Upgrading a 386SX - some advice!
Reply 60 of 69, by Anonymous Coward
Can you give other examples of boards that can use your upgrade module?
Reply 61 of 69, by galanopu
I have ordered already something exotic that probably has the same layout.
I do not want to throw spoilers at people. I will make a video about that.
Either-way for me it is very simple to modify the adapter and reorder.
Let's mod everything! Check my youtube channel:
https://www.youtube.com/channel/UCZ6ULBqIKhxuNslAbqFNJUg
Interested in my devices? Check my store:
https://migronelectronics.bigcartel.com
Reply 62 of 69, by Anonymous Coward
I remember when I was younger I had always heard about how there existed 386SX systems with removeable CPUs. I would often rummage through junk bins in used computers stores looking for such a motherboard. This was before eBay listings had many pictures, and search engines didn't have an image search, so the ability to locate such things was extremely limited.
Even today, finding such a board is rare. From what I can tell, the majority of boards configured this way were in OEM systems. Every time I find a board like this on eBay, I try to document it. Needless to say, I haven't found too many. But during my searches, I occasionally noticed a 386SX board with solder pads for what looked like a test socket...but the pinout never seemed to be very consistent.
One day over 15 years ago I managed to purchase several desoldered 386 QFP100 test sockets that had a staggered pinout. I searched for a long time for a board that I could solder one onto. I think in all my searching I only ever found 1 or 2 boards that looked like they might accept my sockets, but I think both of them were very old and not worthwhile.
There are at least 4 or 5 pinouts for 386SX test sockets that I am aware of. They all seem to be about equally uncommon. I think I may have seen the one on your M396 on perhaps one other board. The most common one I run into is used by the military grade 386SX in PGA, which is also extremely rare.
Reply 64 of 69, by Diegov286c
whaka wrote on 2022-05-02, 20:00:
ohhh i realize i didn't put my contribution here. i successfully upgraded 2 PS/2's with SXLC2 50 and 40 Mhz chip. […]
first is a model 35 (isa) originally with a SX20, successfully upgraded with the SXLC2 50 G50 (without 3,3v mod) , overclocked to 33 MHz. and for bonus, cache is enabled by bios.
and clock doubling work with software control, and 66 MHz is possible totally reliably. but i added a heatsink, clock doubling also mean heat doubling 😀.
second is a model 55SX (mca) originally SX16, successfully upgraded with the 40 Mhz (so real 5V part) , tried overclock to 20 MHz but fail. cache is enabled by bios.
clock doubling doesn't work, the machine crash. don't kno
- model 55SX
hi, i'm also modifying an ibm 55sx by mounting a 486-50 processor.. i wanted to ask.. how far can i put the quartz of the clock without the system exploding?!?!?!?
Reply 66 of 69, by BitWrangler
The timing test in the BIOS fails on a 55SX for any speed crystal above ~18Mhz... i.e. it complains and won't boot.
edit: for clarity, it's a double speed crystal, that means you can't replace the 32Mhz with a 40Mhz, but a 36 might be okay and a 38 is a coin flip depending how warm or cold the system is at boot.
Reply 69 of 69, by Sphere478
386—>486 build
This is my 386 upgrade thread :p
Curious if anyone else has any ideas why I can’t get clock doubling to work?
Sphere's PCB projects.
