Phil's Ultimate VGA Benchmark Database Project
First post, by Mau1wurf1977
Get your test benches ready, whip out your CPU coolers, start overclocking: It's time to do some benchmarking!
Introduction
Hello everyone,
I'm Phil, also known as Mau1wurf1977 on various sites (VOGONS, OCAU, Whirlpool, Dosforum, QuestStudios, Vintage Computer Forums...).
3 years ago I wanted to to create a collection of benchmark results to help retro computer builders check that their system is running correctly, but also to guide slow-down projects and answer questions of the nature: What games will I be able to run on my computer with L1 cache turned off? This resulted in the 3DBENCH database on VOGONS.
My goal is to:
  • Make benchmarking as easy as possible. All benchmarks will be provided and I wrote a batch file and all you have to press is 1 - 5
  • Everything is pre-configured. No confusion about sound / no sound / detail / screen size
  • Make submission as easy as possible. Users submit their results themselves via a Google docs document
  • Two sections: One for stock systems to help others check their systems. One for overclocking and having fun (anything goes)
YouTube video explaining everything
Click to watch the video
So with this project we will be expanding the benchmarks and using the following:
SUPERSCAPE BENCHMARK 1.0c or 3DBENCH2
This version scales nicely with faster machines, all the way from a 386DX to a Pentium 3.
PCPBENCH /VGAMODE
Also scales very nicely and is a good addition to 3DBENCH2.
DOOM
A classic and scales very nice as well. We will be using full screen to make the benchmark more demanding.
QUAKE
Download the benchmarks and batch files
http://www.philscomputerlab.com/dos-benchmark-pack.html
Easy to use set and forget menu:
Submit your results
https://docs.google.com/spreadsheets/d/1lvF9n … dit?usp=sharing
  • You can't enter a FPS value for Doom as this will be automatically calculated. You need to enter the realticks value.
  • Please try to complete all sections to help other users when they build a system.
  • For the overclocking (anything goes) section, please complete all sections and document performance relevant modifications, such as BIOS settings, performance improving utilities, hardware mods...
  • I will sort the table regularly and publish a PDF document on a weekly basis
My YouTube channel
Reply 1 of 491, by badmojo
Hi Phil I'm Rob and I like old computers 😀
Fantastic effort mate, I've been meaning to benchmark my various retro machines and this will make things very easy, and being able to compare my results with others around the world on a level playing field is a big bonus.
Results incoming.
Reply 2 of 491, by Mau1wurf1977
Thanks Rob 😀
Download link to FASTVID
FASTVID improves VGA performance on Pentium Pro and Slot 1 machines:
http://www.mdgx.com/umb.htm#FVD
There are similar utilities for other CPUs. So if you happen to have one, please share and document.
I've also attached the file to this message for archiving purposes.
    FASTV110.ZIP
    1.26 MiB
    357 downloads
    FASTVID which improves performance on Pentium Pro and Slot 1
My YouTube channel
Reply 3 of 491, by Mau1wurf1977
Added this to the first post:
My YouTube channel
Reply 4 of 491, by 5u3
Wow, nice work! I'm sure this will yield nice results to work with. 😉
One comment about FASTVID: Since the benchmarks only use standard VGA modes, it is in most cases not necessary to load FASTVID or similar tools. Standard VGA always has the framebuffer at the same address, so the BIOS usually already sets a MTRR covering the VGA framebuffer.
However, there are systems where these tools might still be needed, for example if you have a fast K6 on an old Socket 7 board which doesn't recognize the CPU properly.
Reply 5 of 491, by Mau1wurf1977
I did a run on a Gigabyte BX2000 and FASTVID greatly improved the performance. I put each results in the database.
My YouTube channel
Reply 7 of 491, by Mau1wurf1977
GL1zdA wrote:
What about adding Quake?
OMG figured it out.
