Reply 40 of 64, by Zup
Nobody talks about Syndicate? It was only VGA, but used a high resolution mode that wasn't common.
I'm selling some stuff!
Reply 41 of 64, by leileilol
leileilol wrote:
dirkmirk wrote:
Populous 2 had svga in 1992
Pretty certain that's just VGA with the color registers pushed to a new set of 16 colors. Syndicate did the same, as well as many other games like Battle Bugs, Lemmings (menus) and The Incredible Machine
Reply 42 of 64, by SquallStrife
Malik wrote:
Errmmm...how about Comanche Maximum Overkill (1992)? It supports SVGA 640x480 high res.
And Lucasarts' Monkey Island 2 (1991) and Fate of Atlantis (1992) supports high res EGA at an odd 640x200 resolution. They look stretched rather than looking like a pure high res games in EGA.
Thexder for DOS used that 640x200 res too.
[retro swim] | Link | Release Thread
Regular silliness on Twitch!! http://www.twitch.tv/RetroSwim (8PM Mon, Wed, Sat AEST)
Reply 44 of 64, by VileR
I do wonder what's the first game that supported hi-res EGA at 640x350. My money says it's probably Cyrus... unless Windows Reversi predates it.
leileilol wrote:
Also Star Trek 25th supported 640x200 EGA
it's also one of the few games that did 640x200 on a Tandy (SL/TL models only).
Reply 46 of 64, by obobskivich
The two that come to mind for me are Total Annihilation, which I think will support any resolution you want. Personally I've run it at 2560x1600 (I don't have a display that can go higher) and that didn't require any tweaking - anything that appears on the monitor's modelist seems to be fair game and it will adjust the viewport to match AR and maintain square pixels, so I'm assuming you could either dump whatever random resolutions in there that you wanted (like 1500x1500 or something obtuse like that - I've never tried anything that extreme, but it never had a problem running on multi-monitors in "span" mode under XP) or run huge resolutions (like 3840x2400). Note that the objects and UI seem to use pre-defined dimensions so on a very huge display you will have both tons of blank-space on the UI bars (it just doesn't have enough to fill them out) and individual units/structures will not take up very much screen-space. Personally on the 2560x1600 monitor I tended to run it at something more like 1920x1200 or 1680x1050 to reel that in while still giving me a large viewport, but it is kind of cool to be able to "know and see all" at high resolution (I'm assuming with a high enough resolution display you could completely eliminate scrolling over the maps and just view all of it at once; not that such a thing would be necessarily desirable but I think it could be done).
The other that comes to mind is Myst - I'm thinking "resolution" in terms of how sharp/slick it looked for its time. I know, most all of it is pre-rendered, but by 1993 standards it looked absolutely gorgeous. 😎
Reply 49 of 64, by Anonymous Coward
I had a friend back in the early 90s with an EGA setup. He played almost the entire sierra VGA library using the 640x200 dithered EGA mode. Some of it actually looked pretty decent considering there were only 16 colours with no palette.
Reply 50 of 64, by Tertz
leileilol wrote:
640x350 wasn't unusual at that point in time, there's plenty of 1989 games that used 640x350
I'd like to see the list of these plenty commercial games (not among free/shareware 'pay who wants' stuff; not educational "games") in 640x350x16 mode. At least 5%: 50 from >1000 commercial games of 1981-1990. To be sure it was usual. As the only usual graphics mode I know for pre-1994 DOS games is 320x200 (not taking in account Hercules b/w).
EGARoids which I mentioned previously was smooth 640x350 in 1986
Hence, you agree it was not 'normal for era'.
DOSBox CPU Benchmark
Yamaha YMF7x4 Guide
Reply 51 of 64, by vetz
leileilol wrote:
Magic Carpet in addition to 640x480, also supported 640x480 in 16-bit color for the anaglyph 3d mode
And no computer at the time could run it. You need like a Pentium 200 for smooth framerate in 640x480.
Flight Unlimited from 1995 supported 1024x768. Again a resolution impossible to run on any computer back then.
Reply 52 of 64, by Lo Wang
Even though outside the traditional understanding of resolution, vanilla doom.exe supported 3 simultaneous display outputs at 320x200 each back in 1993.
"That if thou shalt confess with thy mouth the Lord Jesus, and shalt believe in thine heart that God hath raised him from the dead, thou shalt be saved" - Romans 10:9
Reply 53 of 64, by smeezekitty
EGA actually does have a changeable palette. You can swap the 16 colors out of 64.
It's a shame that 640x480x16 and 640x350x16 didn't get more use. I think 320x200 looks pretty lousy.
Then again, the 16 color modes were somewhat slow because of the planer system.
Reply 54 of 64, by VileR
Not in 200-line modes, which is what A.C. referred to (unless you were using some non-standard clone EGA with a multisync monitor, but very, very few games supported that).
Reply 56 of 64, by Anonymous Coward
Is there anyone in here with a multisync EGA setup that has run Legend Entertainment games? I seem to recall at least some of those supported "Super" EGA graphics if you had the appropriate monitor and card. Most likely VGA mode 12 graphics.
Reply 58 of 64, by leileilol
all Build engine games past 1995 can use whatever VESA mode your card reports, even the unusual ones (even 640x350 in 8-bit color).
    69.27 KiB
Reply 59 of 64, by Marco
Some more to come:
Sierra‘s Police Quest 4 and Gabriel Knight supported SVGA 640x480 (GK with only parts of the game). 1994
Fully SVGA within LSL6
Furthermore Simcity2000 (ran quite well on 386sx) and one of the best at that time: little big adventure.
