Retro Rig Photo Thread
Reply 1260 of 2709, by Anaxagoras
Pasi123 wrote:
2004 Pentium 4 retro setup / bedroom PC: […]
Specs:
CPU: Pentium 4 HT 3.0 Prescott
Mobo: GA-8SGXLFS
RAM: 2gb DDR1
GPU: Radeon 9800 PRO 128mb
HDD: 2x 40gb Seagate
OS: Windows XP Pro SP3
Monitors: 2x 17" CRT, Samsung Samtron 76E and Philips 107E
I still need to get a longer S-Video and 3,5mm-RCA cables so I could connect it to that 28" Philips CRT TV. And a better CPU cooler... One that I'm currently using is from a Celeron 1.8GHz which was the original build in that case.
You have the same TV than me!!!
In my opinion, the better solution for a CRT TV is using Arcade VGA.
There are several versions. I have an old AGP version in a dedicated PC for emulators.
Your setup will be a very good emulstation!!! 😎
My computers
Reply 1261 of 2709, by harddrivespin
Here's my 486 retro rig:
    271.24 KiB
    There is a 486SX-25 processor inside which is actually quite a good processor because it can play most of the CPU sensitive games without downclocking. The mobo is a bog-standard baby AT motherboard from late 1991. While the innards can't be seen I will post more pics tommorow hopefully. There is a acuMOS (pre Crrus acquisition) AVGA1 card in there right now, and a good quality Seasonic AT PSU. The CD drive is for decoration since the BIOS cannot detect CD drives. As of now it lacks an HDD or IDE controller card, since the only IDE controller card I have is ISA VLB. The turbo button on the case is redundant as of now.
Reply 1262 of 2709, by harddrivespin
Picture of my 486's innards: (Not screwed in, lacks a lot of stuff)
    312.75 KiB
Reply 1263 of 2709, by SpectriaForce
Custom HP XW6200 workstation:
132.46 KiB
HP XW6200 motherboard
2x Intel Xeon Nocona 3.4 GHz 1 MB L2 cache + stock coolers
4x Hyundai 2 GB DDR2-400
Sapphire ATI Radeon HD6450
Transcend 64 GB SSD
2x WD 250 GB HDD
Asus DVD-RW
Asus CD-RW
Card reader
NEC FDD
VIA Extra SATA + PATA controller
NEC USB 2.0 card
3x 80 mm fan red LED
3x Bequiet 80 mm fan
Seasonic 550W PSU
AOpen H700C case
Vista SP2 64-bits
The motherboard, which has ATX dimensions, doesn't just fit in a regular ATX case. In the original XW6200 case a couple bolts go through the CPU coolers and motherboard into the chassis. For this project I had to buy M3.5 nuts so I could fix the coolers on the motherboard and I had to fasten some tie wraps around the CPU coolers and the new chassis to make sure one corner of the motherboard would not bend due to the gravity on it. Luckily I could fasten the rest of the board with screws in their regular ATX holes. But that's not all. I also had to reuse the original case fans, which are now located at the bottom, because the CPU's don't run on full speed without them, to prevent them from overheating. Furthermore the power button, front USB and audio connections also had to be researched, but the original cable of the old case led me to the right pins 😀
127.95 KiB
This is now the pc I plan to use for XP games that don't run on Win2K (I don't want to use XP).
Reply 1265 of 2709, by harddrivespin
SpectriaForce wrote:
Custom HP XW6200 workstation: […]
Transcend 64 GB SSD
2x WD 250 GB HDD
Asus DVD-RW
Asus CD-RW
Card reader
NEC FDD
NEC USB 2.0 card
Seasonic 550W PSU
AOpen H700C case
Vista SP2 64-bits
Not really a retro rig though. Not saying it's bad (I like it!) just I don't think it fits the retro category.
Reply 1266 of 2709, by janskjaer
The Dell Dimension XPS M200s just had it's annual dust-out. Although, there was very little to be done as you can see (photos before work began). A 10-minute clean of the fans sufficed.
1.67 MiB
Nothing to clean really.
Christmas is definitely that time of year when I get my chance to really play some games. It's been a re-visit of games from 1997 so a lot of Rendition, PowerVR and 3Dfx based games. That's why the Creative 3D Blaster PCI, Matrox m3D, Orchid Righteous 3D and Creative Sound Blaster AWE64 are all in the case together, and have been getting a good run.
