My 3DMark01 Mega Thread
Reply 360 of 753, by kithylin
havli wrote:
3DMark 2001 loves huge and fast L2/L3 cache. Core2-based Pentium isn't a very good CPU for breaking 3DMark records. :) R9800 Pro […]
3DMark 2001 loves huge and fast L2/L3 cache. Core2-based Pentium isn't a very good CPU for breaking 3DMark records. 😀
R9800 Pro can do 30k+ and 6800 Ultra PCI-E is able to hit 60k easily... of course with very fast CPU and some LOD tweaks as well.
http://hwbot.org/submission/2456100_havli_3dm … xxl_30620_marks
http://hwbot.org/submission/2296093_havli_3dm … _mb_58409_marks
Anyway - here is a score of my lastest build:
Core2 Duo E6400 @ 2,25 GHz
Radeon 8500
1GB DDR 373 MHz
ASRock 775i65G R3.0 (i865G)
11428 points (no tweaks)
I'm not looking for just "stupid high 3dmark scores" but high scores on something that's compatible with older games to actually use the power it produces. So.. scoring high just to score high is not really of interest to me. Usable systems that I can do something with that score high on the other hand, that I'm in to.
Like sandy bridge with that pci-e card can't run win98 and my older games I like to play sometimes that don't like win XP much.
Reply 361 of 753, by BSA Starfire
MSI 915GM speedster-FA4 desktop pentium M board, 1Gb DDR 400mhz, Pentium M 740(1.73ghz, 2 meg cache, 533FSB), using the onboard intel IGP. It has a pci-e slot so will give it a whirl with a proper graphics card when i have time.
file.php?mode=view&id=17241&sid=ede4a26daacf619b3758c28a5d68249a
    210.47 KiB
Reply 362 of 753, by havli
Benchmarking and playing games are two different things. To get a competitive score in 3DMark, the fastest CPU is a must-have.
For gaming it depends on the game - for example Mafia: The city of Lost Heaven with unlimited visibility mod doesn't run that good even with 5GHz i5, regardless of the videocard.
But I agree - most games don't need CPU overkill like this.
Reply 363 of 753, by Stermy57
Oh my god!
I have tried it!
I remember that with unlimited visibility mod is better to use nvidia card 😉
Reply 364 of 753, by Standard Def Steve
S939 Athlon X2 3800+ and a GeForce GTX 560.
I'm impressed with NVIDIA's drivers. Even the newer ones (like 331.65, which I used here) seem to be quite efficient and have low CPU overhead.
Ten Gigahertz
5 Groovy GHz: Ryzen 9 5900X | GTX 1080 Ti | 64GB DDR4-3600 | 2TB NVMe, 8TB HDD | Win 10
5 Troll GHz: AMD FX-8350 | Radeon R9 Fury | 16GB DDR3-1866 | 500GB SSD, 2TB HDD | Win 8.1
Reply 365 of 753, by kithylin
Now you're going to make me go benchmark my recently tuned 939 system tomorrow 😁 I was going to and post it anyway, but now I have a reason to I suppose, see how it compares to yours. 😀
Reply 367 of 753, by BSA Starfire
file.php?mode=view&id=17387&sid=970a0a4418b8d6c2a98dc3e23265f0c3
Added a geforce 6800 to the above Pentium M system, quite the improvement!
    292.58 KiB
Reply 368 of 753, by BSA Starfire
file.php?mode=view&id=17388&sid=970a0a4418b8d6c2a98dc3e23265f0c3
Even better when I remember to turn off BOINC! 🤣
    291.3 KiB
Reply 369 of 753, by Darkman
the Dual Tualatin board is up and running
Gigabyte GA-6VTXD (VIA Apollo 133T chipset)
2x Pentium III-S 1.4Ghz Tualatins (512k cache)
1GB SDRAM PC133
300GB Seagate Cheetah drive on an Adaptec 2100S card.
Voodoo 5500 AGP
Sound Blaster Audigy (in Win2k)
Aureal Vortex2 SQ2500 (in Win98SE)
Intel Pro 100/S
benchmark done in Windows 2000
compared to the Athlon 1400 ,this is a lower result (3DMark01 is not SMP enabled after all) , however in games Im generally seeing similar or minor improvements in the frame rate (Return to Castle Wolfenstein for instacne gains about 5 frames over the Athlon)il I imagine due to the OS offloading the background tasts to the 2nd CPU
Reply 370 of 753, by Skyscraper
Here are some scores with an overclocked quad core socket 771 Xeon X5460.
