386DX40 build
Reply 177 of 434, by retro games 100
I have done some more testing with this mobo. The 100 MHz osci I ordered has arrived, and it works. The 386DX-40 chip now runs at 50MHz. I spent about 30 minutes messing about with everything, and I can get the mobo to behave sensibly at a bus speed of 13.3 MHz, but not at the very highest setting of 20 MHz. There's two things which may be vital to ensure that this mobo runs at this high speed (50 MHz CPU clock speed, and 13.3 MHz bus speed).
(1) Inside the BIOS set up area, and inside the "Advanced chipset settings" area, I think that the field "Auto Configuration function" must be set to Enabled. When it was set to Disabled, I couldn't get the mobo to POST successfully.
(2) I believe you must use a compact flash device, if you want this mobo to run at this high speed. But not just any compact flash device. Please look at the photo. Notice that the CF device is mounted directly on to the multi I/O controller card. Now take a look at that cable next to the mobo. That can also use a CF device, but it's built in to an IDE cable. That's no good. There's something "bad" about it, when running at this very high speed. This cable works 100% at a CPU clock speed of 40 MHz, but if you go higher, you need to ditch it in favour of the one mounted directly on to the I/O controller card.
Underneath this photo is a Speedsys screenshot. It shows an improved score of ~10. Previously, with the AMD CPU running at 40 MHz, I got ~9. My 3DBench score has improved from 16.9, to 17.5. I was hoping for a slightly better score, but I'm just using a Cirrus Logic card at the moment. I tried a Diamond Speedstar x24 card, but it displays garbage at the BIOS POST screen. It works otherwise, just not at this high speed.
Reply 178 of 434, by Mau1wurf1977
Hmm I also expected a heaps better score. Because going from 33 to 40 we saw quite a difference.
My YouTube channel
Reply 179 of 434, by Markk
Right now the board I have in my pc, does 15.8 fps using the default settings, and if I change only the at bus to 20MHz(sysclc2/4) it measures 17.5fps. With some further tweaking in some bios options, I can achieve 17.6, which seems to be my absolute maximum score. It would be interesting to try a 100MHz crystal....
I'm using also a cirrus logic 5422 card. I've got two of them. Not identical though. What's strange is that one has 80ns memory chips, while the other has 70ns. If I use the 70ns one, it's about 0.2fps lower than the 80ns.... I guess the other it's a better card.
Btw, I love that board... I noticed that if have the turbo turned off, it becomes REALLY slow.... Landmark speedtest shows performance equal to a 5MHz AT, and 3dbench does 1.2fps. Now I really need to dig up "zaxxon" 😀 I used to play that game on an Amstrad 1512 we had at school, but any other PC I owned after, was way too fast for it.... 😜
Reply 183 of 434, by retro games 100
Just finishing off testing, using the 100 MHz osci. The BIOS timings needed to be set to "auto". I couldn't set them manually, because the mobo would not POST. This only happens if I use a 100 MHz osci.
Reply 184 of 434, by Markk
I think what is a little strange in your case, is that it seems the cpu performance doesn't benefit much by the extra speed. On average, tested with landmark 6, the 386/40s score between 67 to 69 MHz, with the really good ones doing slightly over 69MHz.
Here's mine with normal settings :
and here's the same system with the at bus set to 20MHz :
Notice the performance boost of the vga in the second case, while the cpu is the same....
Reply 185 of 434, by retro games 100
Markk, congratulations on having an awesome system! 😎 😁 If I use a 100 MHz osci, I can't boot using a 20 MHz bus speed. I can boot at this bus speed, if I use an 80 MHz osci. However, I've got to put the BIOS timings on "auto", which I think cancel out any fine tuning. Here is Landmark using an 80 osci, with a 20 MHz bus speed -
Reply 186 of 434, by udam_u
You have got overclocker soul. ^^ Did you test any game with CPU running at 50MHz?
