First post, by Jorpho
There was some interest in this program last time, so I thought I'd point out that Giveaway of the Day is once again offering Paragon Drive Copy 10 Personal. There's about 8 hours left on the giveaway as of this posting.*
You could do worse as far as drive imaging software goes, and its P2V and P2P features are kind of unique - they let you easily re-configure a Windows installation to run under VMware or Virtual PC, or to run on different hardware than what it was initially installed on. I'm not sure how well these features actually work, but they're not the sort of thing I've seen in other similar products.
*The 8-hour limitation is the time you have to download the program, run the initial Setup program (that is, the GAOTD activation wrapper) and get a free license key from Paragon. The initial setup program will extract an MSI file to a location of your choosing; you can use it to install the program whenever you want. [GAOTD doesn't usually work like that.]
http://www.giveawayoftheday.com/drive-copy-personal-edition/
Reply 2 of 2, by Davros
there is a shareware version hopefully its fully functional for 28days like a lot of shareware (not sure)
if you just want to copy a drive once it should be enough
http://www.drive-copy.com/
