My Covox (Stereo-On-1) LPT Stereo DAC - home made sound card
Emulation of old PCs, PC hardware, or PC peripherals.
Postby totalizator » 2011-10-16 @ 14:13
Hi everybody!
After I could not find any Covox to buy I've decided to build one myself. Here is the result: http://youtu.be/rKb1F-ApK3s and another video with more music http://youtu.be/x2iZFVoOq68.
Cheers!
Covox (Stereo-On-1) LPT Stereo DAC - home made sound card by drhabber, on Flickr
User avatar
totalizator
Re: My Covox (Stereo-On-1) LPT Stereo DAC - home made sound card
Postby MaxWar » 2011-10-16 @ 16:22
Thats is very neat, and the thing sounds pretty good too, i am actually surprised, thumbs up!
User avatar
MaxWar
Postby Mau1wurf1977 » 2011-10-16 @ 16:58
Very cool!
Wish these DIY guides were available when I was a kid...
Any chance you could record a few DOS games?
User avatar
Mau1wurf1977
Postby Stull » 2011-10-16 @ 17:48
Perhaps the Doom E1M1 music? ;)
User avatar
Stull
Postby MaxWar » 2011-10-16 @ 17:52
Stull wrote:Perhaps the Doom E1M1 music? ;)
That would have been cool, but the Thing cannot play midi unfortunately :P
User avatar
MaxWar
Postby GXL750 » 2011-10-16 @ 22:47
I'm surprised at the way it sounds; quite nice. I would have expected a Covox to sound more or less like a Gameboy.
Where are the mod files from?
User avatar
GXL750
Postby totalizator » 2011-10-17 @ 16:19
The links to download MOD files are in the video's description.
There is not many games to play with Covox and you can find gameplays from some of them on YouTube already (Pinball Fantasies, Wolf 3D).
User avatar
totalizator
Postby Robin4 » 2011-10-17 @ 23:53
Make more and put them on ebay!!
User avatar
Robin4
Postby Sol_HSA » 2011-10-20 @ 17:07
Well.. covox /speech thing is "just" a DAC bolted into the printer port, if I remember correctly. In any case there's no synthesis, so it sounds like the samples that are played through it, not like a gameboy.. =) Didn't know they come in stereo variety though.
http://iki.fi/sol - my schtuphh
User avatar
Sol_HSA
Postby Cyberdyne » 2011-10-20 @ 18:16
Ok I have a question for Dosbox developers and Covox maker, how do you make Wolfenstein 3D detect it as Disney Sound Soure, can i connect LPT pin 10 constantly to GND sufficient. Or is the detection mechanism more clever?
User avatar
Cyberdyne
Postby Cyberdyne » 2011-10-22 @ 22:18
Come on dudes, you made dosbox Disney Sound Emulation, and you can not give me istructions, how to make my covox behave like a Disney!
I am aroused about any X86 stuff that has full functional ISA stuff. I think i have problem.
User avatar
Cyberdyne
Postby h-a-l-9000 » 2011-10-22 @ 22:38
The Disney actually has a little FIFO buffer, a simple DAC isn't enough.
1+1=10
h-a-l-9000
DOSBox Author
Postby Cyberdyne » 2011-10-23 @ 09:25
That i know! But if you cheat your program to use Disney driver with Covoxer, the sound works, it only checks that the FIFO buffer is not full, and FIFO tells it to the computer by holding LPT pin10 low. If it goes high, then it does not send sound information. Am I right?
User avatar
Cyberdyne
Postby h-a-l-9000 » 2011-10-23 @ 10:06
Detection routines vary between games, but typically they check that the FIFO reports full after a certain amount of writes, so yes they are more clever. The DSS also generates the sampling rate (FIFO emptying), so even if you trick it into being detected it will not sound correct, depending on the routine used by the game.
You assume that we are always reading every post?
1+1=10
h-a-l-9000
DOSBox Author
Postby matze79 » 2018-7-10 @ 05:40
Does Auto Detection work with this one ?
https://www.retroianer.de
matze79
Return to PC Emulation
Who is online
Users browsing this forum: No registered users and 0 guests
