Reply 21 of 24, by ripsaw8080
Rank DOSBox Author
DOSBox Author
I've updated the patch to current SVN. It still works with my ISO and HSF test case images, but I haven't had an HSF image with audio tracks to test. Feel free to test it with your images, and let me know if you find any issues.
    hsf_svn3858.diff
    10.19 KiB
    45 downloads
Reply 22 of 24, by NewRisingSun
It works great with Jones (including CD audio) and all the other High Sierra discs I have tried, and does not seem to break anything else. Thank-you very much.
Given how well this works and that there are games for which it is needed, I would recommend integration into the main source.
By the way, GH: comparing the two releases of Jones I mentioned, I could not see the forest for the trees: the version with the latest dates being August 1991 only has DOS files, whereas my version with December 1991/January 1992 file dates has additional files for Windows support. The DOS files retain their original dates, except for the updated AUDCDROM.DRV. Silly me! I am not quite sure what the difference in AUDCDROM.DRV is, but they are both of the same size and differ only in a single byte. It seems to have something to do with a sector offset that is enforced --- 1991's AUDCDROM.DRV uses 150, 1992's uses 114.
Reply 23 of 24, by Great Hierophant
I would assume that the change would have something to do with the size differences between the data portion of the two discs, since the addition of the Windows files must add some size to the data track.
