First post, by bristlehog
Got an Orchid SW32 early version (512K ROM). It works in GM and MT-32 mode, and does SB-compatible PCM, but when playing OPL music, it skips notes a lot! What could be the problem?
Reply 1 of 4, by elianda
Doesn't the orchid sw32 plays FM-sound through the wavetable?
Youtube Channel
Reply 3 of 4, by stbunny
Check jumper settings. I experienced the similar problems and after changing DMA settings card works fine.
P55T2P4, Intel Pentium 133MHz, 32Mb EDO, S3 Virge 325, YMF-719s + SC-55, AHA-2940U2W, ST39175LW, UltraPlex40Max, Opti USB PCI, Sony CPD-G400P 19"
