First post, by amarok
I've just installed DosBox 0.74 in Win7 64. I can't type anything into the shell prompt, because the first key I press just gets repeated, as if I were holding the key down. e.g. if I try to type "c:" I just get "ccccccccccccccccccccccccccccccc".
I've googled around and searched this forum, but no dice. Has anyone had the same problem?
