Reply 460 of 590, by matze79
I soldered everything now together.
But unfortunaly i only have partially defective SID's 😳
I get just some Popping noises when playing a SID file.
The SID also runs pretty hot.
My other one does nothing.
Have to wait again 😳
Reply 461 of 590, by noop
@matze79 It is very very easy to break SID. It is one of those old chips that die from static or a even a bad contact. I killed one by temporarily disconnecting filter capacitor(on a working card). I believe, it is better to test these boards with something like swinSID, then insert a real one. Won't cover all possible mistakes, but better than nothing.
Always store SIDs in metal foil or conductive bags. Always discharge static electricity from your body by touching metal grounded things. Never try powering SID in a partially-assembled circuit. Avoid needlessly touching the board and Ext In while it is working. It is even better to not change any connections while the board is powered.
Reply 462 of 590, by Fagear
noop wrote:
@matze79 It is very very easy to break SID. It is one of those old chips that dies from static or a even a bad contact. I killed one by temporarily disconnecting filter capacitor(on a working card). I believe, it is better to test these boards with something like swinSID, then insert a real one. Won't cover all possible mistakes, but better than nothing.
Exactly. SIDs are very sensitive.
I've killed one 8580 myself just by touching the board with soldering iron (was replacing one capacitor). Another died while shipping because of bad packaging (SID was wrapped in non-antistatic plastic bag).
matze79 It's a pity that you can not get the working board right now... But yeah, those SIDs...
SID must be handled with extreme care and inserted as the last part into the board.
Do you have any ideas: were your SIDs working before?
New BIG soundcard: FMonster.
Covox Sound Master replica
Innovation SSI-2001 replica & DuoSID.
My audio/video collection.
Reply 463 of 590, by matze79
I tested the SIDs in C64, both are defective..
i will have soon a cheapo SwinSID avaible and i'm hope i can source the SwinSID Ultimate 😀.
Unfortunaly i have to wait to buy another SID 😀
Reply 464 of 590, by matze79
15 Minutes later, the postman appeared.
Reply 466 of 590, by matze79
They are HMOS and CMOS Technologie which are sensitive to Static Electricity.
If you walk over a carpet and touch it, it's like a lightening strike on a tree 😳 (bit extreme example)
Reply 467 of 590, by matze79
Recieved the Parts today, now i can build the SwinSIDs..
Recordings are coming soon 😀
Does the Gameport of the SSI make use of the Paddles ?
Reply 468 of 590, by matze79
I made today 10 SwinSID Nano, but 2 are not working for some Reason maybe they can't keep up with the 32Mhz.
Here are Recordings of Ultima 6 and a Picture of the SSI 2001 equipped with my SwinSID Clone.
    2.61 MiB
    Innovation SSI-2001 with my homemade SwinSID Nano Clone.
    ultima6-innovation-ssi-swinsid88.ogg
    1.71 MiB
    139 downloads
    Ultima 6 - Innovation SSI with SwinSID Nano
Reply 470 of 590, by Great Hierophant
keenerb wrote:
The U6 music sounds like it's missing a LOT of notes?
It is, the U6 music was composed for Adlib, which has 9 channels or 6 channels with 5 percussion instruments. A SID only has 3 (official) channels, and the music was not really redone, so it will sound like something is missing.
The SwinSID Nano does a really good job with the sample music! I think you would really need a well-trained ear to tell the difference between it and the real thing. I don't think U6 uses filters.
Reply 472 of 590, by Imperious
I have made up a couple of nano-swinsids for my c64's, there are quite a few problems with the firmware. Popping noises, clicking, volume levels staying low
at times, and so on. There is an updated "Lazy fix" firmware that solves some issues, but the author "codekiller" will not release his nearly perfect FW due to
copycats profiting from his labour. I don't blame him, but as the latest hardware design is not compatible with the older swinsids, and he isn't going to make
the older ones anymore, he could have released something for the community, but that's the way it is for now anyway.
Reply 473 of 590, by matze79
It sounds much weirder with px player playing midi.
I will do some recordings today 😀
It does Sound also pretty in Battle Chess 2 and Red Storm Risingl.
