First post, by truth_deleted
I removed the window frame and decorations from DOSBox 0.74/SVN (use output=surface). Attached is the win32 binary for testing by users and also a patch to view the code. I likely removed desirable features from the SDL window in removing the window frame, but posters have asked for no frame, so any trade-off in features may be worthwhile. The two batch files in the attachment allow the docking of dosbox in the top left or center of the screen. These may be further edited by the user. Also, the console window is removed by the batch files, so this is the ideal way to run this dosbox version.
[Edit: updated the SDL.dll library file so that the DOSBox window is borderless and movable. Right-click on the taskbar button for DOSBox and choose "Move", then use the keyboard arrow keys to move the window. Press Enter when finished. Also, the attached SDL defaults to the windib video driver. The modification doesn't seem to work with directx.]
