VOGONS Driver Library
Reply 621 of 1466, by TigerBill
debs3759 wrote:
Sorry, I just checked and none of the files you need are in the archive 🙁
Debs3759, you might be interested in what someone found when I asked in a new thread about BIOS chips for the IC7.
cyclone3d wrote:
Looks like the download link for the ftp site is still working. […]
TigerBill wrote:
jesolo wrote:
Try this link: http://abit.ws/page/en
As discussed over in the Driver Library thread, while that webpage still exists it seems all the file links are dead.
Here is a direct link to the latest BIOS.
http://abit.ws/ftp@ftp.abit.com.tw/pub/downlo … max3/ic7p18.exe
-Accuracy by volume!!!
Reply 622 of 1466, by oeuvre
Any interest in this Dell Dimension Resource CD? It's from 1999. Believe it came with my father's Dell Dimension XPS T550. Ripping an ISO of it right now
    343.07 KiB
Reply 623 of 1466, by Roman555
I tried to find a new bios for my mainboard MS-6168 v2 (Packard Bell Bora Pro), but, with a great difficulties, found only older ones.
So I saved and uploaded my bios AMI A6168P2 V5.00 05302000
If you really know what you are going to do with it get here
Old AMI ones:
A6168P2 V2.96
A6168P2 V3.1
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 624 of 1466, by appiah4
Interested! Also interested in all Optiplex and Dimension XPS D CDs of the 1997-2000 era.
Reply 626 of 1466, by Justin1091
For the driver library I have a Voodoo3 3500 TV driver disc, multi-lingual version 1.2 This one is newer than the 1.1 currently provided there.
From the readme:
Voodoo3 3500TV Windows(r) 9x Driver Kit
Voodoo3(tm) Driver kit: 1.02.18
Voodoo3 Win9x 2D/3D Display Drivers: 4.11.01.1204
Voodoo3 Glide(tm) 2.X Driver: 2.61.00.0439
Voodoo3 Glide 3.X Driver: 3.10.00.0439
Voodoo3 3dfx Tools: Version 1.5.0.44
OpenGL(r) Driver Version: 1.0.0.0444 ICD
Also have a Creative 3D Blaster Banshee driver disc and a Creative SoundBlaster Live! Value driver disc.
Interested?
Reply 627 of 1466, by Repo Man11
I think this would be a good candidate: if you have a Maxtor branded Promise PCI ATA 100 or 133, the Promise drivers won't work, and the Maxtor ones are now hard to find. I just found a site that is hosting them, and I just used them to install Win XP on an Asus TXP4 with one of these cards (so I know they are good), combined with a PATA to SATA adapter to control a 500 gigabyte seagate SATA drive.
https://www.touslesdrivers.com/index.php?v_pa … 23&v_code=16384 Only on server 2 and 3, the Seagate link is 404.
Reply 628 of 1466, by appiah4
oeuvre wrote:
This is very much appreciated, thank you! My XPS D333 is most pleased with it.
Reply 629 of 1466, by gerwin
I uploaded about a dozen old nVidia Detonator/Forceware Drivers, as supplied by Nemo1985. For Windows 9X, dated 2001 to 2005. Also cleaned up the nVidia section a bit by renaming entries to make them sort more logically.
http://www.vogonsdrivers.com/index.php?catid=24
I read somewhere that in Oct 2003 'Detonator' got renamed to 'Forceware', just to make things confusing.
PS. I prefer people taking care of their own uploads, because you know; it takes time and effort. Though it seems the handing out of vogonsdrivers credentials has stalled.
Reply 630 of 1466, by debs3759
SquallStrife - I see you have been online at least once since I messaged you. Any chance of an account on vogonsdrivers, so I can upload any drivers I come across or already have that are not there yet?
Reply 631 of 1466, by Justin1091
Justin1091 wrote:
For the driver library I have a Voodoo3 3500 TV driver disc, multi-lingual version 1.2 This one is newer than the 1.1 currently […]
From the readme:
Interested?
Hmm, I expected some interest in these drivers since there are a lot of similar drivers out there with quite some downloads. Guess there are enough of these types of drivers on there then!
Reply 633 of 1466, by Paralel
Cyrix - Cx486SRx2/Cx486DRx2 Utility Disk, Version 3.30
This is the latest version of this software I have seen anywhere, so I thought I should upload it here in case anyone can use it.
    Cx486DRx2v33.zip
    480.91 KiB
    79 downloads
Reply 634 of 1466, by Hamby
I recently dug up my Gravis Stinger gamepads (serial port joysticks) and the driver CDs that came with them.
I did a brief search, and saw where someone uploaded the Gravis xperience drivers, but didn't see anything about the Stinger.
Should I rip and upload the driver CDs, or is it such an esoteric joystick that there's no point, since the xperience drivers are already up?
Reply 635 of 1466, by SquallStrife
Yes, life has been a bit all over the place for me lately.
I've just finished streamlining the account creation process for myself, until 20 minutes ago, creating an account meant SSH'ing to the VPS and manually running a SQL script in /usr/bin/mysql.
Now I can do it thru an admin-only web interface in one click. Phew.
A few general notes to the dozen or so new people I added just now:
- Your passwords are CaSe SeNsiTiVE. If you copy-paste and it doesn't work, check for leading or trailing spaces/line breaks that your highlight may have inadvertently picked up.
- Read the "FTP Upload Guide" PDF. Yes, it predates the changeover to SFTP, but it still outlines the steps for post-processing your files after uploading them via SFTP. I only mention this because it's caught out one of our members big time in the past, and data was lost.
