Reply 40 of 47, by SavantStrike
wrote:If your Dell has a proprietary power supply, you will need one of these to make the switch to a standard ATX. […]
wrote:Oh it's ok. The Optiplex only has a single V2 in it. My XP machine with a bigger, better PSU holds the SLI rig. I have a desktop from 2003, the old Dell, and my Alienware m11x. I probably shouldn't buy any more computers for a while 🤣
http://www.endpcnoise.com/cgi-bin/e/std/sku=dellconverter
You'll probably find hacks for converting an ATX PSU to Dell, but using this adapter is a lot easier and you can still use the PSU with standard ATX boards later without having to reverse the hack.
The only thing that bothers me is it's not clear if Dell ever used a non standard pinout on the 20 pin ATX connector, but omitted the extra AT style plug. Then there's no identifiable way of knowing if it's standard or not without further research.
