Reply 20 of 23, by Jorpho
swaaye wrote:
Outperformed a Voodoo5 you mean?
Oops. Yes. 😅
Dant wrote:
Oh... I knew about those. I thought he meant with consumer cards.
That's what I remember seeing. Alas, I could not seem to find it via searching just now. I might be mistaken, but I'm pretty sure the riser card was more simplistic than the one pictured in that link.
If someone could please find this it will save me from going nuts.
Reply 21 of 23, by nforce4max
d1stortion wrote:
Reminds me of that guy on youtube posting videos of newer games running on V2 SLI (8MB 🤣) with his dual Xeons, like NFSU2. He claims to be using 3D Analyze.
Seems legit, especially when compared to the quality and framerate of Doom3 running on V2 SLI 12MB... 😉 He also states that two V2 cards "configured right" will outperform a V5.
I used to be friends with that guy a few years back and to be honest most of the videos of "newer games" running on that setup used the Geforce 3 instead of the V2s but that is not to say that they couldn't run but with missing textures.
Reply 22 of 23, by shamino
Filosofia wrote:
The first contender is my first PC I built back in 1998, it has a Slot 1 440BX based motherboard from DFI and a PIII 550, that is the max I can go because the VRM only deals Katmai I think. I can easily get it to 600MHz and it would be a very capable system.
What part number is the VRM chip? Some older revision boards that don't officially support coppermine actually will run them, but it depends if you got lucky with what VRM was installed at the factory.
Those boards have BIOS support available for Coppermines, I've tested one of them before.
Attached photo shows where the VRM chip is
    22.29 KiB
Reply 23 of 23, by Filosofia
shamino wrote:
What part number is the VRM chip? Some older revision boards that don't officially support coppermine actually will run them, bu […]
Back in 1998 only could get a Rev.B1 , I'll take a look asap.
BGWG as in Boogie Woogie.
