My 3DMark01 Mega Thread
Reply 700 of 801, by appiah4
Two results from me:
GeForce 4600Ti AGP on Socket 754 Athlon64 3200+:
1.03 MiB
Radeon X800XT PE AGP on Socket 754 Athlon64 3200+:
1.62 MiB
I will aso post a Radeon X1950PRO AGP on Socket 754 Athlon64 3200+ later today.
Reply 701 of 801, by Baoran
What is the earliest Geforce card that can go through all the tests in 3dMark01?
My Geforce 2 MX skips at least the nature test so I am also interested in what exactly is missing from earlier geforce cards that makes it skip it.
Reply 702 of 801, by noshutdown
nature requires dx8 support, and gf3 is the earliest nvidia card to support that.
Reply 703 of 801, by appiah4
As promised..
278.1 KiB
Reply 704 of 801, by Kamerat
A result from way back, first time I passed 40k.
40392 3D marks with this setup:
AMD Athlon 64 FX55 @ 3,27GHz/1,87V/311MHz HTT/3x LDT, MSI K8N Neo2, 2x 256MB Corsair XMS3500 272MHz/2-2-2-5/3,7V, ATi Radeon X800 Pro @ 16 pipes 684MHz/651MHz 2,07V/2,17V (GPU is 2,03V under load, feeding whole card with 12V+). CPU cooled by Prometeia Mach II R404a, X800 Pro water cooled. Drivers: Catalyst 4.12, NVIDIA nForce 5.10, DirectX 8.1.
And a result from my older 754 rig, same card at default XT PE clocks
31018 3D marks with this setup:
AMD Athlon 64 3400+ @ 2,83GHz/1,95V/283MHz HTT/3x LDT, Gigabyte K8NS, 1x 512MB OCZ EB PC3200 236MHz/3-2-2-5/3,75V, ATi Radeon X800 Pro @ XT PE and default XT PE clocks. CPU cooled by Prometeia Mach II R404a, X800 Pro default cooling.
YouTube channel
Reply 705 of 801, by appiah4
That's 50% higher than my build, with a faster graphics card.. *smh* Yet the score I have looks like it's right and yours is abnormally high for an X800 Series card 30,000 with S754 - really? How? Is it the CPU overclock? I'll repeat testing with a 3700+ soon, let's see how much it improves my score..
Reply 706 of 801, by Baoran
3dmark01 is very much cpu limited. Basically cpu is everything, You could probably double or more your x1950pro score by having faster cpu.
Reply 707 of 801, by appiah4
I did not get a boost to anything even close to that.
1.66 MiB
Not sure if something's wrong with my system or the 30,000pts referred to above has some kind of extreme overclocking in the system..
Reply 708 of 801, by Baoran
appiah4 wrote:
I did not get a boost to anything even close to that. […]
Going from 3200+ to 3700+ is going from 2Ghz to 2.2Ghz. That is only 10% speed increase. You need to go much faster. His cpu is probably 50% faster than yours. if you don't want to overclock perhaps core 2 duo motherboard that has agp slot?
Reply 709 of 801, by appiah4
Baoran wrote:
Actually 3700+ is 2.4% so it's 20% faster but yeah, it resulted in roughly 10% higher points. But doing the math, to get 50% higher points I would need - what, a 4GHz Athlon64? I really can't understand how he got 30,000 points.. Probably the 250MHz FSB has something to do with it - that is 25% faster ram and a 25% overclocked AGP port.. I'm sure memory bandwidth plays a big part in these DDR systems.
Regardless, my scores seem to be more or less in line with what people seemed to be getting at the time.
Reply 710 of 801, by SPBHM
he is running a pretty nice CPU/ram OC
but I also would say to check the driver version, it can have a significant effect on 3dmark 2001 with older cards.
Reply 711 of 801, by Kamerat
Consider this as competitive scores, not only did we overclock but also tweak the driver settings and other stuff. At this time we had one of the worlds best overclockers on our team, the same guy I bought all my phase change coolers from. He actually built his own cascaded phase change coolers.