I can't find a working version of bad blood to test it 😒
Reply 474 of 590, by matze79
Updated Firmware of SwinSID to latest Version avaible, and recorded ultima again..
https://www.forum64.de/index.php?thread/56605 … 5371#post875371
Here some Updated Files of SSI 2001 Playback with SwinSID
It seems that Original for SSI Written Software works very well..
Ultima 6 Introduction
Ultima 6 Title Menu
Red Storm Rising
Battle Chess 2 - Soundeffects play also very clean.
But PX Player has its problems with SwinSID.
Attached files are:
CANYON.MID with PX Player
Doom 1 E1M1 with PX Player
Trying to get my Hands on a Ultimate SwinSID.
    Doom D_E1M1.ogg
    1.89 MiB
    109 downloads
    CANYON.MID.OGG
    2.09 MiB
    90 downloads
    Red Storm Rising.ogg
    2.5 MiB
    78 downloads
    Ultima 6 Title Menu SwinSID Nano.ogg
    2.19 MiB
    81 downloads
    Ultima 6 Intro SwinSID Nano88.ogg
    1.18 MiB
    95 downloads
Reply 475 of 590, by matze79
i tested almost all SSI-2001 Games and they are all working fine with the SwinSID..
It seems SSI-2001 Games don't make much use of Filters. (The Weakpoint of the SwinSID)
I now have a 6581 MOS in working condition.
Works well too.
Thanks for making the SSI-2001 Card.
Reply 476 of 590, by Fagear
A little update on DuoSID (two SSI-2001 on one board).
It is ready to be done in prototype version.
490.66 KiB
389.21 KiB
Reply 477 of 590, by j^aws
^^ Looks amazing - can't wait to test it out. Great work by all involved.
BTW, will it accept two different SIDs, i.e. both the 6581 and the 8580, or does it only take two SIDs of the same kind?
Reply 478 of 590, by Fagear
Voltage selection is separate, so it will accept different SIDs. You can set them to the same address and configure as stereo to get pseudo stereo effect.
Also list of available clocks is much wider:
0.795 Mhz (14.318/18)
0.895 MHz (14.318/16) = Innovation SSI-2001
0.985 MHz (17.735/18) = C64 PAL
1.000 MHz (2.000/2) = HardSID
1.023 MHz (14.318/14) = C64 NTSC
1.108 MHz (17.735/16)
1.193 MHz (14.318/12)
1.267 MHz (17.735/14)
1.478 MHz (17.735/12)
But the clock selection is for the both SIDs together.
Jumper manual:
JP1 (Divider input clock):
1-2: 17.735 MHz
2-3: 14.318 MHz (default)
JP2 (Divider):
none: /12
3-4: /14
1-2: /16 (default)
1-2, 3-4: /18
JP3 (SID clock):
1-2: 1.000 MHz
2-3: Clock/Divider (default)
Available clocks:
JP4 (SID 1/L port address):
1-2: 2E0h
3-4: 2C0h
5-6: 2A0h
7-8: 280h (default)
9-10: 260h
11-12: 240h
JP5 (SID 2/R port address):
1-2: 2E0h
3-4: 2C0h
5-6: 2A0h
7-8: 280h (default)
9-10: 260h
11-12: 240h
JP6 (SID 1/L voltage):
1-2: 9 V (MOS8580)
2-3: 12 V (MOS6581; MOS8580 will burn!)
JP7 (SID 1/L filter capacitors):
1-2, 3-4: 22 nF (C64 MOS8580)
5-6, 7-8: 1 nF (SSI-2001 MOS6581, default)
9-10, 11-12: 470 pF (C64 MOS6581)
JP8 (SID 2/R voltage):
1-2: 9 V (MOS8580)
JP9 (SID 2/R filter capacitors):
JP10 (Output/voice configuration):
Show last 3 lines
1-2, 4-5, 7-8: Stereo, 2x3 voices (default)
2-3, 5-6, 8-9: Mono, 6 voices (SID 2 output -> SID 1 input)
Reply 479 of 590, by j^aws
^^ So many great options to tweak this card now, especially the filter and clock options.
BTW, I was wondering if the sound output is via 3.5mm jacks or RCA jacks?
Personally, I would much prefer RCA, where I can use a simple Y-cable to hook-up L/R channels and keep them separate. And it would also give the card a classier audiophile look. Especially as this card is being upgraded, it doesn't have to follow its predecessors constraints.
