First post, by rexswain
Is there anyone out there who has gotten Amtex's Eight Ball Deluxe to work? (Beside "oldmike", who is not responding.) I wonder if you would share your DosBox configuation with me? I am an experienced middle-aged programmer (i.e., I actually used DOS on my IBM PC XT), so you don't need to use baby talk. But I am confused about how to get EBD going.
I have DosBox installed, and I have the EBD files in a directory on my C: drive. So I start DosBox
DosBox c:\games\8ball2
and then when I get the DosBox C prompt, I execute
8balldlx.exe
But then it freezes.
FYI, I also have the original EBD diskettes.
Rex Swain
http://www.rexswain.com
Reply 4 of 9, by frip
sorry for multiple posts having problems with attachments.
Working is 15,000 Cycles
Funky is 7,700 Cycles
Attached dosbox config
    dosbox.zip
    1.69 KiB
    355 downloads
Reply 5 of 9, by Harekiet
Rank DOSBox Author
DOSBox Author
Well it's a more a problem with the vga emulation that the screen is drawn to quickly and games thinking they still have some time before the lower half of the screen still needs to get drawn
Reply 7 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
Yeah On a real pc the drawing of the screen is process that takes time.
Dosbox draws the screen at once but keeps the virtical retrace active for the time the drawing takes on a real pc. (else many games mess up)
So games wait for the virtical retrace wait half a period and change the pallet. or change other things.
In dosbox this doesn't work as the sreen isn't updated any more
Water flows down the stream
Reply 8 of 9, by Srecko
So,
If the processor is fast enough, game has enough time to draw things
correctly during the vertical retrace. If not, it uses time during screen drawing.
That explains why raising cpu cycles helps.
Hmm, wouldn't it, in some cases, help to draw complete screen at the end of the drawing period?
(only if game doesn't alter the upper part of the screen in similar fashion)
