Reply 200 of 270, by Falcosoft
Joseph_Joestar wrote on 2020-02-18, 07:06:
Anyone tried SetMul with a Duron on a SocketA system? I have an Abit KT7A and I'm thinking about downgrading my AthlonXP 1500+ to a Duron 700 in the hopes of getting more slowdown choices.
Currently, SetMul only allows me to disable the L1 cache on the AthlonXP which puts it at around 386 levels, and that's really awesome. However, I'd like something not quite as slow for mid-late 90s games like WarCraft 2 and Red Alert which have issues with overly fast screen scrolling.
Is it possible for SetMul to change the multiplier on the Duron and make it run at something like 200 MHz? For reference, the multiplier settings in my BIOS only go down to 5x.
1. There is no point in replacing your Athlon to Duron for more slowdown choices. Every SocketA desktop CPU has the same minimum multiplier(5x) and cache disabling option with your board . Only L1 cache disabling is possible (which also means disabled L2 cache) so a Duron and an Athlon with disabled L1 cache have the exact same speed. Even with caches enabled the difference is minimal at the possible minimum 500 MHz (5x100).
2. Setmul can only set K7 multipliers in real time with mobile K7 CPU (Athlon XP-M). You can make a desktop CPU a mobile one by modifying some bridges:
http://fab51.com/cpu/barton/athlon-e24.html
https://web.archive.org/web/20170912115837/ht … tiplier_FAQ.htm
The above modifications can work with your Athlon XP but definitely not with your Duron 700. The processor must have some MSR registers for this to work and only Morgan+ Durons have them. Your Duron 700 is a Spitfire without PowerNow! MSR registers.
But unfortunately on KT7-A it's not enough since it's a desktop and not a mobile board. You also have to manually tune your chipset for Setmul to be able to set multipliers on the fly:
https://web.archive.org/web/20170822100906/ht … html/Tweaks.htm
Website, Facebook, Youtube
VST Midi Driver Midi Mapper
Reply 201 of 270, by Joseph_Joestar
That's too bad, I was hoping for some K6 style granularity with the slowdown.
Ah well, the Duron cost me only 5 EUR, so no big loss.
Reply 202 of 270, by SaxxonPike
Thank you so much for this utility!
I just grabbed v1.24 to test with an Athlon XP-M 3000+. I have it installed in a KT133A board, the Soltek SL75-KAV. The processor works great and is stable in this board. Crystal can set the multiplier in Windows without issues all the way up to the processor's reported maximum, 16.5x. The startup multiplier and FSB frequency are configured via jumpers on the motherboard. Voltage is configured via a BIOS setting.
SetMul shows all the current settings correctly. Disabling or enabling the L1 cache with SetMul seems to work fine. However, when I attempt to use SetMul to change the multiplier to anything else, it hangs at "Setting K7 PowerNow..", regardless which drivers or TSRs I boot with.
Here's a captured screen from the machine:
56.58 KiB
Anything I should try, or additional info you will need to diagnose this one?
Sound device guides:
Sound Blaster
Aztech
OPL3-SA
Reply 203 of 270, by MKT_Gundam
Past week , saved a VIA c3 700Mhz (100fsb and 1,6v -Saumel 2?).
At BIOS Menu (ASUS CUV4x), seems the multiplier is locked.
Any chances to change the multiplier at SetMul?
Retro rig 1: Asus CUV4X, VIA c3 800, Voodoo Banshee (Diamond fusion) and SB32 ct3670.
Retro rig 2: Intel DX2 66, SB16 Ct1740 and Cirrus Logic VLB.
Reply 204 of 270, by kolderman
MKT_Gundam wrote on 2020-07-29, 01:56:
100% chance. Why the C3 is so nice.
Reply 205 of 270, by MKT_Gundam
kolderman wrote on 2020-07-29, 02:13:
Yes. Its working!
Lowest setting for me 3x 66.6 (200mhz)
At speedtest i got 13,1 with L1/2 disabled , BPD and ICD.
Using freeDOS and no soundcards.
Reply 206 of 270, by kolderman
MKT_Gundam wrote on 2020-07-29, 03:07:
Yes. Its working! Lowest setting for me 3x 66.6 (200mhz) At speedtest i got 13,1 with L1/2 disabled , BPD and ICD. Using freeDO […]
Yes. Its working!
That sounds about right. I think my k6-3 got around 11 at slowest settings. The C3 will scale better over the 486-pentium range though.
Reply 207 of 270, by MKT_Gundam
kolderman wrote on 2020-07-29, 03:37:
Yes. Its working!
I waiting for my slotcket and put this or my Erza 800 on BX board.
My CUV4x has only 1 ISA slot. I want put another isa soundcard + arueal vortex2 or Sb live.
Reply 208 of 270, by kolderman
MKT_Gundam wrote on 2020-07-29, 03:50:
Yes. Its working!
