Another 486 build.... with EISA!
Reply 60 of 97, by NJRoadfan
Well, I pin-pointed that weird SC2000 problem. It must be some random bug or hardware incompatibility since it only happens when the program is started in real mode. With EMM386 installed and the machine in V86 mode, SC2000 works fine. I still don't understand why it happens in Creative's diagnose.exe program. I might pull out the NiCE SuperEISA board again and see if the problem crops up there.
EDIT: The NiCE board seems to work fine, weird. Might want to try 8MB of memory in it though since I only put 4MB in.
Reply 61 of 97, by NJRoadfan
My hunch somehow proved correct. Swapping the keyboard controller fixed the odd behavior. Now I just need to find another chip. Anyone got a spare i8042 compatible keyboard controller laying around? 😜
Reply 62 of 97, by NJRoadfan
I'm running into some odd problems with memory speed on this board. For some reason, memory throughput numbers seem to drop a bit when L2 writeback cache is enabled in the BIOS. Below is my Speedsys and Cachechk results. Don't ask me why speedsys doesn't detect any L2 cache when the BIOS Memory Speed is set to "Fastest" (Both the Tyan and NiCE board does this). Anyone know what might cause these odd results?
L2 Writeback enabled:
                Cache/Memory Benchmark
ÚÄÄÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÄÄÄÄ¿
³ Read ³ Write ³ Move ³ Average ³
ÚÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄ´
³ Cache Level 1 ³ 94.45 MB/s³ 41.43 MB/s³ 41.13 MB/s³ 59.00 MB/s³
³ Memory ³ 31.33 MB/s³ 41.43 MB/s³ 21.60 MB/s³ 31.45 MB/s³
ÀÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄÄÙ
ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ
Cachechk results:
 CACHECHK v4 2/7/96  Copyright (c) 1995 by Ray Van Tassle. (-h for help)
CMOS reports: conv_mem= 640K, ext_mem= 11,264K, Total RAM= 11,904K
"GenuineIntel" 486 DX4 Clocked at 99.8 MHz
Reading from memory.
MegaByte#: --------- Memory Access Block sizes (KB)-----
1 2 4 8 16 32 64 128 256 512 1024 2048 4096 <-- KB
0: 11 11 11 11 11 26 26 26 26 71 -- -- -- æs/KB
1: 11 11 11 11 11 26 26 26 26 71 71 71 71 æs/KB
2 3 4 5 6 7 8 9 10 11 <--- same as above.
Extra tests----
Wrt 16 16 16 16 16 16 16 16 16 16 16 16 16<-Write mem
This machine seems to have both L1 and L2 cache. [read]
L1 cache is 16KB -- 102.5 MB/s 10.2 ns/byte (665%) (239%) 3.9 clks
L2 cache is 256KB -- 42.8 MB/s 24.5 ns/byte (277%) (100%) 9.3 clks
Main memory speed -- 15.4 MB/s 68.1 ns/byte (100%) [read] 25.9 clks
Effective RAM access time (read ) is 272ns (a RAM bank is 4 bytes wide).
Effective RAM access time (write) is 61ns (a RAM bank is 4 bytes wide).
"GenuineIntel" 486 DX4 Clocked at 99.8 MHz. Cache ENABLED.
Options: -t0
L2 Writethrough enabled:
Cachechk results:
0: 11 11 11 11 11 26 26 26 26 30 -- -- -- æs/KB
1: 11 11 11 11 11 26 26 26 26 30 30 30 30 æs/KB
Extra tests----
Wrt 24 24 24 24 24 24 24 24 24 24 24 24 24<-Write mem
L1 cache is 16KB -- 102.5 MB/s 10.2 ns/byte (280%) (238%) 3.9 clks
L2 cache is 256KB -- 42.9 MB/s 24.5 ns/byte (117%) (100%) 9.3 clks
Main memory speed -- 36.6 MB/s 28.6 ns/byte (100%) [read] 10.9 clks
Effective RAM access time (read ) is 114ns (a RAM bank is 4 bytes wide).
Effective RAM access time (write) is 92ns (a RAM bank is 4 bytes wide).
Options: -t0
³ Cache Level 1 ³ 94.45 MB/s³ 41.49 MB/s³ 41.19 MB/s³ 59.04 MB/s³
³ Memory ³ 33.51 MB/s³ 41.49 MB/s³ 22.60 MB/s³ 32.53 MB/s³
    10.07 KiB
    Tyan S1437 with L2 writeback
    10.08 KiB
    Tyan S1437 with L2 writethrough
Reply 63 of 97, by feipoa
I've noticed all sorts of weird things with cache and memory timings on SiS 486 boards. I have never found concrete answers to them, but I suspect the chipset (or BIOS) does some auto manipulation of the timings when the user manually sets speed combinations higher than the system can run.
Reply 64 of 97, by Anonymous Coward
The L2 is being detected in the graph, it's just not being reported for some strange reason. I wonder why it shows up on my board but not on yours. Maybe it's a chipset revision related issue? I'll have to test your writeback/writethrough issue too. I seem to recall getting a performance boost though. Does the BIOS have an option for tag length? If so, when it writeback mode make sure it's set to 7+1 rather than 8+0.
