First post, by enginesol
Hi!
Today i received a Roland SC-55ST.
Here I put a picture of the inside ( PCB ).
Roland SC-88 ( INSIDE )
And my two Roland's: SC-88 & SC-55ST
Greetings!
Reply 1 of 11, by keropi
always nice to see another one that likes to open up stuff 🤣
thanks for the pics!
🎵 PCMIDI mpu site buy+info
🎧 WIP Orpheus soundcard site
Reply 5 of 11, by keropi
it's the Yamaha S-YXG50 , a software based synth like Virtual Canvas
Reply 7 of 11, by enginesol
I confirm that this does not belong to graphic equalizer Yamaha S-YXG50 program (I think it is a plugin ... but i don't know which programa use it).
Reply 9 of 11, by ik777
enginesol wrote:
You need MidiYoke to make your VSC and S-YXG50 as a Midi Device. (Such like inputport to Midi yoke : 0 1 2...)
then copy savihost.exe to your VSC's DLL file. (you may change savihost another name as you like)
Run renamed savihost.exe. If all is correct, you can run legacy XG soft synth.
file.php?mode=view&id=13854&sid=89966bf1a7afed9635758b2362ca4ead
    155.11 KiB
    No downloads
Reply 10 of 11, by enginesol
ik777 wrote:
You need MidiYoke to make your VSC and S-YXG50 as a Midi Device. (Such like inputport to Midi yoke : 0 1 2...) […]
Excuse me, do you have the plugin ( VST ) of YAMAHA XG SoftSynthesizer S-YXG50?
I have the S-YXG50.dll, but don't works for me! ¿?
Thanks!
Reply 11 of 11, by ik777
enginesol wrote:
Excuse me, do you have the plugin ( VST ) of YAMAHA XG SoftSynthesizer S-YXG50? I have the S-YXG50.dll, but don't works for me! […]
Thanks!
file.php?mode=view&id=13885&sid=9bbc7de167f24a1fce95349a4f77c41f
If you did it correctly, it cannot have errors. The purple square icon file (savihost.exe) is same file. There's no special plugin.
    33.7 KiB
