First post, by dosquest
Okay, I have an old nanya nv999.0 16mb card from an olf gateway, is this better then my current one? My current one is an ati agp pro, I think.
Reply 2 of 6, by dosquest
Okay, the current card is a buiult in 4mb with another 4mb added to make it 8mb, I was wondering if this stock graphics card (it came out of a windows 2k tower) would be better then my current card is an ati rage pro intergrated.
Reply 3 of 6, by sliderider
Sounds like an ATi Rage of some sort. I have a few machines with those built in. The TNT is probably going to be better. If it's an OEM board, which it sounds like, it could also be a Vanta which is a slower TNT with a narrower memory bus. You'll have to do your own benchmarking to determine which is faster unless someone else has done the comparison themselves. I don't have any TNT boards to test against my onboard ATi's.
Reply 4 of 6, by Tetrium
TNT M64 is roughly similar in performance to TNT (except the Vanta, which was a lower clocked M64). You can kinda compare then to GF2MX vs GF1
My retro rigs (old topic)
Report spammers here!
Reply 5 of 6, by Pippy P. Poopypants
Do you have any way of testing the card to verify its identity? From a blind guess from the memory configuration I'm gonna have to go with it being a TNT as well (or possibly also a TNT2 M64 or Vanta). Either way, it's going to be much better in terms of potential compatibility issues with hardware and software, as opposed to the ATI card.
*SDR
Reply 6 of 6, by Tetrium
Google tells me it's a TNT
