SoftMPU project needs your help! (game & sound card testing)
Forum for discussion of bugs, code, and other aspects of SoftMPU.
Re: SoftMPU project needs your help! (game & sound card testing)
Postby Thomas_GER » 2019-1-15 @ 07:35
Yeah, thank You. I have that Version allready and my S2P works fine. Problem is the /MT32 option as it works ONLY with s2p. So I asked if that switch could be implemented into the other /OUTPUT options so i can switch my standard S2 on the soundcard's MPU interface to MT32 emulation.
User avatar
Thomas_GER
Postby dreamblaster » 2019-1-29 @ 20:07
a new build of softMPU is now available from https://github.com/pdewacht/softmpu (based on scali's changes-- thanks!)
this supports /MT32 option, also for S2
OPL2LPT, OPL3LPT, X2, S2, S2P, MCE2VGA, ... many projects !
Special vogons LPT bundle : https://www.serdashop.com/Parallel-port-retro-sound-bundle
Thanks for your support !
dreamblaster
Postby Thomas_GER » 2019-1-29 @ 21:51
Yes! Tested version shortly. Works perfectly, thanks for the help! :)
User avatar
Thomas_GER
Postby Thomas_GER » 2019-2-02 @ 13:20
Still some flaws with the pitchbends in some games but work continues.
User avatar
Thomas_GER
Postby bjt » 2019-2-05 @ 10:56
bjwil1991 wrote:And when I'm done using the game and software, I type in the TSR removal command to close out the SoftMPU software.
While this may free the memory used by the TSR, it won't return the RTC, PIC and GDT to their original state and will probably result in a crash later on.
User avatar
bjt
Postby bjwil1991 » 2019-2-05 @ 14:19
I reboot the system later on as a precautionary measure.
Systems from C64 to FX-6300.
User avatar
bjwil1991
Postby Thomas_GER » 2019-4-05 @ 09:26
Hey guys.
Any news on the pitchbend issues in combinations with Dreamblaster S2?
User avatar
Thomas_GER
Previous
Return to SoftMPU
Who is online
Users browsing this forum: No registered users and 0 guests
