Retro Rig Photo Thread
Reply 1960 of 2743, by vad4r
Youngtimer twins:
755.85 KiB
1.43 MiB
1.6 MiB
Case: Lian Li PC A-05N
Mainboard: MSI P35 Platinum
CPU: Intel C2Q 9550 @ 3,57Ghz
CPU Cooler: Scythe Ninja Copper
GPU: MSI Geforce GTX560ti Twin Frozr II Golden Editon
RAM: 4x 1GB Geil PC2-8500
HDD: Samsung 840SSD 120GB
ODD: Samsung SH-224DB
PSU: Cougar SE400
1.47 MiB
buy picture:
1.78 MiB
vae victis!
Reply 1961 of 2743, by vad4r
Case: Lian Li PC-A05
Mainboard: Asus P8P67
CPU: Intel Core i5-2500K @
CPU Cooler: ?
GPU: GIGABYTE GeForce GTX 560 Ti OC
RAM: 2x 4GB G.Skill Ripjaws X DDR3
HDD1: SSD
HDD2: ?
ODD: ?
PSU: Enermax Liberty ELT500AWT
365.52 KiB
382.75 KiB
1013.27 KiB
720.23 KiB
485.93 KiB
vae victis!
Reply 1962 of 2743, by vad4r
Case: Fujitsu T-Bird-A
CPU: 2x Intel Celeron "Mendocino" 400Mhz (66Mhz x 6) @ 576Mhz (96 x 6)
CPU Cooler: 2x Noname with 60mm Revoltec Air Guard @ 10V
Mainboard: Abit BP6 (Intel BX440)
RAM: 3x 256MB PC133 cl2
GPU AGP: Asus V8200T264m TVR (GF3 Ti200)
GPU PCI: 2x InnoVision Mighty 3DII (Voodoo 2 12MB) @ SLI
NIC: Asus PCI-L3C920
Sound: Asus I-A16C (Creative Vibra 16C)
HDD: Seagate Barracuda 7200.10 250GB
ODD: Samsung Super-WriteMaster SH-S202J
PSU: Enermax Coolergiant EG565AX-VH(W)
OS: Windows 2000 + SP4
It´s a old built and the HW ist a little more mixed, but I like the yellow PCBs ^^
524.34 KiB
729.48 KiB
902.47 KiB
1.13 MiB
1.48 MiB
It will be updated soon...
vae victis!
Reply 1963 of 2743, by PD2JK
It doesn't need updates, already flawless in my book.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Orion 700 | TB 1000 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 1965 of 2743, by H3nrik V!
vad4r wrote on 2021-05-09, 12:20:
Case: Fujitsu T-Bird-A CPU: 2x Intel Celeron "Mendocino" 400Mhz (66Mhz x 6) @ 576Mhz (96 x 6) CPU Cooler: 2x Noname with 60mm Re […]
NIC: 08/15 Realtek ftw!
Abit BP6 (1).JPGAbit BP6 (2).JPGAbit BP6 (3).JPGAbit BP6 (4).JPGAbit BP6 (5).JPG
Oh, that's almost the exact build I am planning, I have sourced 4 400 MHz Mendocinos, hoping that 2 of them might be good for 100 MHz, an then a couple of Golden Orbs modified with room for capacitors .. Probably no or only one Voodoo, though - it's just so expensive 🤣
Reply 1966 of 2743, by vad4r
Asus TXP4-X
Pentium 166mmx
64MB RAM
S3 Vision 968
Crystal CS4280-CM
358.75 KiB
183.36 KiB
664.01 KiB
786.97 KiB
67.24 KiB
vae victis!
Reply 1968 of 2743, by sf78
Made this i486 DX4/100. It was an interesting experience because I don't think I've ever build anything from this era by using mostly NOS parts. Biggest problem was the two VLB cards which obviously had a resource conflict when most of the time the machine refused to POST. I seem to have fixed it by replacing the S3 with a Cirrus Logic. I was tempted to create a 5x86 based PC, but I feel it's more at home in a PCI board. I did have an ASUS board that had it all (ISA/VLB/PCI), but as it happens it only has a single VLB and it would really piss me of if I had to use a standard ISA/PCI I/O card.
145.53 KiB
Reply 1969 of 2743, by vad4r
sf78 wrote on 2021-05-11, 20:12:
... by using mostly NOS parts...
Very nice! Are there more NOS parts in Finland? 😁
And please do show us more pictures from inside.
And now something different:
Amiga 2000
Mainboard Rev.6.2 with CR2032 mod
Kickstart 1.3 + 3.1
Commodore 2630
icomp BigRAM 2630 (+120MB)
icomp Indivision ECS Flicker Fixer
BSC AT-Bus 2008 IDE Controller with Octapussy Rom
2x 4GB CF Card
120.2 KiB
211.36 KiB
187.93 KiB
103.53 KiB
1.99 MiB
vae victis!
Reply 1970 of 2743, by Caluser2000
Swapped the Panasonic 17" lcd tv or a 19" SANYO lcd tv and abosolutely no sign of flicker in Workbench 2.05 on my Amiga A600.
    565.05 KiB
Reply 1971 of 2743, by sf78
vad4r wrote on 2021-05-12, 05:24:
Probably not, got these from recycling and from an estate. Nothing much to see inside, just your basic bunch of cards and wires.
133.59 KiB
126.65 KiB
151.18 KiB
Reply 1973 of 2743, by ronyket
Hello to everyone.
I am new to this forum, but I am very happy to share the joy I had when building my retro rigs.
