Reply 520 of 590, by Fagear
Tiido wrote:
I really like the idea used for brackets, I'll possibly use the same method for one project of my own.
Jo22 wrote:
Me, too. Reminds me of one of my father's DIY projects. He once built a case for a ham radio out of PCB pieces.
I use PCB as a mounting or casing material pretty often.
[total_offtop_end]
    44.32 KiB
    Support for erase head
    863 KiB
    Case lids are held by pogo-pins from inside.
    790.08 KiB
    Full case out of PCB.
New BIG soundcard: FMonster.
Covox Sound Master replica
Innovation SSI-2001 replica & DuoSID.
My audio/video collection.
Reply 521 of 590, by shock__
Would you by any chance mind sharing the .pcb files for those brackets? Might be an awesome alternative/budget option for the ARGUS.
Current Project: new GUS PnP compatible soundcard
[Z?]
Reply 522 of 590, by Fagear
I can share design files for Sprint Layout 6.
    mount.zip
    11.03 KiB
    87 downloads
Reply 523 of 590, by Jo22
Awesome! Thank you very much!
Reply 524 of 590, by j^aws
Fagear wrote:
A little update on DuoSID board. A factory board prototype is ready, but I still didn't get generators for other frequencies. […]
Glad to see this project still moving - looks amazing with a mix of old and new.
Reply 525 of 590, by ITzTravelInTime
For the cards because the cards can use different models of sid chips, is it more convenient to use both kinds of caps for each chip model and then select which one to use via a jumper or dip switch? or it is too difficult to implement?
Reply 526 of 590, by ITzTravelInTime
if you want a more professinal look for your expansion cards, you can use also a proper metal isa bracket, you can find them on mouser, but the pcb one or 3d printed should be ok too, but the metal one for me just looks more professional https://www.mouser.it/ProductDetail/534-9202
Reply 527 of 590, by matze79
is this project abandoned ?
Reply 528 of 590, by Fagear
Which one? SSI-2001 replica? Or DuoSID?
Replica is pretty much done, I don't have an intention to do any more batches of kits or assembled boards. Probably only bare PCBs if there will be any demand.
DuoSID is at full power, probably will start sell soon. Software-wise it is the same as two SSI-2001 in your PC. But with more configuration options, cleaner sound output, more available clocks and almost on the same size board.
And FMonster thing is in development...
317.75 KiB
Reply 530 of 590, by Fagear
keropi wrote:
^oh!
what is this? CMS+OPL2+SID combo card? 😮
Tandy 1000, CMS, OPL2, OPL3, 2xSSI (FM)onster... Probably with WaveBlaster header and mixer, probably not.
Reply 531 of 590, by keropi
that's 6-times wow! One card to rule them all? 🤣
I hope we get to see more previews as this progress! Great job!
Reply 532 of 590, by matze79
Hey where is Covox & DSS Support ? 😀
DuoSID 😀
Reply 533 of 590, by Fagear
At the same place as EMU8000, GF1, WaveFront and anything else. The name of the card (in the works) is FMonster. FM Synth board. It will be big and expencive as it is.
I don't know if I will put any existing mixer chip (software controlled) or I'll just stick with fixed mix or individual volume trimmers. I didn't research mixer chips yet.
Also I want to put MPU-401 interface with DB15 connector and WaveBlaster header, but it reqires additional space and routing. It would be cool to have "all-in-one" FM Synth board with proper MPU-401, so you can plug in any Wavetable synth(s) into it. And add any "normal PCM (+wavetable synth) board" you like.
For example, GUS as a second board, MT-32, SoundCanvas on the DB15 in chain and Yamaha Synth on WaveBlaster header. Killer config with just two boards. And FMonster in ISA 8-bit.
Also, I probably should open a separate thread for this...
Reply 535 of 590, by Fagear
j^aws wrote:
FMonster deserves no less.
Done.
Reply 536 of 590, by Eleanor1967
Are you already selling those cards? I may be interested to pick one up.
Reply 537 of 590, by Fagear
Not yet.
It's kinda... I've made the project, bought all the boards and parts to produce kits and assembled boards... And put it into the box. Didn't really get time to work on releasing or selling it.
I think I should, though.
I've just transitioned from DuoSID development straight to FMonster development (where parts of DuoSID were used). 😐
Does anybody else is interested in DuoSID?
    1.04 MiB
    DuoSID, finished.
    428.77 KiB
    DuoSID, back side.
    469.47 KiB
    DuoSID onboard clock generators.
    767.42 KiB
    SSI-2001 replica vs. DuoSID length
Reply 538 of 590, by Great Hierophant
That is a very nice looking board and it has all the options anyone would ever seem to need. I have one question. The edge contacts of the old board are gold whereas the new board look silver in color. This suggests a HASL finish. I hope you aren't planning on using HASL in production boards.
Reply 539 of 590, by Fagear
Well, those white boards were ordered as production boards. What's so wrong with HASL, not durable enough for thousand insertions?
Because I have about 30 perfectly fine boards with HASL finish edge connector without bevels... You suggest throwing those into a bin? Works fine in my systems.
