First post, by Sadist boar
There are two ways to fix Tower Assault crash in DOSbox 0.74:
1. Disable EMS, XMS and UMB.
OR:
2. Type "ver 6.00" to tell Tower Assault that DOS version.
In both cases, use the installer to disable sound.
I got both basic Alien Breed and Tower Assault from old-games.ru, though GOG has them for sale.
Sad fat people are never good at using complex programs.
Reply 2 of 13, by Sadist boar
Why move? It's not a help request, it's a tip to others who might have the same issue 😐
Reply 4 of 13, by Sadist boar
I thought games/apps is for questions, GUIDE being for fixes.
Reply 6 of 13, by Sadist boar
Done, posted an entry, only with the easier of the two fixes.
Reply 7 of 13, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Is "ver 6.00" intended to change the version of DOS that DOSBox reports? If so, I don't think that works; the command should be "ver set 6 0". Doesn't appear to be necessary in any case...
Also, disabling sound is not necessary to get the game working in DOSBox, it does work with sound. However, with SB sound there is DMA wrapping causing an error exit in 0.74, so you could use 0.73 or an SVN build to play with SB sound. There is also an option for GUS sound, but it seems flaky in my attempts to get it to work.
Reply 8 of 13, by Sadist boar
I'm on DOSbox 0.74 official... oh, just checked, still reports dos 5. Well, I'm uncertain then...
Another fix is to disable EMS+XMS+UMB, but that's probably not recommended.
I have trouble with dos 5 reported even without sound. It's 7-x64.
Reply 9 of 13, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Works fine here in 0.74 with default settings when the game is configured for no sound, but has the problem with DMA wrapping when using SB sound. Disabling XMS/EMS/UMB does not appear to help with the DMA wrapping, nor does loadfix. But, again, The error exit for DMA wrapping is specific to 0.74, and does not exist in 0.73 or SVN builds.
Reply 10 of 13, by Sadist boar
Maybe I should try using the CD versions of both AB and TA? Maybe those would have it fixed?
Reply 11 of 13, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
The problem is fixed in current code (that's what SVN stands for) or dosbox 0.73. Meaning that if you want to play it with sound get an SVN build or version 0.73.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
