VOGONS Driver Library
Reply 460 of 1466, by paulo_becas
What about registration? Is it possible?
AMD Am486/Am5x86-P75 DX5 133 Mhz-64Mb Ram
S3 Trio 64V2DX 2 Mb
Soundblaster AWE64 Gold+Music Quest+MT-32+MU80
LAN-3Com
1.44 3,5 Epson Drive+1.2 5,25 Mitsumi drive+Iomega Zip 256Mb
8gb HDD,4Gb CF HDD
HP CDRW 9200
http://jp-retro.blogspot.com
Reply 461 of 1466, by SquallStrife
As long as nothing screwy happens in the next 24 hours, then tomorrow I'll start creating accounts.
There's no registration process, I just create the accounts manually in the DB. 😀
Reply 462 of 1466, by paulo_becas
So i can wait a PM when it's done? 😉
S3 Trio 64V2DX 2 Mb
LAN-3Com
8gb HDD,4Gb CF HDD
HP CDRW 9200
Reply 464 of 1466, by paulo_becas
Great, thanks
S3 Trio 64V2DX 2 Mb
LAN-3Com
8gb HDD,4Gb CF HDD
HP CDRW 9200
Reply 465 of 1466, by vetz
Could it be an idea to create moderators for the different sections? The content could use a "clean-up" to sort out descriptions, remove duplicates, etc.
Reply 466 of 1466, by SquallStrife
I've been thinking that for a while.
That said, anybody with an account can edit any file, so if someone wants to take up that role they can just go ahead and start fixing! 😀
Reply 467 of 1466, by vetz
Should be pre-approved list though, so if anyone starts wondering why "vetz" have edited their post they can find official info on it. I could probably do some edits in the video section.
Reply 468 of 1466, by SquallStrife
Oh yeah, that's a good point actually.
Um, let me come up with something. Might not be immediately, but some time this week with a bit of luck.
Reply 469 of 1466, by vetz
Two ways to do it simply:
1. Add the names in the first post in this thread.
2. Add a special icon/color to the persons who are official moderators.
Reply 470 of 1466, by Jolaes76
I would like to use Total Commander + sftp plugin + requried DLLs from http://curl.haxx.se/download.html#Win32
I got so far as contacting the server, but logins halts here...
    17.51 KiB
"Ita in vita ut in lusu alae pessima iactura arte corrigenda est."
Reply 471 of 1466, by SquallStrife
I haven't been able to replicate the issue, unfortunately.
Are you able to connect with other clients, like FileZilla or WinSCP? (Just wondering whether it's a server/network issue, or just with TC)
Reply 472 of 1466, by Jolaes76
Yes, Filezilla and Winscp work fine. Total Cmd would be more convenient, that's all.
Reply 473 of 1466, by SquallStrife
I did a little digging, here's what I found:
- There is a version of the plugin that doesn't rely on external DLLs: https://cristianadam.eu/20150927/total-commander-and-sftp/
- Connecting to SFTP doesn't use TC's FTP functionality under the "Net" menu. (That uses FTPS, which is different to SFTP. Confusing yes? 😵 )
- Instead, on the drop-list that has your drives listed, pick "Network Neighbourhood", then double-click "Secure FTP". Create a new "folder" with F7, give it a name, then a dialog will pop up for connection settings.
Reply 474 of 1466, by Jolaes76
Thanks for the hints, I am still trying to make a connection with this method.
Right now I am stuck before the first handshake, I mean I get a "failed to connect to the given server" error.
My firewalls (both software and the one on the router) are OFF, so it should work. I am still investigating. I will try accessing other sftp servers.
Reply 475 of 1466, by SquallStrife
You're not putting the sftp:// in front of the address? That's just there to indicate which protocol to use.
I got it working in TC using these settings (obviously use your own username/password)
Edit: I just changed the logon-generation page to make it a bit clearer. 😀
Reply 477 of 1466, by Jolaes76
😵 Yep, this was the problem. I mean I connected to other sites in the meantime and the "sftp://" prefix had to be deleted as well. Thanks !
Reply 478 of 1466, by SquallStrife
I went with number two, I created a little star to put next to moderators' names.
E.g. http://www.vogonsdrivers.com/getfile.php?fileid=541
It's pink because of my un-leet photoshop skills, and was my lame attempt to colour it the same as the buttons on the forum. 😜
Reply 479 of 1466, by Malvineous
Any idea when new users will be able to start uploading files? I'm collecting them like crazy at the moment but have nowhere to put them.
Maybe we can get a hosting system set up on the Vogonswiki server if there are issues preventing Vogonsdrivers from working properly?
