First post, by Athena
Hello,
I installed DosBox 0.74 on a W2008R2 server (used as Terminal Server), in order to run old DOS applications.
I works fine, however the Dos Box Window is too small (640x480) and we don't want to use full-screen (which not change the application windows size)..
I already tried several configurations in the config file (fullresolution=1024x768; windowresolution=1024x768; output=X,Y,Z...) but nothing works.
Is it possible to simply enlarge the window to 1064x768 on this type of configuration (usedremotely via RDP) ?
Thanks in advance for your help.
