First post, by alexfru
Set-up: I'm using DosBox 0.74 on Windows 7 74-bit.
I have two batch files.
QQQ.BAT:
@echo qqq start!
@call www.bat
@echo qqq finish!
and WWW.BAT:
@echo www!
If I run QQQ.BAT directly from DosBox, I get all three lines printed:
But if I try to run this batch file from under any shells similar to the Norton Commander, "CALL WWW.BAT" doesn't seem to return control from WWW.BAT back to QQQ.BAT.
Dos Navigator:
Volkov Commander:
And finally, my very own Frunze Commander:
If I exit whatever commander I'm running and run QQQ.BAT again, all is back to normal, all three lines are printed.
What could be the problem and is there any fix or workaround for it?
Reply 1 of 4, by Joey_sw
i would suspect its because those program run the bat using "COMMAND.COM /C" method, which ...
anyway, you can have similar result by running the following in dosbox:
command /C QQQ.BAT
the /C command should have work properly on real DOS.
-fffuuu
Reply 3 of 4, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Here's a patch against current source that resolves the issue in my testing. It also matches the internal batch loop to the command prompt batch loop more closely.
    shell_run_internal.diff
    662 Bytes
    112 downloads
