Screenshots of the current CVS - round 2 (ADULT MATERIAL)
Reply 43 of 72, by jurgen
Well, it càn be done ; with the more recent cvs versions, on my 'slower' AMD Athlon 1300, I can easily run most of the games at +9000 cycles without overloading the cpu, if you set overlay=true (or scaler=none) etc.,
so on a shiny new cpu at 2,6 Ghz , it should be possible to run dosbox at 18000+ cycles (I suppose)
J.
Reply 45 of 72, by Guest
guest: i told you i had a reason...doom competition demos are only valid if recorded with the original .exes, no port demos are allowed. so i need to be able to run the .exes. simple, yes?
and as I mentioned, I only have an xp1700+, overclocked at 1.7Ghz. At 16000 cycles, dosbox uses 97% of CPU. I compiled with cflags -march=athlon-xp -O3 -fomit-frame-pointer and it was noticeably better than default cflags, so if you need speed, you might wanna try that (well, use the appropriate -march, obviously :>)
Reply 47 of 72, by priestlyboy
I wish i had screenshot ability to prove this but using rpja's cvs build at www.mypixels.dk/forums (you have to become a member and make a few helpful posts to get the build)
runs Privateer... kinda oddly not completely in sync so to speak. Jerky here or there. But It ONLY works in the Debugger version of DosBox for some reason.
I've commented on this as it occured to me on the DosBox Unoffical CVS forums.
BTW if you do go there to become a member. You can use me as a referal.
Same name as on here - "priestlyboy" - no qoutes of course.
Later guys,
Ieremiou
Reply 49 of 72, by almightyjustin
Hmm ok I can get more speed than I thought, first of all the speed varies a lot by game (Tyrian is quite slow and erratic) but setting scaler to none or overlay to true gives a big speed boost in all cases. Have to try some of those compiler optimizations too.
Swim, swim, hungry! Stupid fish.
Reply 51 of 72, by Magamo
Wing Commander II: Vengeance of the Kilrathi is definately a few steps closer to working, except for the fact that it now crashes upon trying to open campaign.s00 after you destroy all the fighters attacking the Concordia at the end of the second mission.
Entering your name
The TCS Concordia in the second mission
Reply 54 of 72, by Jiri
Yes, it looks like another forgotten gem. I own this game for some time but I have not played it yet because of technical problems (with sound etc.). So I´m glad that it works in DOSBox now.
More info:
fanpage: http://members.tripod.com/~noctrop/
review: http://fourfatchicks.com/Reviews/Noctropolis/ … ctropolis.shtml
Reply 57 of 72, by Guest
[quote="almightyjustin"]This should make some folks happy...it's überslow though and I've only tested the demo version (don't have the full). I can't get the sound effects working either, only music. You also need to increase memsize in dosbox.conf or it'll be even slower and crash when you start a game.
could you copy here the dosbox.cfg ? I could'nt made it run 😢
Reply 58 of 72, by Harekiet
Rank DOSBox Author
DOSBox Author
Hmm ecstetica seems to be working now too.
    29.48 KiB
    24.54 KiB
