First post, by ever
On a core i3 330um?
Notice that bold letter "u". It means its an ultra low voltage chip for an ultra-portable laptop I plan on getting.
I'm worried about the clockspeed which is only 1.2 Ghz and there is no turbo boost.
I understand that some people have had success running games such as descent and duke3d on netbooks at reasonable frame rates.
According to this website:
http://www.notebookcheck.net/Mobile-Processor … ist.2436.0.html
This chip is more powerful than the latest atoms, despite the slower clock.
Could I expect reasonable performance playing lets say duke3D or TIE fighter? If so what about more intensive games such as strike force centauri or realms of the haunting at 640*480? If not what about less demanding games such as Ultima VII or X-com?
Reply 2 of 4, by DosFreak
Descent and Duke3D have ports so you are better off using those.
Games with static screens should run fine.
Any 3D games would probably be slow at 640x+ if so then drop to a lower resolution.
No one can give you definte answers since most people on these forums that use DOSBox run them on laptops\desktops with normal processors.
Make your games work offline
Reply 3 of 4, by Serious Callers Only
Use dos32a when you can (replaces most dos extenders by a much faster one).
Notice that there are many games that use these extenders but don't advertise the fact - except maybe when run there is something saying dos4gw or something - the extender is embedded in the exe of the game, you can replace it anyway.
Games where this helps: any complex late dos game that didn't do it's own extender, typically had one of the standard ones: azrael's tear for instance. Many others.