- Informative but succinct names, and as much details as you can provide in the description. A copy+paste of the readme.txt or similar is perfect. Some kind of image or disk photo is gravy!!
Great examples:
http://www.vogonsdrivers.com/getfile.php?fileid=548
http://www.vogonsdrivers.com/getfile.php?fileid=880
Good examples:
http://www.vogonsdrivers.com/getfile.php?fileid=781
http://www.vogonsdrivers.com/getfile.php?fileid=323
Average examples:
http://www.vogonsdrivers.com/getfile.php?fileid=1019
http://www.vogonsdrivers.com/getfile.php?fileid=1317
Bad examples **
http://www.vogonsdrivers.com/getfile.php?fileid=35
http://www.vogonsdrivers.com/getfile.php?fileid=43
** In defence of these entries, they were created when the site was still being developed, and were copy+pasted by me from the original thread on here. It's not Malik's fault at all, just legacy data. I've linked them here as an example of what we should avoid doing going forward.
Reply 636 of 1466, by SquallStrife
gerwin wrote:
SquallStrife
It is not really important, but the text line-height is not entirely proper. Text can overlap the text below it. It has always been that way. I think if you just remove line-height styles it should correct itself. Using Firefox here.
I've implemented this, and it's fixed a lot of the layout problems I was seeing about the place. Cheers mate!
xjas wrote:
Hey Squall,
I PMed you a while ago - could I get upload access to Vogonsdrivers
PM incoming.
Drill_Sergeant_CH wrote:
Hey Guys, hi Squall. Need access for driver-cd upload: I purchased on Ebay a NEW Microsoft SideWinder ForceFeedback2 Joystick wi […]
I purchased on Ebay a NEW Microsoft SideWinder ForceFeedback2 Joystick with original packaging (incl. 2 CD-Roms with drivers!). I would like to upload those two CD-Roms (ISO-Files) for the vogons-library.
http://imageshack.com/a/img922/89/aDGgRW.jpg
*** UPDATE: ***
Link for Download: https://drive.google.com/open?id=0B3X30i7OCuH … aUdUV3NJaUlsbWc
so long
Drill_Sergeant_CH
Hi there. As per the OP, I'm only comfortable creating accounts for established members.
I'm sorry that I didn't get to respond to your post sooner, but I would be happy to upload the files on your behalf.
I tried clicking your Google Drive link, but it says the folder has been moved to Trash? If you restore the folder, I can do the download in the next few days.
Sorry again for the inconvenience.
markot wrote:
Abit Rev. LX-1.31 motherboard drivers from original disc (7-zipped ISO): https://ufile.io/1fau7
Abit KT-1.10M motherboard drivers from original disc (7-zipped ISO): https://ufile.io/t8kvy
markot wrote:
MVGA-I740A MVGA-I740AG MVGA-S6326AG MVGA-3DP2A MVGA-3DP2A8M PV-BT848 PV-BT848P MVGA-CL5446P MVGA-CL5465A MVGA-CL5465AN MVGA-CL54 […]
MVGA-I740A
MVGA-I740AG
MVGA-S6326AG
MVGA-3DP2A
MVGA-3DP2A8M
PV-BT848
PV-BT848P
MVGA-CL5446P
MVGA-CL5465A
MVGA-CL5465AN
MVGA-CL5465P
Different MVGA video card drivers from original disc: https://ufile.io/kt8ok
markot wrote:
Drivers for Asus 440BX/440ZX AGPset motherboard:
https://ufile.io/apn0u
Markot, these posts are from January, and I created your account in February. I can see that you've uploaded some other MVGA related stuff since then, were you having trouble with the items I've quoted here?
Let me know if I can be of any help.
Outtheredude wrote:
Hello everyone! […]
Hello everyone!
This is my very first time in this section of the forum here. I'd like to be able to post a set of nVidia graphics drivers, currently unavailable in the driver archive here, for Windows 9x-xp. They are the following:
nVidia Detonator (v56.64) (9x-me) (International), 14,642KB
nVidia Detonator (v56.64) (2k-xp) (International), 14,907KB
It looks like we do have the 9x version of 56.64: http://www.vogonsdrivers.com/getfile.php?fileid=1410
But if you've got the 2K/XP package then feel free to upload it to the archive. PM incoming.
Yeah man, go for it!
Love your avatar, btw! I had a lot of fun making that image all that time ago.
Reply 637 of 1466, by SquallStrife
I just uploaded 17 files from various contributors in the thread. That should bring everything up to date.
Reply 638 of 1466, by Stiletto
There were a few mentions of people wanting to upload to "VOGONSDrivers"/"Vogons Drivers" in other threads, I'll see if I can track them down.
This if you want to check on the first spelling: search.php?keywords=vogonsdrivers
do the Fandango!" - Queen
Stiletto
Reply 639 of 1466, by peido
I've uploaded the 'Toshiba: Tools & Utilities CD-ROM: Tecra 520 / 530CDT' (https://www.dropbox.com/s/l44otimkeaoja0z/Tos … CDT.iso.7z?dl=0) for the thread Toshiba Tecra recovery CD?. I could upload the CD-ROM to Vogons Drivers, but I don't have permissions.
I've also uploaded an image I've made of the boot diskette that came with my Tecra 520 CDT (an error occurred while trying to read the file IO.SYS in the diskette), but it's not an original diskette and I really don't know if it isn't just a normal Windows boot disk (more information about it, check the mentioned thread in the paragraph above).
If you can, it might help someone in the future, thank you.