The Live might have issues with the Via chipset on that board, the vortex2 will be fine though.
Reply 209 of 270, by bbuchholtz
Hey Gerwin,
Thank you very much for this tool. It's been super useful!
I was wondering if there was a way to call setmul from config.sys? I'm looking for a way to change CPU registers, before the memory manager loads.
-Brian
Reply 210 of 270, by gerwin
bbuchholtz wrote on 2020-11-22, 18:58:
Hey Gerwin, […]
Hey Gerwin,
-Brian
Glad to hear that SetMul has been useful.
I don't know exactly what configuration you are thinking of. The way SetMul is compiled it is of course no DOS .sys driver, nor is it a real mode program. But if you want a real mode program to simply send certain bytes to certain CPU registers, is such a thing not already available?
Currently my mind is not really on making significant changes to SetMul.
Reply 211 of 270, by bbuchholtz
Hey Gerwin,
I'm having an issue with QEMM's DPMI. I am unable to disable CPU cache, while DPMI is active. However, I can safely change CPU multiplier.
I'm looking for a way to disable CPU cache, before the memory manager loads. A lot of folks use QEMM and DPMI. May be a worthwhile feature to add.
-Brian
Reply 212 of 270, by cyclone3d
Hi Gerwin,
I am using a modified ASUS PVI-486AP4 motherboard with a Cyrix 5x86-120.
I am able to get down to a 4Mhz fsb on this board and depending on how I set the CPU to the 1x multiplier, Setmul shows either 1.2Mhz or 2.0Mhz for the CPU speed.
I am not 100% sure on the motherboard jumper method for getting to 1x multiplier because chkcpu shows a 1.9Mhz fsb and a multiplier of 2.
Even when not running at super slow speeds, the CPU Mhz is not detected properly.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 213 of 270, by gerwin
bbuchholtz wrote on 2020-11-30, 18:29:
I am sorry for the delay. I missed a reply notification.
Attached CACHEOFF.zip with source code. This is for L1 cache only. It is very simple.
Now this is not made as a DOS device driver, for use with the config.sys install= or device= options. Anyone have any idea how to turn it into one?
cyclone3d wrote on 2020-12-23, 08:15:
I am more interested in what it shows exactly, at more common CPU speeds.
For CPUs that do not support timestamp-counter, SetMul reverts to a XOR chaining benchmark, as suggested here:
https://wiki.osdev.org/Detecting_CPU_Speed
It worked well with a multitude of socket 3 processors, but I used just two motherboards for testing the calibration (XOR to MHz).
    CACHEOFF.zip
    1.47 KiB
    114 downloads
Reply 214 of 270, by Falcosoft
gerwin wrote on 2021-01-08, 00:25:
...Now this is not made as a DOS device driver, for use with the config.sys install= or device= options. Anyone have any idea how to turn it into one?
I have compiled a DOS device driver that can be run from CONFIG.SYS to disable cache.
DEVICE=C:\...\CACHEOFF.SYS
CACHEOFF.zip
882 Bytes
141 downloads
Reply 217 of 270, by gerwin
Bumrusher89 wrote on 2021-02-28, 10:28:
I have a question for the L1DX parameter. What do you mean by “exclusively”?
The normal "L1D" method disables L1 cache, but as a side effect the L2 cache is also non-functional. Some processors have a special command that can disable L1 cache whilst leaving L2 cache functional: L1DX.
Reply 218 of 270, by Lazer42
I'm a new user of this very nice utility and I have a few questions I have been unable to get a good answer on by searching around the internet.
I am running a K6-2+. Do I understand correctly that this CPU has an L1 and an L2 cache on-die, meaning that the motherboard cache functions as an L3?
If so, what does this mean for enabling or disabling these caches via different methods?
If I use the L1D switch, will it disable the L1 and L2 on-die caches and leave the L3 cache active?
If I use L1DX would I then have no L1 cache but an active L2 cache and also an active L3 motherboard cache?
If I disable the external cache in the BIOS, does this then disable only the L3 cache and leave the L2 and L1 to be controlled by Setmul?
Or, do I have this all wrong and confused?
Reply 219 of 270, by gerwin
Lazer42 wrote on 2021-04-29, 15:48:
Yes. L2 cache is on the K6-III / K6-III-P / K6-2+ / K6-III+. Next in line is the motherboard cache.
Fortunately I wrote about this earlier in this topic, on page 1, at 11-3-2014. It also has an image there, which may help illustrate things.
"When you use an AMD K6 with on-Die L2 cache, the motherboard external cache changes from L2 to L3. I found that when I disable the L1 cache, the L2 seems to become non-functional too. Giving me 20,87 points in Speedsys at 2.0x60=120MHz. This is with the L3 cache still working."
Then later the L1DX method was implemented in SetMul and it prevents this part from happening: "L2 seems to become non-functional too".
Yes, the external cache being external of the CPU.