YouTube channel
Reply 712 of 801, by Baoran
Something that tells alot about the cpu bottleneck is that my geforce 7800gs gets 25000 in 3dmark01se on my 2.6Ghz Athlon64 even though it is much slower card than x1950pro.
Reply 713 of 801, by appiah4
2.6GHz is about 10% faster than what I have, and 25,000 is about 10% higher than what I get. That's probably 5% due to clockspeed and 5% due to dual channel memory (3800+ has to be S939 I presume). Yeah, with AGP you get some real bottlenecking beyond the Radeon R300 series GPUs unless you do some heavy overclocking.
That said, 3DMark2001SE is a terrible gauge of game experience for anything that uses a decent amount of shaders, bottlenecking is less of an issue in games like Doom 3 and Halo:CE for example.
Reply 714 of 801, by Baoran
You are right. 3dmark03 is much more gpu heavy benchmark than 3dmark01. It doesn't really matter that mine was dual core FX-60 because I tested in win98 and it ignores the second core.
You could make 3dmark01 more gpu heavy if you test it with 1600x1200 and 4xAA but you couldn't compare it to others in this thread then.
Reply 715 of 801, by Kamerat
X800XL and Pentium E6500K @ default (CPU FSB and multiplier fails to detect correctly) on an Asus P5VD2-VM SE running Windows 98SE:
104.28 KiB
YouTube channel
Reply 716 of 801, by Standard Def Steve
Lenovo Thinkcenter M93p
i7-4790 (non-K)
16GB of cheap CL11-11-11-28 DDR3-1600
GTX 980
Win 8.1 Pro
Not bad for a stodgy business machine eh?
Reply 717 of 801, by tomoa
Board: Asrock 775i65G R3.0
Processor: Pentium E5800 3.2 GHz
Memory: Kingston KHX3200ULK2/512 (2x256 MB) 2-2-2-5
VGA: Geforce 6800 GT AGP DDR3 350/500 MHz
Windows 98 SE, Forceware 81.98
3DMark2001 SE: 29072
3DMark2000: 39879
3DMark99: 38829
OVERCLOCKED
Processor: Pentium E5800 3.2 GHz@4.3 GHz (15x288 MHz) (1.45v-1.5v VID5+VSS)
Memory: Kingston KHX3200ULK2/512 (2x256 MB) 200@230 MHz 2-3-3-6
VGA: Geforce 7900 GS AGP DDR3 450/660@550/750 MHz
Windows 98 SE, Forceware 82.69 not official.
3DMark2001 SE: 40865
Poland , http://komputery-retro.ddns.net/ http://komputery-retro.ddns.net/blog/ , I like old games and old computers 😀
Reply 718 of 801, by Carlos S. M.
haven't posted here for long time, but there are some scores i tested in a socket 939 system, i recently built the system with the following specs:
AMD Athlon 64 X2 4200+ 2.2 GHz (later replaced with a 4400+, stock clocks)
2 GB DDR 400 CL3
Gigabyte GA-K8N-SLI
nVidia Quadro FX 3500 (stock clocks)
2x 160 GB Seagate Barracuda 7200.9 SATA drives
Windows 2000 Professional SP4 with updates and BWC's extended kernel
Replaced later the X2 4200+ with an X2 4400+ (same clocks, but larger cache) and the score improved by nearly 2k, both Athlons are Toledo (rev E6)
Athlon 64 X2 4200+ score: 23523
Athlon 64 X2 4400+ score: 25287
    202.46 KiB
    132.29 KiB
Reply 719 of 801, by Carlos S. M.
Also benched my VIA C3 system (VIA EPIA M1000) with both the onboard S3 UniChrome (VIA CLE266) and a Radeon 9000 PRO PCI (Hercules)
Specs:
VIA C3 1 GHz (Nehemiah)
1 GB DDR 266
VIA EPIA M1000 (VIA CLE266 + VT8235)
S3 UniChrome/ATI Radeon 9000 Pro PCI
80 GB WD HDD
Windows XP Pro SP3
    182.94 KiB
    VIA C3 1 GHz + VIA CLE266 onboard Unichrome
