Post pics of your CRT monitors
Reply 300 of 540, by Radical Vision
Only 2 of them.
Compaq not sure what OEM it is, but looks nice so i guess is something good, and is like brand new..
DELL is all SONY Trinitron inside, 21 inches, it is too damn heavy...
    1.84 MiB
    389.1 KiB
K7 2.6/ NF7-S/ HD3850
Cmq P2 450/ GA-BX2000/ V2 SLI
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
Reply 302 of 540, by tegrady
My Mitsubishi Diamond Plus 91 19" CRT. I bought this new back in 2001.
It still works, but it makes a slight high pitch squeal sometimes and it looks a lot blurrier than I remember.... Probably needs new caps and a tune up, which is currently beyond my abilities. For now it just sits in the corner, waiting to be revived.
    309.99 KiB
Reply 303 of 540, by KCompRoom2000
Here are the few CRT monitors that I have in my collection.
Sony Trinitron Multiscan CPD-E240 (owned this ever since I got it back in 2005):
354.1 KiB
Dell M782p (another spare monitor, does a hissing noise when powered on, so might need a recap):
298.81 KiB
Dell M782 (used as the main monitor for my two retro systems: the Win95 rig, and the Win98-2K rig):
370.32 KiB
Reply 304 of 540, by kixs
21" CRT ELSA ECOMO 21H97 - still has good picture quality @ 1600x1200 as photoed here:
ELSA ECOMO™21H97 21" Monitor with 115 kHz for Professional DTP and DIP […]
ELSA ECOMO™21H97
The ELSA ECOMO 21H97 meets the toughest of requirements for display quality, color reproduction and ergonomics demanded by the most sophisticated of tasks in image processing. The special 21" flat screen CRT with superfine mask pitch and high-quality antireflection coating guarantees high accuracy in fine detail, even for the most demanding applications. Very high resolutions of 1600 x 1280 pixels can be displayed at an absolutely flicker-free refresh rate of 87 Hz. With a generous array of ELSA features, this class-leading model is fully adjustable for individual ergonomic needs. The ELSA ECOMO 21H97 is recommended for professional desk top publishing, document image processing and other areas of application where sharpness, color reproduction and ergonomics on a large-area screen play a major role.
* 21" (53 cm) Black-Matrix Hitachi Flat Square picture tube with 0.27 mm mask pitch (0.21 mm horizontal)
* Antireflection picture tube using Lambda/4 antireflection coating
* Up to 115 kHz horizontal frequency
* High resolutions up to 1880 x 1440 pixels
* Multi-mode technology for automatic frequency adjustment
* On-screen display menu
* Selectable color temperatures between 5000 and 9300 Kelvin
* Purity control including rotation features for precise adjustment of color purity
* DDC1/2B, Plug&Play interface
* Intelligent power management in accordance with VESA DPMS, NUTEK and EPA
* TCO '95, ISO 9241-3, MPR II, TÜV ERGO, TÜV GS
Reply 305 of 540, by bjwil1991
Medion MD 1998OF monitor
IBM 2115-001 Monitor (needs repairs)
Reply 306 of 540, by bjwil1991
Radical Vision wrote:
Only 2 of them.
The Compaq one came with the Presario 6000 series desktop computers back in 2002. I had that exact monitor, but a burn-in (ghost) image defect.
Reply 307 of 540, by ElementalChaos
I dumpster-dived this AcerView 34T a few months back. Looks fantastic after a flyback G2/focus adjustment.
1.05 MiB
  • Manufacture date: November 1993
    14" Panasonic M34KNZ080X tube, .28mm invar shadow mask
    Maximum resolution: 1024*768 @ 70Hz
    Horizontal scan: 31-48 KHz
    Vertical scan: 50-100 Hz
kixs wrote:
21" CRT ELSA ECOMO 21H97 - still has good picture quality @ 1600x1200 as photoed here: […]
This is almost certainly a rebranded Hitachi Superscan Supreme 803. I have that monitor back at home, and it is mindblowingly good. No surprise as it retailed for $2000 in 1997. I took some pictures back when I got mine.
Pluto, the maxed out Dell Dimension 4100: Pentium III 1400S | 256MB | GeForce4 Ti4200 + Voodoo4 4500 | SB Live! 5.1
Charon, the DOS and early Windows time machine: K6-III+ 600 | 256MB | TNT2 Ultra + Voodoo3 2000 | Audician 32 Plus
Reply 308 of 540, by looking4awayout
This old lady is the monitor of my Pentium 3 retro daily driver!
