D-Fend Reloaded not adding games
First post, by trebrick
so i have a few games that wont add in d-fend
i have a folder with each Leisure suit larry game and each has only a setup file. there is also a batch setup file with the option to install each game individually in dos (fig. 1)
when i try to install the games using the game install wizard, i get all the way through the setup only to type exit and have d-fend display this message "there is no new folder in the games directory from which a new game could be added"
    65.26 KiB
Reply 2 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
is not a game nor dosbox problem.
and for what it is worth. there is an edit your post button at the top right of your posts. Use that instead of double/triple posting.
Water flows down the stream
