Tandy mode.
