Fester77 wrote:for some reason the only time the cdaudio will play is when large install is done (to the best of my knowlegde).
It does not make sense for the program to operate in that fashion. That is not to say that it is not impossible, but if this only happens to "the best of your knowledge", you may be mistaken.
So I thought of tricking the game by copying the iso dirs (which is more or less identical to the install dir) to the hardrive then merging the install dir into that.
Then mounting this as cd so dosbox whould read it both as gamedir and cdrom.
Why not merge the install dir into the iso dirs, and then put the whole thing into a new ISO?
If this mount whould only read the oggs placed in that dir like imgmount does there could be saved a lot of space. and thats just one game.
Good thing disk space is mindbogglingly cheap these days.
I belive the ScummVM is capable of doing this. that is what i think is mounting a folder and associate track01 track02 and so on as cdaudio.
both emulators use the sameSDL.dll so i whould seem possible that DOSbox whould do whatever Scumm does
I do not think the functionality you are referring to is inherent to SDL.