I think the scores are a bit low because of the not totally flawless chipset nForce 780i.
Geforce GTX 285, close to 80K
Geforce GTX 580, over 80k 😀
Geforce GTX 580 SLI, a few more points!
Main PC: Dual Xeon X5690@4.6ghz, Evga - SR-2, 48gb memory, Intel X25-M g2 SSD and a Nvidia GTX 980 ti.
Retro PC #3: K6-2 450@500mhz, PC-Chips m577, 256mb sdram, AWE64 and a Voodoo Banshee.
Reply 371 of 753, by kithylin
Skyscraper, could you please tell me the exact model # and if possible, revision # of the motherboard you used with that cpu? No one online seems to have much info on the nvidia 700 series of chipsets in conjunction with those 771 quads on the internet, and it's a project I was hoping to assemble myself some day in the future.
Reply 372 of 753, by Skyscraper
XFX nForce 780i SLI
MB-N780-ISH9 V1.5 W07/08
I think this is the model number? MB-N780-ISH9
The revison is at least V1.5
I think the model is also called XFX nForce 780i Tri SLI FTW
Im sure there are more numbers but its hard to see with my pocket light 😁
Reply 373 of 753, by kithylin
Skyscraper wrote:
XFX nForce 780i SLI MB-N780-ISH9 V1.5 W07/08 […]
XFX nForce 780i SLI
I this is the model number? MB-N780-ISH9
I thinks the model is also called XFX NForce 780i Tri SLI FTW
That's fine already and more than enough, thank you 😀
Reply 376 of 753, by Standard Def Steve
Skyscraper wrote:
Here are some scores with an overclocked quad core socket 771 Xeon X5460. I think the scores are a bit low because of the not to […]
Holy hell man! 😳
You outscored my 4.3GHz i7-4930k. It only gets 82500 with a GTX 970.
Now I want to install WinXP just to beat your score. You're lucky I'm a lazy bum. 🤣
edit: no WinXP drivers for the GTX 970. There goes that idea.
Ten Gigahertz
Reply 377 of 753, by kithylin
Standard Def Steve wrote:
Holy hell man! 8-O You outscored my 4.3GHz i7-4930k. It only gets 82500 with a GTX 970. Now I want to install WinXP just to b […]
Holy hell man! 😳
Yep sadly nvidia has officially killed off WindowsXP support starting with the 900 series of cards. I looked in their drivers and saw that a few days ago. Sort of a milestone in nvidia history, I think.
Reply 378 of 753, by Standard Def Steve
Latest dumpster find:
An adorable USFF Optiplex 780 in perfect condition. It came with:
-Core 2 Duo E7500 (2.93GHz, 1066FSB, 3MB L3)
-4GB DDR3-1333, running at 1066MHz CL7
-320GB HDD
-Q45 chipset w/ GMA X4500HD IGP
-DisplayPort and eSATA
Unfortunately, there's no PCIe expansion so I can't really put the pedal to the metal, but it's a zippy little Internet machine and has no problem playing 60fps 1080p YouTube video. Completely silent, too. Here's the 3DMark01 score
Ten Gigahertz
Reply 379 of 753, by Skyscraper
Holy hell man! 😳
Well my Xeon Frankenstein system is totally bottlenecked by system memory bandwidth at this point so if you upgrade to a GTX 980 you will beat my score even when running Windows 8 🤣 .
3dmark 03 isnt as badly bottlenecked by CPU and memory speed as 3dmark 2001 so there we see better scaling.
The CPU scores are a bit strange so perhaps the CPU was throttling from heat. I diddnt really check the temps (Zalman air cooling) as it was a quick and dirty OC before I settled for a nice and cool 4037 MHz at default voltage and installed Windows 7.
3dmark 03. Xeon X5460@4400 with GTX 285.
3dmark 03. Xeon X5460@4400 with GTX 580. Not bottlenecked very much.
3dmark 03. Xeon X5460@4400 with GTX 580 SLI. Bottlenecked.
The reason I want this system to run cool is that the board has some bad caps right by the very hot running northbridge. They were bad when I got the board and have not gotten worse so I have ignored them so far but I am not overvolting the northbridge other than for short benchmark sessions.
