Reply 560 of 578, by matze79
It can also playback MIDI on 9x.
Midi Drivers and SID Player are avaible.
And maybe some other Software..
I`m not sure if support for hardsid can be coexist on a ssi-2001 card so ssi-2001 and hardsid software can be used.
EDIT:
Found Project URL Again:
http://hardsid.8m.net/
    52.3 KiB
Co2 - for a endless Summer
Reply 561 of 578, by elianda
Could you elaborate a bit what the HardSID does differently compared to the DuoSID to accomplish better compatibility to timing critical C64 replay routines?
I don't see the gain.
I mean would that be even possible with the SID connected through ISA bus or would it require to move the C64 emulation core to the card itself?
The application idea was to use such a card to record C64 tunes correctly with a convenient PC application such as ACID 64 Player.
Youtube Channel
Reply 562 of 578, by Fagear
elianda wrote:
Though I got a question how timing precise your card is. There are quite a few songs on the C64 that play samples or use oscillator feedback to produce reverb effects. For these the timing of the writes and reads is critical to produce the correct output.
Can you provide something to test on DuoSID? *.SID file that I can playback on DuoSID via three existing players? Or native *.EXE DOS program that will write to 0x280 +0x01C ports which represent all SID registers?
I can run test and show timings on logic analyzer and record produced sound.
elianda wrote:
On C64 the CPU and SID run on the same clock, how close can you get with the ISA card?
SID on DuoSID can be clocked as 0.895M, 0.985M, 1.000M, 1.023M (and many more variants), ISA bus can run faster I think. At least ~5 MHz if I'm not mistaken. And speed also depends on CPU speed of the machine.
The other thing is DuoSID contains ready/wait circuit from SSI-2001 that prolongs ISA access cycle for some time.
matze79 wrote:
The SSI-2001 never was meant to resemble the C64 Soundsystem on PC.
If you want this you can build yourself a HardSID ISA.
HardSID uses totally different address method. You have to, first, write address to the board, than you have to write data to the board. So it has to take two ISA write cycles for one SID write instead of one ISA write (or read) cycle on DuoSID.
New BIG soundcard: FMonster.
Covox Sound Master replica
Innovation SSI-2001 replica & DuoSID.
My audio/video collection.
Reply 563 of 578, by matze79
HardSID is supported directly by ACID64 Player.
ISA Bus will run on 7.68Mhz on AT Machines, or faster depending on ATCLK Setting in BIOS.
Up to 16Mhz depending on Configuration and Cards ( not many will work at this clock..)
Reply 564 of 578, by elianda
Ok, try this: Deep Kiss (Revision Cut) by LMan: https://csdb.dk/release/download.php?id=217847 (as .SID)
https://csdb.dk/release/download.php?id=217846 (as .PRG)
Recording: https://www.youtube.com/watch?v=d20DxzdOkkc
Youtube Channel
Reply 565 of 578, by shock__
Transplanting a SID to another plattform while maintaining full compatibility with the C64 is not a trivial task, which is why the HardSID has had a number of revisions, outsourcing a ton of work to a custom chip or software emulation. Take a look at this (supposedly) fully compatible hardware solution for the ZX Spectrum (which is basically half a C64): http://zxbyte.ru/index_en.php?id=7
Current Project: new GUS PnP compatible soundcard
[Z?]
Reply 566 of 578, by Fagear
Ok, Pentium-233 is definitely not enough to leverage playback of that SID 🤣 : https://www.youtube.com/watch?v=vAgSXiv4uh4
But K6-2+ @500MHz did the trick: https://www.youtube.com/watch?v=XeuzBPPsY2k
That is DuoSID with SwinSID on the left channel and real 8580R5 on the right. Clocked at 0.985 MHz.
Only one player was capable of playing "LMan - Deep Kiss" file... And that player really does not favor SwinSID, producing many glitches. Other player is more lightweight and produces good results with SwinSID... But it glitches both on SwinSID and 8580 on some files (that "background Pong" in "Edwin van Santen - Blackmail Tune 1"... 🤣 ). Still there no perfect *.SID player for DuoSID/SSI-2001. 😢
Reply 567 of 578, by matze79
ArmSID now also supports OPL2 Emulation.
https://www.retrocomp.cz/produkt?id=20
>ARM2SID is new TWO SIDs and SFX sound expander (OPL FM synthesis) emulator in one DIP28 socket size!
So it would be possible to decode additional address and add Adlib Support to the SSI %)
Reply 568 of 578, by Fagear
Here you go!
DuoSID meets ARMSID(s). 😎
578.04 KiB
ARMSID
682.52 KiB
ARMSID: STM32
1.16 MiB
DuoSIDs: old and new
Did not test this config yet.
Reply 569 of 578, by matze79
Hehe nice 😀
Reply 572 of 578, by shock__
erek wrote:
i wonder how many of these Innovation SSI 2001s really exist in the wild ?
I'm currently aware of 2 (owned by people on this forum, being the one with the "sid 6581" written near the socket with a marker and the one with a 6581R4AR) and one being "semi-lost" (should be on loan to someone in this city ... but that info is 8+ years old, with no update since - being the card with all pads present on the slot connector).
My "guesstimate" would be that the card never was widespread and is likely one of the rarest PC soundcards that was ever professionally made in a very limited volume.
[Z?]
Reply 573 of 578, by matze79
https://www.phantom.sannata.org/viewtopic.php?t=14626
is this Schematic up to date ? 😀
Reply 575 of 578, by derSammler
erek wrote:
Very disappointing seeing who the seller is and that he got it from the original developer and now trying to make big money with it. No idea who the "original developer" is, but you can bet if he sees this, he won't ever contribute anything to the community. Nor will others.
btw, wasn't he the one who run wild when someone tried to sell a pre-built clone card on Amibay for a hundred bucks? Screems hypocrite to me.
http://retro-net.de/blog.html
Reply 576 of 578, by Beegle
Just offering another perspective : without knowing the price he bought it from the developer originally (doubt it was free) it's hard to say. This cloning project is done now so I understand the need to get rid of stuff instead of hoarding it, as well.
The more sound cards, the better.
AdLib documentary : Official Thread
Youtube Channel : The Sound Card Database
Reply 577 of 578, by matze79
And who pays this price will keep the Item very well.
So for sure it will be preserved 😉
Reply 578 of 578, by Fagear
In the process of more and more optimizations for FMonster I've managed to make DuoSID board even smaller. 😐
262.46 KiB
DuoSID @2019-08-06
