First post, by OSH
Well, I'm a little bit frustrated.
1. I've made imagefile using imgmake test.img -t hd_2gig -nofs -bat
2. I've formatted this image using format c: /s
3. I'm trying to mount this under DOSBOX using imgmount d test.img -t hdd -size 512,63,64,1023
4. I've got a message "can't create drive from file".
What I did wrong? I've remembered, I was able to mount su8ch image under DOSBOX, and after this copying a files on this image under DOSBOX, but now I can't. Why?
Reply 3 of 13, by bloodbat
Which file system did you format the image with prior to adding files?
Also, is the path to your image file set correctly?
You're not trying to mount it to an already used drive letter, right?
Reply 5 of 13, by OSH
Well - I've formatted it using Windows95 startup disk
Yes, is correctly set.
No, I'm not.
When you try to mount the image there's probably a message in the Status Window explaining what's wrong.
Using partition 0 on drive: skipping 63 sectors
IDE: index -1 slave=0
Reply 8 of 13, by Jorpho
OSH wrote:
Of course. I did everything, what was described in DosFreak's, and dada's description...
Which description are you referring to? What partitioning tool did you use?
Patch: Imgmake - creates floppy or harddisk images suggests "imgmake c:\harddisk_2gb.img -t hd_2gig" requires no formatting at all.
For that matter:
Don't you have to mount the image before you can format it..?
Reply 9 of 13, by OSH
this: Windows 9x DOSBox Guide (Not officially supported)
and this: Guide - Windows 95 on DOSBox 0.74
Image was partitioned with fdisk from Windows95 start disk.
Of course!!! otherwise I couldn't format it! Really, I can't imagine, how I can format image without mounting it.
Reply 10 of 13, by Jorpho
Well, what command are you using to mount the image before you run fdisk, then?
Also, if you're using fdisk from a later version of Windows 95, you should probably make sure you're not formatting the disk as FAT32. (You have to answer "no" when asked if you want to enable large disk support.)
Reply 12 of 13, by DepthsDoes
cd winent1
(Windows 3.1 Entertainment Pack 1)
imgmount A: \disk01.img -t floppy
Can't create drive from file.
E:\>
