First post, by feipoa
Does anybody have an updated BIOS for the DTK PKM-0033S E-0?
The BIOS I have is from 12/11/95 with the following revision string:
DTK PKM 0033S.P02.02.05-V2.05
Anyone have any first-hand experience with this board?
Reply 1 of 17, by Anonymous Coward
Should be an OEM version of 486SPS. Try looking for a BIOS for that.
Reply 2 of 17, by feipoa
I tried looking for both, but stuck out. I've had better luck with forum users sharing these long lost BIOS updates. It is also possible that a BIOS update was never released.
Anyone with a DTK PKM-0033S or Gemlight GMB-486SPS have either the original BIOS or some update? Thanks a lot!
Reply 4 of 17, by feipoa
pkm0033s.205
pkm33v222
I wonder if PKM0033 is the same as PKM33. I'll test it out. Thanks for finding this!
Reply 5 of 17, by Anonymous Coward
Probably just shortened because of the 8 letter DOS filename limitation. As far as I can tell the DTK models always had 4 numbers PKM-0031Y, PKM-0038S etc.
Reply 6 of 17, by feipoa
Unfortunately, that v2.22 BIOS is not for the PKM-0033S or GMB-486SPS. It is for a DTK PAM-0054, which is for a 430FX board.
The reason I want the BIOS update is because I recall the Zita Tomato 4DPS board, which is also SiS 496/497-based, would not recognise 64 MB FPM sticks until I updated that BIOS. I figure the same would apply to this motherboard.
The existing v2.05 BIOS is from December 1995, however this board had chipset dates going to mid-1996, which means there is probably a good chance there was a BIOS update.
Reply 7 of 17, by feipoa
I checked all the wayback captures for gemlight and it seems v2.05 was the latest BIOS. I wonder if the GMB BIOS is any different from the PKM BIOS.
http://web.archive.org/web/19961219082235/htt … emlight.com.hk/
GMB-486SPS/PKM-0033S SiS 496/497 486 PCI Motherboard
4WSSG205.BIN for GMB-486SPS V0 RB/RD (Size 131K)
4WSSD205.BIN for PKM-0033S E-0 RC/RD (Size 131K)
Reply 8 of 17, by NJRoadfan
There is likely no difference aside from branding. From what I could find on DTK's old sites, 2.05 was the latest for their board too. Was DataExpert still in business in 95-96? They made quite a few GemLight boards, or at least cloned them. Quite a few shared manuals in 93-94.
While its a bit crazy, the 4DPS BIOS might actually work on that DTK board if its the same chipset. I'd try it if I had a backup BIOS chip handy.
Reply 9 of 17, by feipoa
I thought about this too, but recalled that when I tried to use the 4DPS BIOS on a 4DPS clone board, that some things didn't work quite right.
Reply 10 of 17, by alexthekid
feipoa wrote on 2013-06-06, 08:36:
I checked all the wayback captures for gemlight and it seems v2.05 was the latest BIOS. I wonder if the GMB BIOS is any differe […]
Can somebody please upload the PKM-0033S and/or the GMB-486SPS-BIOS(es) again? The link above seems to be dead.
Thank you very much 😀
Reply 11 of 17, by Horun
alexthekid wrote on 2020-11-10, 23:48:
The GMB-486SPS BIOS 2.05 can be found on the Power utils CDROM here:
GMB Spsb205.zip GMB-486SPS Bios v.2.05.
https://www.elhvb.com/mobokive/Archive/POWER_ … gmb/spsb205.zip
Use WInRAR or 7Zip to extract, inside is 4WSSG205.bin
Has these internal headers: Award Modular BIOS v4.50PG ,Copyright (C) 1984-95, Award Software, Inc. 40-0205-2A4IBG3I-V2.05
Award 12/11/95-SiS-496-497/A/B-2A4IBG3IC-00
Still looking for the DTK PKM-0033S variant of the BIOS
Reply 13 of 17, by computerguy08
Horun wrote on 2020-11-11, 01:55:
We have it here: http://www.win3x.org/uh19/motherboard/show/1932
37.43 KiB
Looking for a motherboard? You can find it in Ultimate Hardware 2019: http://www.win3x.org/uh19/motherboard/search
Join our UH19 Discord server here: https://discord.gg/HWWH7hsk2p
Reply 15 of 17, by watson
Since we seem to be on a roll here, would anyone happen to have the latest BIOS (seemingly V3.06) for either the GMB-486SG or its DTK variant PKM-0038S ?
Both of these existed on the previously linked Gemlight website at some point, but my search for them has proved fruitless.
Reply 16 of 17, by computerguy08
watson wrote on 2020-11-11, 17:35:
It seems that we have the Gemlight variant in uh19: http://www.win3x.org/uh19/motherboard/show/2600 , not sure if it's v3.06
Reply 17 of 17, by watson
computerguy08 wrote on 2020-11-11, 17:43:
EDIT: Several months later, I was able to locate V3.05 for GMB-486SG here: http://sannata.ru/bios/486/ROM4DX07.RAR
The BIOS available in UH19 is V3.04 and it the same version that the poster on DOSReloaded was referring to.
I misunderstood his original post, he listed the BIOS string of his current BIOS (V3.04), not the new one he was looking for.
Therefore, I am still on the lookout for V3.06.
Original post:
I think that might actually be it. The only result on Google for "4WSPG306.BIN" is this: https://dosreloaded.de/forum/index.php […]
The only result on Google for "4WSPG306.BIN" is this: https://dosreloaded.de/forum/index.php?thread … -486-vlb-board/
I can't read German, but Google Translate suggests the poster is looking for version 3.06 from 1995, while claiming to have 3.04 from 1994.
In any case, thank you very much.
