dgVoodoo 2 for DirectX 11
Reply 2620 of 3949, by MrEWhite
Presbytier wrote:
MrEWhite wrote:
Presbytier wrote:
I am going to ask a real stupid question, but I am genuinely curious. Why are we playing winQuake instead of GLQuake or one of the many source ports? Is there an actually difference in how it plays from all the other versions?
Software looks superior to hardware rendered ports in my opinion. I also use a WinQuake sourceport called "QDOS" and it works really well.
I never played anything but GLquake, but I just found out the gog version comes with winquake the exe is in the game folder, tried it and it runs flawlessly. I can definitely see the appeal definitely looks different.
dgVoodoo2 lets the Steam Overlay work and adds scanlines, which is why I use it.
Reply 2621 of 3949, by Deadalus
dgvoodoo2 finally fixes Fighting Steel 3D view issue.
http://imgur.com/e00Aaqc
Some graphic issues still exists, especially when enabling Sea Swell effect in the options menu, and illumination flare light effects. But at least it's more playable than ever now.
http://imgur.com/hzdOJ07
http://imgur.com/cISDDzK
Reply 2622 of 3949, by KainXVIII
stranno wrote:
Digital Foundry recommending dgVoodoo for MDK 😀
https://www.youtube.com/watch?v=_LbIJdGNQfA
I don't get it how to achieve fullscreen image with dgvoodoo in MDK (gog version), il always stays windowed in top left corner of the screen...
UPD - ok, so i somehow solve this problem, but there is another - how to get rid of blinking lines around edges of screen?
    509.53 KiB
Reply 2623 of 3949, by ed_barber
Your wrapper is probably the best thing I've come across for retro gaming on Windows 10 as I've gotten every game I tested on it to work! I have one game called Delta Force 2 and it has support for both software rendering and semi-hardware rendering. The thing is that in hardware mode the objects being rendered using Direct3D (I believe uses DirectX 6) get shown through the terrain (rendered in software mode even if the renderer is set to full-screen hardware) even when they are behind it. If I use dgVoodoo 2 to try and fix it it will actually make everything that's rendering in Direct3D disappear so only the terrain is in the scene with the fonts on the characters that represent their friendly tag. It would be cool if you could look into this. I would love to see the day I can finally play this lost treasure while making use of its 3d acceleration on modern hardware.
I even heard that the chipsets listed such as the nVidia TNT 2 had issues with the game too. I even got a GeForce 7600 GS using drivers from around June 2008 to render everything correctly in hardware mode but at a lower than anticipated framerate. Your work is very great and you should consider contacting game companies with your fixes. Many people would love to see certain retro games able to play once again!
PS. It would be nice if there was an option to use either hard or soft shadows in when the game is using shadow buffer mode such as in Splinter Cell 😀
    396.51 KiB
    Software Renderer: Close enough
    425.64 KiB
    D3D Renderer: The fog doesn't blend in with the environment and the water morphs through the grass it seems. Also the exit prompt it very broken.
    479.1 KiB
    561.67 KiB
    D3D Renderer: The buildings show through the terrain. See the part with red circle around it.
Reply 2626 of 3949, by ed_barber
lowenz wrote:
???? A DX6 game????
No, I meant for a game such as Splinter Cell it would be nice if there was an option to use the hard or soft PCF shadows for nostalgia purposes. Using an era correct PC for Splinter Cell has PCF shadows but it looks blockier.
Reply 2628 of 3949, by daniel_u
ed_barber wrote:
lowenz wrote:
???? A DX6 game????
You can do it from the game's config. Look up shadowBuffers.
Reply 2630 of 3949, by VirtuaIceMan
Any chance of getting table fog in Shadows Of The Empire? As far as I know, the GOG version has fog, and whilst this site recommends DXGL I didn't have any luck with it: http://www.play-old-pc-games.com/2015/02/10/w … shadows-empire/
It's particularly noticeable on level 2, Escape from Echo Base, this video shows it with and without. On my 980 whether I use it's own D3D or dgVoodoo 2.53, there's no fog 🙁 https://www.youtube.com/watch?v=WdkbC3iOsD8
Reply 2631 of 3949, by gameragodzilla
Every time I use dgVoodoo 2 in Splinter Cell 1, the game stutters for a bit whenever I start a cutscene, or start a level, or switch to thermal. Afterwards, the framerate speeds back up and I can switch fine, but before it always stutters. Is that normal or is there some setting I had wrong?
Reply 2632 of 3949, by daniel_u
I get that too but i thought is my system or settings.
Reply 2633 of 3949, by gameragodzilla
It's a minor annoyance but it's still there.
