Reply 181 of 183, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Kisai, if you could get a somehow cleaner patch working, I'd be very grateful 😀
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 182 of 183, by Kisai
Dominus wrote on 2020-11-16, 09:02:
Attached (you may want to clean it up a bit more, as this is from my working source)
I've noticed that the SDL2.0.13+ Mercurial is broken and have reverted the binary attached to 2.0.12
In 2.0.10 and 2.0.12, it does not spontaneously break the events. The problem appears to be directly in SDL2 as I did all sorts of things to the event polling to try and fix it and nothing fixes it, the event's just stop after 2.0.12 for some amount of time and will then restart unless a debugger is attached in which case the debugger won't trip it, which makes it hard to figure out what SDL2 is stalling on.
I've included all the source code from my working source. If you've previously used the SDL2 patch in this thread, you should already have the src\sdl_cdrom\* files. If you've previously used the munt patch, the file will already exist, but it touches dosbox.cpp (self-contained). If you've previously used the fluidsynth patch, the files should already exist, it touches dosbox.cpp, but is also self-contained. The patch files are against individual files changed in r4392 and do not generate these other files.
I'm sorry in advance that it's a bit of a mess. I usually just checkout the SVN version, apply munt, fluidsynth and SDL2 and don't really add much after that other than nukedopl. Because almost a year passed in between the last time I did this, the SVN version changed significantly, so that I had to manually follow the SDL2 patch earlier in this thread to make sure it patched what I expected it to patch.
    DosboxSDL2-20201116.7z
    1 MiB
    41 downloads
    src,include, patches
    GPL-2.0-or-later
    lib64.7z
    3.78 MiB
    33 downloads
    Precompiled x64 libraries used with this binary
    dosbox64.exe.7z
    1.9 MiB
    29 downloads
    Win10 x64 Binary
    GPL-2.0-or-later
Reply 183 of 183, by Dominus
DOSBox Moderator
Whee! Thanks that gives me a starting point. As I've now cleaned up my macOS build scripts I can take this on again