109.38 KiB
It's a Crystal CM-1402E made in 1989 by Intra Electronics, 14" shadow mask monitor with a .31mm dot pitch. It was made under several brands such as Arcus, ARX, Ancer, MGC, Crystal, Intra, Socos, JET and many others. It's one of the earliest "8514/A compatible" VGA monitors and supports only three resolutions (640x480, 800x600 and 1024x768 interlaced) along with a few sub-resolutions. It's not a real multiscan monitor and makes it akin to an IBM 8514 in terms of features. Picture is kind of fuzzy but it's not blurry and unreadable: the "fuzziness" of the screen smooths out fonts and graphics giving to the overall appearance a very pleasant look and doesn't make 640x480 look huge. It's also not a quite flickery monitor despite I run it at 60Hz. What I love most of this monitor is its colours, as they are very deep and vibrant, something I could only dream of on a flatscreen display.
I had some niggles with it the first time I got it: red tended to flicker and disappear randomly until it finally stopped flickering for good, for a period it jittered when being turned on at cold (fixed the issue by using a non grounded power cord, I suspect it was a ground loop issue) and its connector is quite mangled since it was a bit mistreated after two decades of storage.
Thankfully all these issues have been fixed but in future it definitely needs a capacitor replacement to make it work as good as it was back when new. I love this monitor to bits.
My Retro Daily Driver: Pentium !!!-S 1.7GHz | 3GB PC166 ECC SDRAM | Geforce 6800 Ultra 256MB | 128GB Lite-On SSD + 500GB WD Blue SSD | ESS Allegro PCI | Windows XP Professional SP3
Reply 309 of 540, by VileR
Probably not what is meant by this thread, but this is what I'm stuck with, so I'm using it as a monitor 😉 (I'm yet to figure out how to photograph this thing without moire, over-brightness, and white-balance issues.)
1.76 MiB
Found by chance at a TV repair shop down the street- they were looking to get rid of it. Since it's a 14" set in good shape, and supports NTSC (not a very common thing around here, but the TINT control gave it away!), I figured it'd be a more 'appropriate' CGA display than my more modern flat-screen TV, even if the latter deals surprisingly well with CGA.
Can you handle the superior quality of 80-column text over composite?
1.7 MiB
Reply 310 of 540, by xjas
^^ Good old Never Twice the Same Colour. 😜 PAL TVs don't even have tint adjustment?
Reply 311 of 540, by VileR
Never seen one that had it, unless it was a so-called 'multi-system' (dual PAL/NTSC) set. I think this TV may actually handle PAL as well, since it was manufactured in 1999 and that was becoming common then.
Reply 312 of 540, by Woolie Wool
I should buy a real camera; a phone is hopeless at photographing a CRT head-on:
Sun GDM-51010PT 21" Trinitron. It's absolutely magnificent at 1600x1200. It is an NOS unit that shipped in its original sealed box and cost me $200 + $100 shipping on eBay; god only knows how much it cost in 1998.
It's not actually that dark in the room; that's the phone throttling the exposure when it gazes into the CRT.
wp0kyr-2.png CALIFORNIA_RAYZEN
1wpfky-2.png REDBOX
3q6x0e-2.png FUNKENSTEIN_3D
Reply 313 of 540, by bjwil1991
Not a bad photo of the CRT. Was that monitor distributed by Sony, hence the name Trinitron?
Reply 314 of 540, by Woolie Wool
No. The tube and possibly some other components were built by Sony, Sun marketed and distributed it as a monitor for SPARC workstations. It was not marketed as a Trinitron in the material, but it has a Trinitron CRT inside.
1wpfky-2.png REDBOX
Reply 315 of 540, by Jed118
1992's TTX XGA (I got it to 1280x1024) - Not sure of the dot pitch but it is kinda blurry and changing the resolution bounces the image around. I've relegated it to my 286 (which really needs an EGA)
This Samsung Syncmaster 3Ne for my 486 DX2/66 - Very clear and sharp image. I occasionally will use it for Photoshop work:
And 1989's DataTrain DC-509 VGA monitor that came with my 386SX. I have the original packaging and styrofoam for this one.
Decently clear image for what it is.
I also have an NCR 17 inch in the closet, a 14" Digital XGA and another 17" TTX in original packaging that I will try to bundle with a PII system when I'm ready to sell it.
What's for sale? my eBay!
Reply 316 of 540, by HPI
CRT Mon with all in one
FmTowns ur20
80486SX-20 MHz
Sony Trinitron CRT
    21.69 KiB
Reply 317 of 540, by xjas
HPI wrote:
CRT Mon with all in one FmTowns ur20 80486SX-20 MHz Sony Trinitron CRT […]
FmTowns ur20
80486SX-20 MHz
Sony Trinitron CRT
OMG I love that. No idea they made those (well, I don't know much about FM Towns models in general.) Looks SO good in that charcoal grey too.
Reply 319 of 540, by HPI
My FM Towns UR20
    96.7 KiB
    71.78 KiB
    67.31 KiB
    42.36 KiB