Also, sometimes dgVoodoo 2 spontaneously stops working. Like it'd be working and the shadows look nice, and then it'd stop and I'd have to fiddle around with the settings again.
I also saw random black splotches, like there wasn't any textures or something, which after redownloading the files, it went away.
Reply 2635 of 3949, by gameragodzilla
daniel_u wrote:
Post some pics and hope Dege will look into the problems. 😀
I haven't been able to recreate them so far, so I will when I can.
The big issue is still the stutter, though. It's annoying that every time I reload a save, I get a brief stutter for everything. Would like to play this way with 100% smooth gameplay like I could normally without dgVoodoo 2.
Especially since dgVoodoo 2 seems to be the only wrapper that actually fixes buffer shadows.
EDIT: Also, I was perfectly content with just playing with projector shadows, but recently, the level Vselka Infiltration glitches out at the end if I use them. Basically, the guards would not spawn properly and thus run into each other and get stuck on the stairs. So no one would actually go into the room and I'd be stuck as the doors are locked.
Is there a way to fix this? It literally only happens with projector shadows. Anytime I switch to buffer, it works perfectly fine.
Reply 2636 of 3949, by VEG
Dege wrote:
The polygon glitch is strange because I don't think that there is any difference between DX6 and DX7. Is transparency solved wit […]
Is transparency solved with textures with alpha channel or legacy colorkeying?
If alphaed textures then DX6 and DX7 should be equivalent but the thrash driver may configure the fixed function pipeline in some other way for DX7, for some reason.
If colorkey then it's MAYBE renderstate D3DRENDERSTATE_COLORKEYBLENDENABLE, it's DX7-only and if it's enabled then colorkeyed pixels forced to 0 without discarding the pixel.
But, it all should be debugged.
I've found the difference between the DX6 and DX7 thrash drivers which causes the problem. DX6 thrash driver reports to the game that it supports textures from 8×8 to 256×256 (it's hardcoded). DX7 uses actual device capabilities and reports that it supports textures from 1×1 to 8192×8192. The game doesn't like when minimal texture size is less than 4×4. That invisible tree uses a 2×2 transparent texture. When minimal size is larger than a texture size, the game stretches the texture before using. If I set minimal texture size of DX6 to 1×1, it causes the same problem. So, some code in the renderer or in the game don't like when too small textures are used. So, I have a good workaround for this problem (treat every minimal texture size below 4×4 as 4×4), but the root of the problem why something doesn't like too small textures is still mysterious 😀 Maybe later I'll try to understand it better. At least the problem is workarounded.
Best regards, Evgeny
Reply 2637 of 3949, by Dege
I'm up to my neck in non-dgVoodoo works nowadays, unfortunately, so can't be too active.
But, recently I surveyed what to do next. The list is not really about new features but some existing problems and revising some internals (for example, crash with SpaceBunnies pointed out some things).
I could only try the original version and it was ok. But, I only played the first level.
Thanks!
I tried this game, and yes, I got the same through both dgVoodoo and natively, wrong z-order. Didn't yet checked what's going on (the rendering technique) though, but it's on the list. 😀
Would game companies re-release their old stuff with new fixes? 😀
I think they don't care and release them to Steam or Gog.
But, yeah, would be nice, for example, if Splinter Cell (or any other fixed game) could be available as a simple drm-free release with modern installer, all patches, texture packs, and so on, gog-like.
I'm not against it but I wouldn't like to have an option for this on the GUI.
An ini-file config would be better, exclusively for experts, where everything could be finetuned.
Yes, I hope. I'll check it.
I haven't been able to recreate them so far, so I will when I can. […]
Hmmm..... I never experienced this. Couldn't it be a driver problem? I have bad experiences with AMD drivers, for example, ATI tech demo Island2 doesn't run properly on my R7 360, flashing polygons and screen parts, etc. On other hw, it runs fine.
You could try the WARP rendererer with a low resolution (640x480) and without extras (like MSAA) in windowed mode, to see if stuttering is caused by the video card.
Maybe the stretching code is wrong in the trash drivers?
If it's done by Blt then the RECT parameters can be wrong (RECT is exclusive as for right and bottom) so one row and column may remain unblitted. Or sg like that. 😀
Reply 2638 of 3949, by gameragodzilla
Well I want to play it in 1920x1080 if at all possible. The good thing is this program even puts the cutscenes in that resolution, when usually they're hardlocked to 640x480. That being said, I run a GTX 980M (gaming laptop) at the moment and I also put the ini files at 1920x1080. Could that be the problem? Might fiddle around with my Nvidia graphics settings too.