Here's the first one:
44.69 KiB
Front
116.9 KiB
Back
159.4 KiB
Inside
The specs:
Intel Pentium III Katmai 500 MHz Slot1
1x 256 MB PC133 + 2x128 MB PC133
ASUS P3B-F
Voodoo 4 4500 32 MB AGP
Creative SoundBlaster Live! 5.1 Digital (SB0220)
3COM 905-C Fast Ethernet NIC
56K Lucent ISA Modem
300W Generic "Bluecase" (a Brazilian brand) PSU
LG DVD-RW IDE Drive
Maxtor 80 GB HDD SATA with SATA to IDE Converter
1.44 MB Floppy Drive
ISA Controller Card for Genius Scanner
CoolerMaster Cavalier3 Case
OS: Windows 98 Second Edition (in Brazilian-Portuguese)
Now the only upgrade i am willing to do on this rig, is to get a better and safe PSU for it.
I also have built a 486DX, an AMD Sempron, an AMD Athlon 64 (S754), a Core2Duo and a Core2Quad too.
Later I can take pictures of those and post in this thread.
Reply 1974 of 2743, by vad4r
AcerPower Magic
Pentium 60 with FDIV bug (SX835)
MICRO-STAR International MS-5103
40MB EDO Ram
520MB Seagate HDD
S3 Tri64+
ES1868F
3com Etherlink III
Seasonic SSG-200G
763.69 KiB
1.43 MiB
1.33 MiB
vae victis!
Reply 1976 of 2743, by Doornkaat
ronyket wrote on 2021-05-13, 17:36:
Hello to everyone.
Welcome to the forum! 😃
That's a nice, balanced system.
What's the modem for?
Reply 1977 of 2743, by rcarkk
1997 AT socket7 MMX / 3Dfx + benchmarks
CPU - Pentium MMX 233MHz
Motherboard - DFI P5BTX/L
RAM - 64MB SDR SDRAM PC100 @ 66MHz CL2
Graphics - Matrox Millennium II 4MB PCI
Sound card - Sound Blaster AWE64 Value CT4500
3D graphics - Orchid Righteous 3D
HDD - Maxtor 5.2GB IDE UDMA
CD-ROM - Toshiba 24x
Benchmarks DOS
3D Bench 320x200 = 66.6 fps
3D Bench 640x480 = 164.6 fps
Chris 3D Bench 320x200 = score 276.2 = 165.7 fps
Chris 3D Bench 640x480 = N/A
PC Player 320x200 = 59.0 fps
PC Player 640x480 = 22.8 fps
Doom slow PCs = 261 realtics (74690/261 = 286.2 fps)
Doom fast PCs = 900 realtics (74690/900 = 83.0 fps)
SpeedSys 4.78
Memory Bandwith (64MB) = 241.98 MB/s
CPU score = 176.79
Data cache L1(16kb) = 425.96 MB/s
Data cache L2(512kb) = 185.19 MB/s
Memory throughput (64MB) = 137.67 MB/s
Benchmarks Windows 98SE
- Winquake 1.09 without sound - 320x200 = 51.7fps
- Winquake 1.09 without sound - 512x384 = 20.7fps
- Winquake 1.09 without sound - 640x480 = 17.0fps
- Winquake 1.09 with sound - 320x200 = 42 8fps
- Winquake 1.09 with sound - 512x384 = 17.8fps
- Winquake 1.09 with sound - 640x480 = 14.4fps
- DosQuake 1.06 without sound - 320x200 = 53.3fps
- DosQuake 1.06 without sound - 640x480 = 16.8fps
- Quake II 3.09 without sound - 320x240 = 25.1fps
- Quake II 3.09 without sound - 512x384 = 15.8fps
- Quake II 3.09 with sound - 320x240 = 22.5fps
- Quake II 3.09 with sound - 512x384 = 14.2fps
- GL Quake 0.94 without sound - 640x480 = 35.0fps
- GL Quake 0.94 with sound - 640x480 = 34.9fps
- Quake II 3.09 3dfx without sound - 640x480 = 26.4fps (8bit text on) 23.6ps (8bit text off)
- Quake II 3.09 3dfx with sound - 640x480 = 25.7fps (8bit text on) 23.0fps (8bit text off)
Baby AT socket7 - Pentium MMX 233MHz + 3Dfx Voodoo
Socket 8 build - Soyo 6FA + Pentium Pro 200MHz + 3Dfx Voodoo 2 12MB
PC Remake - Pentium III 450 + Matrox G400 16MB
The K6-III build
Reply 1978 of 2743, by vad4r
Network Mini AT Tower
Mainboard: Biostar MB-8500TAC-A (+ CR2032 Mod)
CPU: Intel Pentium 100Mhz
RAM: 2x 16MB EDO
GPU: Diamond Stealth Video 2500
Sound: Sound Blaster 16 (Vibra) CT2980
NIC: RTL8029 PCI
HDD: 1GB
ODD: Matsushita CR-581-M
FDD: 3,5" 1,44MB
PSU: King Year KYP-200WT
Untouched since years, only the Dallas was empty and needed a mod....
542.2 KiB
657.31 KiB
910.26 KiB
850.93 KiB
1.61 MiB
vae victis!
Reply 1979 of 2743, by vad4r
My P166mmx you can find here: Re: My first, own PC (rebuild)
Intel Pentium 200 (no MMX)
VX Pro+ USB Ultr
48MB EDO RAM
Elsa Winner 3000-M
Orchid Righteous 3D
Creative Sound Blaster 32 PnP
WDC AC11000H 1GB
BCD 24x CD-Rom
93 KiB
289.32 KiB
249.72 KiB
180.15 KiB
vae victis!