Reply 187 of 434, by retro games 100
I tried to run Quake. Hehe. It didn't run. Perhaps it requires a 486 or faster processor? I ran doom -timedemo demo3. That works, at 50 MHz CPU speed, with the bus speed set to 13.3 MHz. I get 2134 gametics / 10209 realtics. Unfortunately, I can get a slightly better score if I drop the CPU speed back down to 40 MHz, and also increase the bus speed up to 20 MHz. This means that on my 386 mobo, increasing the CPU speed to 50 MHz has little or no benefit. Pity!
Reply 188 of 434, by retro games 100
Oh yes! I've just got 18.5 in 3DBench. I'm using the 100 MHz osci, and the max bus speed of 20 MHz. It all works! When the multi IO controller detects the HDD at the BIOS POST stage, it appears to hang. What I did was just wait. I waited for about 40 seconds, and then the IO controller simply "unhangs itself", and continues to boot up DOS.
Once at the DOS prompt, everything is faster than ever before. This sequence of events has been repeated half a dozen times, to ensure it wasn't a one off fluke. Now, doom -timedemo demo3 gives me 2134 gametics / 9736 realtics.
Reply 190 of 434, by retro games 100
Markk wrote:
That's great! If I may ask, what is the speed of your simms, and also your cache chips?
The SIMMs are: bank 0 = 4 lots of 1MB 60ns, and bank 1 = 4 lots of 1MB 70ns. I hope to be able to replace the 4x 70ns 1MB SIMMs with 4x 60ns 1MB SIMMs, when they arrive. I wonder if it will make any difference?
The 256Kb cache chips are slow: 20ns! I do have 4 fans pointing at various areas of the mobo. One is on the cache chips, another is on the CPU, and two more are over the RAM and other chips on the mobo.
Reply 191 of 434, by Markk
I have 8x60ns 1mb simms, and changed the cache chips with 15ns(was lucky to find a guy that sells 50 of them for 10 euros), but I didn't notice changing much. But I really wonder if it would work better when running at 50MHz.
edit : I hope that if you change the four 70ns simms, you might see something. A similar example was my vga. It was working ok, but some flickering appeared on the screen while it was working, especially with graphics mode. Some day I thought to check on the card, and saw that it had 1mb but used four 60ns chips and four 70ns. I replaced the 60ns with another set of four 70ns I had, and after that it works fine.
Reply 192 of 434, by DonutKing
I'd be interested to see your results. my understanding is that the SIMMs just run at the same speed as the FSB regardless of their ns rating- this was in the days before SPD. You might be able to turn off 'auto configuration' and set some tighter timings with the faster SIMMs though. Otherwise I expect there wil lbe no difference.
This is actually an interesting point. The manual recommends 20ns SRAM for 40MHz with a 15ns TAG RAM chip. Obviously the chips are decent quality because they seem to be working ok at 50MHz. Perhaps that is part of the reason why you need auto configuration enabled- they only work properly with SRAM wait states at that speed? I wonder if you turned off auto configuration, and left the SRAM wait states at max, maybe you could tighten the memory timings.
Of course, if you could steal some 15ns or 10ns SRAM chips from a 486 or something you might be able to run the SRAM with even faster timings.
Reply 193 of 434, by Tetrium
DK is right. Try getting 15ns sram chips. Those should work even at 66Mhz.
Btw RG100, where'd you get the 100Mhz osci? Now I'm a bit more interested in acquiring one! But I don't have a lot of money to spend 🙁
Reply 194 of 434, by retro games 100
Sounds like I need some faster cache! I've got a box somewhere, with some old cache chips in it. I'll see if I can find it...
I got that 100 MHz osci from a place called Farnell. Tetrium, you're in luck. They have a NL website: http://nl.farnell.com/. They also sell 80 MHz oscis, if you ever need a replacement.
Also, I got the slower 66 and 50 oscis from rs-online. They are also global.
Reply 195 of 434, by Tetrium
Ugh...which one is it? I can't make heads or tails with all those different ones 🙁
Reply 196 of 434, by retro games 100
🤣 It's easy. Just search for 100 MHz frequency, then pick the 14 pin version. Here, this is the product code: O100M000000L434 just enter that in to the search box.
