DOSBox-X branch
Here you can discuss the development of patches.
Re: DOSBox-X branch
Postby pantercat » 2019-11-02 @ 10:45
Hi, still having same SM bug with 0.82.23 :( at least on my system: Debian x64 and dosbox-x compiled with ./build-debug
sm segment:offset af -> byte becomes 00
sm segment:offset bf -> byte becomes BF (OK)
sm segment:offset cf -> byte becomes 00
sm segment:offset df -> byte becomes 00
sm segment:offset ef -> byte becomes EF (OK)
sm segment:offset ff -> byte becomes FF (OK)
Same behaviour with "sm segment offset" syntax.
If you need more details or something you can ask, or if I can do something for fixing it.
Regards.
pantercat
Re: DOSBox-X branch
Postby hail-to-the-ryzen » 2019-11-29 @ 06:45
It may not be reproducible, but where a large time delay occurs at startup (such as loading cd audio), then sometimes movement of the parent window before the shell loads will lead to a sudden exit.
hail-to-the-ryzen
Re: DOSBox-X branch
Postby pantercat » 2019-12-04 @ 12:39
Well, I've manage to locate where the problem is.
For anyone interested the following patch will let you write bytes AC, AF, CF and DF in memory.
Code: Select all
--- debug.cpp.ORIG   2019-12-01 01:27:21.000000000 +0100
+++ debug.cpp   2019-12-04 13:19:02.243257342 +0100
@@ -1330,10 +1330,6 @@
     else if (strncmp(hex, "FS", 2) == 0) { hex += 2; regval = SegValue(fs); }
     else if (strncmp(hex, "GS", 2) == 0) { hex += 2; regval = SegValue(gs); }
     else if (strncmp(hex, "SS", 2) == 0) { hex += 2; regval = SegValue(ss); }
-    else if (strncmp(hex, "AC", 2) == 0) { hex += 2; regval = GETFLAG(AC); }
-    else if (strncmp(hex, "AF", 2) == 0) { hex += 2; regval = GETFLAG(AF); }
-    else if (strncmp(hex, "CF", 2) == 0) { hex += 2; regval = GETFLAG(CF); }
-    else if (strncmp(hex, "DF", 2) == 0) { hex += 2; regval = GETFLAG(DF); }
     else if (strncmp(hex, "ID", 2) == 0) { hex += 2; regval = GETFLAG(ID); }
     else if (strncmp(hex, "IF", 2) == 0) { hex += 2; regval = GETFLAG(IF); }
     else if (strncmp(hex, "NT", 2) == 0) { hex += 2; regval = GETFLAG(NT); }
When I type "SM some:addr XX" I want to write opcode XX in memory, not 0 or 1 based on some flag value for XX=AC, AF, CF or DF.
Patch tested with last dosbox-x release: 0.82.24
Happy debugging :)
pantercat
Re: DOSBox-X branch
Postby ripsaw8080 » 2019-12-04 @ 21:30
I believe the register/flag name parsing was originally intended to be for SR only, not for SM.
Does it work to write register values into memory (e.g. SM 0000:0200 AX)? If so, it may have been intended as a feature, but the collision between flag names and hex values could have been overlooked.
User avatar
ripsaw8080
DOSBox Author
Re: DOSBox-X branch
Postby pantercat » 2019-12-05 @ 23:05
Yes, you can write register values into memory.
pantercat
Previous
Return to DOSBox Patches
Who is online
Users browsing this forum: No registered users and 2 guests