1.63 MiB
3D cards - all in
1.74 MiB
Rendition, PowerVR, 3Dfx
DELL Dimension XPS M200s
:Intel P1 MMX 200MHz
:64MB EDO
:DOS 6.22/Win95b
:Matrox Millenium II + m3D (PowerVR PCX2)
Chaintech 7VJL Apogee
:AMD AthlonXP 2700+
:512MB DDR
:Win98SE/2000 SP4
:3dfx Voodoo5 5500 AGP
Reply 1267 of 2709, by arncht
i upgraded the midi section
Asus VL/I-486SV2GX4 rev 2.1 SiS 85C471
Intel DX4 100 WB
Sharp 72 pin FPM 60ns 8M x2
WDC Paradise Bali32 1M VLB ARK Logic ARK1000VL
Creative Sound Blaster Pro 2.0 CT1600 ISA
Gravis Ultrasound 3.74 1M ISA
Roland MPU-IPC
Roland MT-32
Roland SC-55 Firmware 2.0
DTK PTI-265W VLB controller Winbond W83759AF
Quantum Fireball II 1280M IDE
Sony CDU-77E 4x CD-ROM IDE
Baby AT
FSP SPI-250G
955.93 KiB
Overdoze of the demoscene
Reply 1268 of 2709, by arncht
one of my favorite bundle.
1997 Q1 - Pentium MMX
Asus TX97-E rev 1.12 Intel 430TX
Intel Pentium MMX 200 SL27J
Mosel Vitelic PC133 SDRAM 7ns 64M
Hercules Terminator 3D/DX 4M PCI S3 ViRGE/DX
Diamond Monster 3D 4M PCI 3Dfx Voodoo
Creative Sound Blaster AWE64 Gold PnP CT4390 ISA
Gravis Ultrasound Plug & Play 1.0 8M ISA
1.17 MiB
1.37 MiB
479.54 KiB
1.15 MiB
1.01 MiB
Reply 1270 of 2709, by KSHIRZA1
My Aptiva 2144-M63
Pentium 133mhz
32mb edo ram
256kb l2 cache
56x cdrom
Ati all-in-wonder 3d rage ii 4mb pci
Ata133 ide controller pci
Patriot Blaze 120gb ssd
Yamaha 719s sound
IBM G40 14” monitor
IBM rapid response keyboard
IBM two button mouse
build thread...
IBM APTIVA 2144-M63 BUILD - BIG UPGRADES
\\IBM Aptiva 2144 build\
My instagram @kshirza1
Reply 1271 of 2709, by arncht
oeuvre wrote:
How do you get your cards so clean?
Nothing special... brushes, maybe isopropyl.
Reply 1272 of 2709, by ElementalChaos
Here is "Charon", my K6-2 (soon to be K6-2+) build. Shot with a 1997 Sony Mavica FD7 floppy disk camera.
    18.75 KiB
    39.66 KiB
Pluto, the maxed out Dell Dimension 4100: Pentium III 1400S | 256MB | GeForce4 Ti4200 + Voodoo4 4500 | SB Live! 5.1
Charon, the DOS and early Windows time machine: K6-III+ 600 | 256MB | TNT2 Ultra + Voodoo3 2000 | Audician 32 Plus
Reply 1273 of 2709, by DeafPK
Dude, that minitower case appears to be the exact same I have for my 486 in this topic I made like three minutes ago. Cheers! 😁
"an occasional fart in their general direction would provide more than enough cooling" —PCBONEZ
Reply 1275 of 2709, by netfreak
oeuvre wrote:
It must be some sort of vogons requirement to have that Gravis gamepad
Yep.
144.34 KiB
I like computing hardware from the 80s and 90s.
"Paul's Old Crap" retro computing videos
Reply 1276 of 2709, by luckybob
A CHALLENGER APPEARS!!!
WARNING, don't use Alcohol to clean these damn things. As you can see, it wipes the logo right off.
Reply 1277 of 2709, by Tetrium
You really use it that way? 😕
netfreak wrote:
Yep.
luckybob wrote:
A CHALLENGER APPEARS!!! […]
Lol!
I don't have one either though, I don't use gamepads 😊
My retro rigs (old topic)
Report spammers here!
Reply 1278 of 2709, by Stiletto
I have the upper one, the Gravis Gamepad Pro, in USB and charcoal grey. 😁
do the Fandango!" - Queen
Stiletto
Reply 1279 of 2709, by Gered
Gotta keep the chain going:
(No, I'm not just holding 2 of the same model, they are technically different revisions! Look at the label differences! 😜)
486DX2-66/16MB/S3 Trio32 VLB/SBPro2/GUS
P233 MMX/64MB/Voodoo2/Matrox/YMF719/GUS CD3
Duron 800/256MB/Savage4 Pro/SBLive (IN PROGRESS)
Toshiba 430CDT
