Post pics of your CRT monitors
Reply 280 of 540, by jwt27
I'm sure I had some pics of Diablo 2 on my low-dpi HP but I can't seem to find them. The phosphors on this screen (green and blue especially) are a bit worn out so the gamma is way off and darker hues turn out a bit reddish-purple. Somehow this looks absolutely gorgeous with Diablo 2 so I always disabled gamma correction for this game specifically 😀
Reply 281 of 540, by pojo
I picked up this very nice Dell 19-inch for free! I think the model is M990.
Sharp picture and quite compact for display size 😀 I will use it between my Slot1 machine and the Macintosh.
Reply 282 of 540, by Deflektor
Best CRT EVER. 17 inch Sony Trinitron g200. Bought it recently.
954.03 KiB
I've tested a shit load of crt's for my purposes. To me - 15-inch shadow mask actually never got that "true-dos-look". 19-inch is crap for lower resolutions. But 17-inch aperture grill is great for everything, imho.
Here some other stuff that i bought, but it didn't satisfy. Also got samsung 959nf and iiyama master vision pro 454 for my second socket a setup, but they being repaired right now.
1.14 MiB
Reply 284 of 540, by greasemonkey90s
PeterLI wrote:
I picked up 7 CRTs last week. Down to 6 this week. Down to 4 tomorrow. The only one I will keep is a Dell Trinitron. 🤣
The other 6 were crappy generic brands and pretty poor quality. Plus they take up too much space. 😀
I have a dell trinitron p990 1600x1200 @120hz and i love it wish i new some calibration settings
Reply 285 of 540, by archsan
120Hz? That's high for a 19 inchers... my Sony G420s can only go max 87Hz at 1600x1200 I think.
"Any sufficiently advanced technology is indistinguishable from magic."—Arthur C. Clarke
"No way. Installing the drivers on these things always gives me a headache."—Guybrush Threepwood (on cutting-edge voodoo technology)
Reply 286 of 540, by King_Corduroy
Just pulled this out of the trash a couple days ago! I finally have a matching Packard Bell monitor for my Platinum 55. 😁
Check me out at Transcendental Airwaves on Youtube! Fast-food sucks!
Reply 287 of 540, by retrofanatic
Very nice find King_Corduroy! Do the speakers work?
I've been looking for a similar monitor for my Packard Bell as well. I do have another PB CRT that's in good shape but I like this one with the speakers.
Reply 288 of 540, by King_Corduroy
Yep works perfectly. 😁 I had to clean it up and adjust the colours etc but now everything works like new.
Reply 289 of 540, by retrofanatic
That's great!
I'm curious if I have the same CRT but without the speakers attached because my CRT looks very similar. Is it possible that the speakers were just not attached to mine or are they built in and cannot be removed?
Reply 290 of 540, by King_Corduroy
There should be two holes on either side where they would attach. The speakers are held in with screws with plastic spacers. You can indeed remove the speakers, and they aren't (or shouldn't be) too hard to find on eBay, plus any old 9V 1000mA adapter will power them. 😁
Most people took the speakers off since they were decent and kept them long after the monitor konked out (since they were pretty generally cheap and shoddy)
Reply 291 of 540, by MMaximus
I bought this little guy locally a few days ago. Thomson CGA monitor, was apparently stored in a kitchen for years - it smells really bad! 😵
I already spent quite some time cleaning it but I need to do it more. Amazingly though, it still works, even if the colors are probably not as bright as they were when it was in its prime.
aZ7zxxbl.jpg?1
Hard Disk Sounds
Reply 292 of 540, by Caluser2000
554.62 KiB
P97 Monitor hooked up to my 286.
Reply 293 of 540, by einr
The photo is a bit crap, but here's my Nokia 920C, manufactured in August 2000 by ViewSonic (I think):
148.57 KiB
It's 19", max 1600x1200 at 76 hz, .22 dot pitch. Really good monitor. Very sharp, good geometry, capable of solid refresh rates. Back in the day, Nokia monitors had a well-deserved top-notch reputation (at least here in Scandinavia; I remember them always being near the top in monitor tests in computer mags).
This is the only VGA CRT I have left these days. I would like to find something older and smaller for my 486 system but as you guys have noticed it's hard to even find them in dumpsters these days...
Reply 294 of 540, by Aideka
einr wrote:
The photo is a bit crap, but here's my Nokia 920C, manufactured in August 2000 by ViewSonic (I think): […]
Nice! I have always wanted a Nokia monitor, but most of those were used primarily in businesses, and as such have been used so much I wouldn't want to buy one and have it blow in the first week 🤣
Reply 295 of 540, by oeuvre
I have an NEC Multisync XP17 sitting around... it's too big for my desk (which is not deep enough). Trippy GIF testing the monitor here https://gfycat.com/ClassicPepperyDrever
Here is a picture of the connectors (yes that's access.bus)
http://i.imgur.com/A0Fzilz.jpg
Reply 296 of 540, by ynari
Interesting. I was around throughout USB's introduction, but have never even heard of access.bus. It really must have bombed early on.
On the rarity side, I'll get around to posting pictures of my IBM C220p monitors. They unusually have a DVI-A connector on the back. Understandably, if a DVI-D cable is used to connect it, the monitor information can be queried but there's no image. DVI-I cables should, in theory, work but in practice only support low end resolutions. It needs to be a genuine DVI-A cable to take full advantage of the monitor.
Reply 297 of 540, by NJRoadfan
DVI-A to VGA adapters pass all the signals present on a DVI-I port to the monitor regardless. Throw on an adapter+VGA cable on the back of the monitor and connect to the VGA port. It should work, including DDC.
Reply 298 of 540, by xjas
This is my fully-modern i7 workstation in my office:
632.84 KiB
...and that is a huge Mitsubishi Diamond Pro21TX that someone in the machine shop tried to throw away for no good reason. It's perfectly obnoxious and eats all the electricity and I love it. Note the coffee cup for scale.
111.7 KiB
Rear view. Yes it sticks right out into the walkway and crates a navigational hazard. Unfortunately I had to use the VGA input because the component ones don't play nice with Linux (no Monitor ID pin means the available resolutions aren't set automatically - of course you can edit the config file to set it up yourself but it was easier just to plug into VGA) but I do have the VGA->5 BNC cable for it.
Unfortunately it's gotten a little soft and dim in its 20 years of service, but it's still fine for everyday use. I'm running it at 1280x1024x85Hz instead of its max of 1600x1200x75. This thing was a $2275 monitor new, how could I not use it??
(Fun fact: I am using it right now to post pictures of itself on here. It's like inception.)
Reply 299 of 540, by xjas
...And then of course there's this monitor in my "arcade cabinet":
186.33 KiB
a 16x9, 1080i CRT w/DVI? Yes plz.
