Reply 20 of 198, by ik777
- Member
wrote:EDIT: OK so I have attempted to install the kernel driver on XP where I already have the YMF724F-V legacy mode enabled with PowerYMF. Regardless of methods of installation (Add new hardware, update driver on Legacy Sound System which has port 388h used), I get the following:
An error occurred during the installation of the device.
The class installer has denied the request to install or upgrade the device.
Assistance is required. Thanks.
I got same issue, too. Tried on SoundTrack Dightal XG, DS-XG Legacy WDM Driver still hold address 220 330 and "388". No way to install Kernel Mode Adlib Drivers.
The basic Windows XP Ds1 Driver only install FM MIDI. Can hear FM-MIDI using with Media player, and work on GM setting in DOSBOX.
But Sound horrible because no program reset FM as DOS driver. And installing any DS-XG WDM driver remove FM synth.
