First post, by Guest
Motherboard: Not Sure (runs Dual BIOS though)
Processor type and speed: p4/2.4ghz
Amount and type of RAM: 512MB DDR
Video board w/ RAM amount and type: Nvidia GeForce4 MX440/64MB
Sound board:AC97 Onboard
Operating system: XP Pro
Game name (and version, if applicable): FC Demos
Reproducibility of problem (always, only once, always but only on a specific level, etc.): Always
Version 0.60
Steps already attempted to solve the problem:
- made sure EMS/XMS enabled
You can't really call yourself a dos enthusiast unless you've ever heard of future crew and other great demo groups of the old scene. I tried running a few demos today, a lot of them didn't have sound. If you can get sound to work in these demos then I can guarantee about 95% of your sound issues will be solved.
http://www.phreak.org/index/archive02/load/load.shtml
go look through that archive devs, you'll find a plethora of old scene demos, check out unreal and panic by future crew, I'm thinking that part of the reason sound isn't working in either is that you might also need the SET SOUND=C:\SB16 (or wherever) environment variable, that may require some drivers not sure.
Kudos to you guys btw for actually having working adlib that is awesome!!
- sinister x [acid]