I'll quickly replace the ZIP file and everything 😀
My YouTube channel
Reply 9 of 491, by Mau1wurf1977
F2bnp wrote:
You are awesome Phil, you have helped this community immensely over all these years!
Thank you! Means a lot 😀
CHANGES:
QUAKE
Unpack and type BENCH.zip which you can download here: https://www.mediafire.com/?4riihr1m9iui13v
My YouTube channel
Reply 10 of 491, by kixs
Just tested on Celeron 800 (Acer laptop). Fastvid improves results from 5 to 50% even in VGA mode. I guess it all depends on the motherboards BIOS because on other platforms I didn't get any imprevements in VGA mode, only in VESA modes.
Reply 11 of 491, by Mau1wurf1977
Thanks for submitting the results!
Had to put the sheet on view to add protected areas. The DOOM FPS column is now locked (because it calculates the value based on realticks) and so are the headers. The document is back to be editable.
Added some 486 results and removed all Slot 1 results because they were missing the Quake results. Might do some more benchmarks tomorrow, but I hope people start entering results over the weekend.
My YouTube channel
Reply 12 of 491, by keropi
awesome, nice to see this project going... will update with the quake score in a jiffy 😀
🎵 PCMIDI mpu site buy+info
🎧 WIP Orpheus soundcard site
Reply 13 of 491, by Geoman
Thank you very much for the effort!
Unfortunately, the Doom-Benchmark does not work as intended: there is no gameplay displayed(like in the youtube-video)
but only these results:
file.php?id=13429
9956 realtics cannot be...
    432.36 KiB
    1 download
IBM Aptiva 2168-931
Reply 14 of 491, by sandmanx
This is a great excuse to get some of my retro systems up and going again. I've got a pile of 486 and Socket 7 CPUs to try out.
One I'm curious about is a 486 I have that's labeled: It's ST 486DX2-80. I also have a Cyrix Dx2-80 as well as a AMD 5x86 133, and a real Intel 486DX50.
In the Socket 7 world I have a K5, K6(which I removed the heat spreader on and got it to overclock another speed grade bitd), K6-2(several speed grades, and even an Engineering sample @350MHz), P54,P55, and Cyrix MII.
81.28 KiB
No downloads
Some P54, P55, and 486
Reply 15 of 491, by 5u3
5u3 wrote:
One comment about FASTVID: Since the benchmarks only use standard VGA modes, it is in most cases not necessary to load FASTVID o […]
Huh, I didn't expect that, at least not on the Intel platform (even the early Pentium II CPUs have MTRRs, unlike the early K6 CPUs). BIOSes seem to be worse than I thought...
So, if you are unsure, bench with FASTVID loaded of course. And thanks to Mau1wurf1977 for not forgetting to mention this feature. 😉 On faster machines, the MTRRs have more impact than anything else.
Reply 16 of 491, by Mau1wurf1977
Yes that's the output of whatever was saved last in RESULT.TXT.
I would delete the entire BENCH folder and unzip it again.
If the menu system still doesn't work you can try some things manually:
Go into the DOOMS folder
type DOOM.EXE and see if the game runs
TYPE DOOM.EXE -timedemo demo3 and see if the timedemo runs
if no score is displayed
type
DOOM.exe -timedemo demo3 > result.txt
And after the benchmark
type
type result.txt
My YouTube channel
Reply 17 of 491, by Mau1wurf1977
sandmanx wrote:
This is a great excuse to get some of my retro systems up and going again. I've got a pile of 486 and Socket 7 CPUs to try out.[/attachment]
That's awesome. You have some more "exotic" CPUs which are always very interesting to see where they end up at!
My YouTube channel
Reply 18 of 491, by Geoman
Mau1wurf1977 wrote:
TYPE DOOM.EXE -timedemo demo3 and see if the timedemo runs […]
type
type
result.txt
I will try that - thank you! 😀
IBM Aptiva 2168-931
Reply 19 of 491, by Mau1wurf1977
My bad. The command to output a text file is to type:
type result.txt
My YouTube channel