Reply 65 of 97, by NJRoadfan
No option for tag length on either board. Looking at the physical chips, the Tyan looks like it was produced a few months after the NiCE. Its BIOS is dated 6/1993 with chip date codes from late 1993, while the NiCE appears to be from early 1993. The cache tag setup is different between the boards, the NiCE uses 3 tag chips, while the Tyan only has space for 2 (256k only uses one tag chip on that board).
Reply 66 of 97, by Anonymous Coward
Have you tried adding the second Tag chip on your Tyan board? On second thought maybe it won't matter. I consulted with TH99, and it seems the second tag is only needed if you use 1024kb cache.
What date is given in your BIOS splash screen? Mine is 6/6/92.
Reply 67 of 97, by NJRoadfan
Both boards have the 6/6/1992 AMI Hi-Flex core. The 1993 date on the Tyan appears above the memory test count along with the board's BIOS revision. My NiCE board displays revision 1.2.1 on the same line, but with no date.
Reply 68 of 97, by Anonymous Coward
I probably already asked, but I forgot the answer. Have you tried an AMD 5x86-133 yet?
Reply 69 of 97, by NJRoadfan
I don't have one on hand.... yet.
Reply 70 of 97, by Anonymous Coward
I seem to recall a lot of older boards had compatibility issues with the IntelDX4, even with a VRM. The AMD chips were said to work better with such boards.
Reply 72 of 97, by Anonymous Coward
Can you do some benchmarks with the DX/2 66 to see if the memory scores exhibit the same problems?
What kind of DX/2 is it? A 5V model with WT cache would be preferable.
Reply 73 of 97, by NJRoadfan
A plain old stack of Intel DX2/66s, nothing special. They all came with the EISA boards (some with their warranty void if removed stickers in tact!) so I doubt they are write back chips. Heck, I didn't even know they made write back ones.
Reply 74 of 97, by Anonymous Coward
Intel's version was probably only used by OEMs, but the AMD and Cyrix writeback models were fairly common.
Reply 75 of 97, by Anonymous Coward
My Nice Super EISA board is now non-functional. I've exhausted pretty much all possibilities, and I can't revive it. I now have a Tyan S1437.
I am not impressed with the Tyan for a couple of reasons. At 33MHz, I am unable to get "FASTEST" memory settings going unless I set the cache timings to their slowest settings, which makes it slower than "FASTER" with optimal settings. I am using a 10ns tag and 15ns cache. I will try different chips later.
The DRAM interleave option in the BIOS appears to be useless. I'm not really sure what's going on. Enabling or disabling it has no effect whatsoever on memory scores, whereas on my Super EISA I could see a dramatic difference between the two. There are a few undocumented jumeprs and an empty socket on the Tyan. Maybe something else needs to be configured to get it working?
Overall build quality on the Super EISA seems to be higher overall. The only thing the Tyan has going for it is that it uses standard tag RAM chips, which doesn't help me much since memory speed is so much slower anyway.
I ran both Cyrix and AMD 5x86 chips in my tests.
Reply 76 of 97, by Anonymous Coward
L2 Writeback cache on this board appears to be somehow broken. At least according to speedsys it is slowing down memory substatially while not improving the L2 cache bandwidth.
I was able to get DRAM interleave working by disabling the WB cache. Not sure why having WB enabled was causing this. It's rather odd. But that's okay, because I set a record of 51MB/sec uncached DRAM running at 40MHz in "FASTER" mode. That's insanely good. I will try replacing the SRAM chips eventually to see if "FASTEST" is possible.
Of other note, there is an empty socket next to the cache chips. It's 22 pin. There are two 28-pin sockets for TAG ram nearby as well. I suspected that the 22-pin socket might be for a WB dirty bit since I've seen this on a number of other boards. I had a 15ns 64kx1 chip floating around so I popped it in to see if it could fix WB mode. It didn't explode, but nothing happened. It would be nice to have the manual.
Reply 77 of 97, by feipoa
51 MB/s for the DRAM - Is that the combined Speedsys speed for main memory, or just the read speed? Is that speed for the AMD X5-160 or Cyrix 5x86-120? Is the system stable using these CMOS settings? Have you been able to install Win9x without issue? What about running Quake timedemo? What is the reported speed when you disable interleave mode?
Reply 78 of 97, by Anonymous Coward
51mb/sec is the combined read/write/move speed for main memory. With interleave off I believe it was 36mb/sec. I haven't tested the system for hours on end, but I ran DOOM and GTA1 for a while. I suspect the system should be pretty stable though, because I'm using less agressive memory timings than on my Super EISA. The results were obtained with a Cyrix 5x86-120 with enhancements turned on. Combined speed with AMD 5x86 at 160 and 133 are both about 48MB/sec.
At the moment the system is kind of in pieces because I'm attempting to upgrade the cache. There are problems though. It is not letting me upgrade to 512kb or 1024kb with cache that is known to be good.
Reply 79 of 97, by feipoa
What are the symptoms? The system doesn't detect the proper amount and shows 0 cache, or 256 kb cache? Or the system does not turn on? Or turns on and beeps? Did you tune down the CMOS timings?
