First post, by Decop
Hello !
I threw DOSBox 0.74 and I have a message mistake:
Z:\>mount E E:\Rimini_V
Drive E is mounted as local directory e:\Rimini_v
Z:\>E
E:\>Dir
RIMINI.BAT
RIMINI_V.EXE
RITEXTD.TXT
E:\>Rimini
Data E:\RIMINI_V\RITEXTD.TXT not fund??????
The file exists = to see annex
Do you have an answer?
Thank you
    RITEXTD.TXT
    2.83 KiB
    95 downloads
Reply 1 of 4, by leileilol
Ok this is an absolute path issue (did you install it within DOSBox?). try this
Make a E:\DOS directory, and move the Rimini_V folder into it
Mount E: to E:\DOS
E:
cd Rimini_v
rimini
Reply 2 of 4, by DosFreak
There is no "E:\Rimini_v" in the guest if "E:\Rimini_v" on the host is mounted as a virtual e:\.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
