VOGONS Driver Library
Reply 560 of 1466, by appiah4
Could I please have an account?
I have drivers I would like to contribute.
Reply 561 of 1466, by gerwin
SquallStrife
It is not really important, but the text line-height is not entirely proper. Text can overlap the text below it. It has always been that way. I think if you just remove line-height styles it should correct itself. Using Firefox here.
    23.18 KiB
Reply 562 of 1466, by Paralel
SiliconSoft SoundJr. Windows 3.1/95 Driver & Test Program
Drivers provided by the developer for the SoundJr. parallel port sound hardware for Windows 3.1/95, as well as a test program for determining if the hardware is installed and functioning correctly
    SoundJr.zip
    569.05 KiB
    197 downloads
Reply 563 of 1466, by 33oldnew
Hi
1. SOUND UTILITY for COVOX - Package used to adapt the games and other software to work with analog-to-digital COVOX. Allows multiple programs to play a sound using the COVOX.
2. Window Sound Driver for COVOX on LPT1
Use with care, preferably on the copies
The description is in the Polish language, but that's not a problem to use the translator.
Covox-18P.zip
23.28 KiB
196 downloads
From 90's years
Reply 564 of 1466, by xjas
Hey Squall,
I PMed you a while ago - could I get upload access to Vogonsdrivers? I have some sound card drivers (ATI Stereo F/X CD, rescued off my own floppies, currently not extant on the internet(!)) and a few other things (VR stuff, "lost" video utility for the original Asus eeePC models, etc.) I'd like to share.
On that note, all the early beta drivers that support the Oculus Rift DK1 have been wiped off Oculus' website (as I feared would happen!) I have my own archive of a lot of these drivers, exactly as downloaded from Oculus (installer untouched.) Should they go up on Vogonsdrivers? The DK1 isn't compatible with anything they currently host on their website, so if you're trying to run one you need these.
Reply 565 of 1466, by Drill_Sergeant_CH
Hey Guys, hi Squall. Need access for driver-cd upload:
I purchased on Ebay a NEW Microsoft SideWinder ForceFeedback2 Joystick with original packaging (incl. 2 CD-Roms with drivers!). I would like to upload those two CD-Roms (ISO-Files) for the vogons-library.
http://imageshack.com/a/img922/89/aDGgRW.jpg
*** UPDATE: ***
Link for Download: https://drive.google.com/open?id=0B3X30i7OCuH … aUdUV3NJaUlsbWc
so long
Drill_Sergeant_CH
Reply 567 of 1466, by Stiletto
Drill_Sergeant_CH wrote:
#push
Send SquallStrife a PM, he'd the only person who can give you access.
do the Fandango!" - Queen
Stiletto
Reply 568 of 1466, by Anapan
I just received a Makopad PC (SV-234) in the mail - it's even better than I'd read about - Here's the 95/98 driver and an image:
http://anapan.525lines.moe/sv234.exe
I had to get the driver from Archive.org - I found a directory listing where most Interact accessories' drivers can be downloaded:
https://web.archive.org/web/*/http://www.inte … com:80/dlfiles/*
The driver reports it as Interact PC PowerPad Pro 6-button, tho the driver seems to be different from the one already archived (it is the same driver by file-size that came on the disk which had bit-rotted).
Reply 569 of 1466, by appiah4
I've come to be in posession of an AWE64 Value Installation CD. I know the Gold CD is on Vogonsdrivers (and actually works with the Value card) but if anyone would want me to upload it somewhere let me know.
EDIT: You can download it here: https://drive.google.com/open?id=1qYExwo_A-25 … TSxpZQMXXPWyzJY
And I wish Squallfire would give me an account 🙁 He doesn't read his messages on Vogons it seems..
Reply 573 of 1466, by firage
The final DOS software releases for a classic Thrustmaster joystick lineup.
F22_209.zip
1.38 MiB
202 downloads
Thrustmaster F-22 Pro software v1.09 with the v2.09 RT200 update.
FLCS_518.zip
863.68 KiB
195 downloads
Thrustmaster F-16 FLCS software v4.00 with the v5.18 RT200 update. (If the FLCS is used together with the TQS, use the TQS software instead.)
TQS_518.zip
870.66 KiB
197 downloads
Thrustmaster F-16 TQS software v4.00 with the v5.18 RT200 update. (If the TQS is used together with the F-22 Pro, use the F-22 software instead.)
WCS2_813.zip
777.77 KiB
194 downloads
Thrustmaster WCS Mark II software v8.10 with the v8.13 RT200 update. (If the WCS is used together with the FLCS or F-22 Pro, use their software instead.)
My big-red-switch 486
Reply 576 of 1466, by blurks
I uploaded the driver files for the VideoLogic DVD-Player (MPEG2 decoder card for PCI bus).
This includes the drivers, the setup and the readme files from the attached disc but DOES NOT include the DVD Player application as I am not aware of its current copyright status.
http://www60.zippyshare.com/v/6I4wWmrM/file.html
Reply 578 of 1466, by Stiletto
Murugan wrote:
Is the library down?
Seems that way.
http://downforeveryoneorjustme.com/vogonsdrivers.com
Stiletto
Reply 579 of 1466, by Stiletto
Stiletto wrote:
Seems that way.
Back up, BTW.
Stiletto
